[petsc-users] Orthogonalization of a (sparse) PETSc matrix
Thanasis Boutsikakis thanasis.boutsikakis at corintis.com
Tue Aug 29 11:50:36 CDT 2023
Hi all, I have the following code that orthogonalizes a PETSc matrix. The problem is that this implementation requires that the PETSc matrix is dense, otherwise, it fails at bv.SetFromOptions(). Hence the assert in orthogonality().
What could I do in order to be able to orthogonalize sparse matrices as well? Could I convert it efficiently? (I tried to no avail)
Thanks!
"""Experimenting with matrix orthogonalization"""
import contextlib
import sys
import time
import numpy as np
from firedrake import COMM_WORLD
from firedrake.petsc import PETSc
import slepc4py
slepc4py.init(sys.argv)
from slepc4py import SLEPc
from numpy.testing import assert_array_almost_equal
EPSILON_USER = 1e-4
EPS = sys.float_info.epsilon
def Print(message: str):
    """Print function that prints only on rank 0 with color
    Args:
        message (str): message to be printed
    PETSc.Sys.Print(message)
def create_petsc_matrix(input_array, sparse=True):
    """Create a PETSc matrix from an input_array
    Args:
        input_array (np array): Input array
        partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
        sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
    Returns:
        PETSc mat: PETSc matrix
    # Check if input_array is 1D and reshape if necessary
    assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
    global_rows, global_cols = input_array.shape
    size = ((None, global_rows), (global_cols, global_cols))
    # Create a sparse or dense matrix based on the 'sparse' argument
    if sparse:
        matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
    else:
        matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
    matrix.setUp()
    local_rows_start, local_rows_end = matrix.getOwnershipRange()
    for counter, i in enumerate(range(local_rows_start, local_rows_end)):
        # Calculate the correct row in the array for the current process
        row_in_array = counter + local_rows_start
        matrix.setValues(
            i, range(global_cols), input_array[row_in_array, :], addv=False
    # Assembly the matrix to compute the final structure
    matrix.assemblyBegin()
    matrix.assemblyEnd()
    return matrix
def orthogonality(A):  # sourcery skip: avoid-builtin-shadow
    """Checking and correcting orthogonality
    Args:
        A (PETSc.Mat): Matrix of size [m x k].
    Returns:
        PETSc.Mat: Matrix of size [m x k].
    # Check if the matrix is dense
    mat_type = A.getType()
    assert mat_type in (
        "seqdense",
        "mpidense",
    ), "A must be a dense matrix. SLEPc.BV().createFromMat() requires a dense matrix."
    m, k = A.getSize()
    Phi1 = A.getColumnVector(0)
    Phi2 = A.getColumnVector(k - 1)
    # Compute dot product using PETSc function
    dot_product = Phi1.dot(Phi2)
    if abs(dot_product) > min(EPSILON_USER, EPS * m):
        Print("    Matrix is not orthogonal")
        # Type can be CHOL, GS, mro(), SVQB, TSQR, TSQRCHOL
        _type = SLEPc.BV().OrthogBlockType.GS
        bv = SLEPc.BV().createFromMat(A)
        bv.setFromOptions()
        bv.setOrthogonalization(_type)
        bv.orthogonalize()
        A = bv.createMat()
        Print("    Matrix successfully orthogonalized")
        # # Assembly the matrix to compute the final structure
        if not A.assembled:
            A.assemblyBegin()
            A.assemblyEnd()
    else:
        Print("    Matrix is orthogonal")
    return A
# EXP: Orthogonalization of an mpi PETSc matrix
m, k = 11, 7
# Generate the random numpy matrices
np.random.seed(0)  # sets the seed to 0
A_np = np.random.randint(low=0, high=6, size=(m, k))
A = create_petsc_matrix(A_np, sparse=False)
A_orthogonal = orthogonality(A)
# TEST: Orthogonalization of a numpy matrix
# Generate A_np_orthogonal
A_np_orthogonal, _ = np.linalg.qr(A_np)
# Get the local values from A_orthogonal
local_rows_start, local_rows_end = A_orthogonal.getOwnershipRange()
A_orthogonal_local = A_orthogonal.getValues(
    range(local_rows_start, local_rows_end), range(k)
# Assert the correctness of the multiplication for the local subset
assert_array_almost_equal(
    np.abs(A_orthogonal_local),
    np.abs(A_np_orthogonal[local_rows_start:local_rows_end, :]),
    decimal=5,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230829/98d3c874/attachment-0001.html>
