[petsc-users] PETSc and MPI-3/RMA
Jed Brown jed at jedbrown.org
Sat Dec 9 18:13:38 CST 2023
It uses nonblocking point-to-point by default since that tends to perform better and is less prone to MPI implementation bugs, but you can select `-sf_type window` to try it, or use other strategies here depending on the sort of problem you're working with.
#define PETSCSFBASIC      "basic"
#define PETSCSFNEIGHBOR   "neighbor"
#define PETSCSFALLGATHERV "allgatherv"
#define PETSCSFALLGATHER  "allgather"
#define PETSCSFGATHERV    "gatherv"
#define PETSCSFGATHER     "gather"
#define PETSCSFALLTOALL   "alltoall"
#define PETSCSFWINDOW     "window"
PETSc does try to use GPU-aware MPI, though implementation bugs are present on many machines and it often requires a delicate environment arrangement.
"Maeder  Alexander" <almaeder at student.ethz.ch> writes:
> I am a new user of PETSc
> and want to know more about the underlying implementation for matrix-vector multiplication (Ax=y).
> PETSc utilizes a 1D distribution and communicates only parts of the vector x utilized depending on the sparsity pattern of A.
> Is the communication of x done with MPI-3 RMA and utilizes cuda-aware mpi for RMA?
> Best regards,
> Alexander Maeder
