[petsc-users] Help for MatNullSpaceCreateRigidBody
Jeremy Theler (External) jeremy.theler-ext at ansys.com
Tue Dec 5 14:22:25 CST 2023
just in case it helps, here's one way I have to create the near nullspace:
https://github.com/seamplex/feenox/blob/main/src/pdes/mechanical/init.c#L468
jeremy
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Jordi Manyer Fuertes via petsc-users <petsc-users at mcs.anl.gov>
Sent: Tuesday, December 5, 2023 9:57 AM
To: Matthew Knepley <knepley at gmail.com>; bsmith at petsc.dev <bsmith at petsc.dev>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Help for MatNullSpaceCreateRigidBody
[External Sender]
Thanks for the prompt response. Both answers look like what I'm doing.
After playing a bit more with solver, I managed to make it run in parallel with different boundary conditions (full dirichlet bcs, vs mixed newmann + dirichlet). This raises two questions:
- How relevant are boundary conditions (eliminating dirichlet rows/cols vs weak newmann bcs) to the solver? Should I modify something when changing boundary conditions?
- Also, the solver did well with the old bcs when run in a single processor (but not in parallel). This seems odd, since parallel and serial behavior should be consistent (or not?). Could it be fault of the PCGAMG? I believe the default local solver is ILU, shoud I be changing it to LU or something else for these kind of problems?
Thank you both again,
Jordi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231205/d85d4ebf/attachment-0001.html>
