[petsc-users] Error while building PETSc with MATLAB
Tue Aug 29 09:01:18 CDT 2023
Send configure.log, make.log from both petsc-3.13 and 3.17 [or 3.19].
[you can gzip them to make the logs friendly to mailing list - or send them to petsc-maint]
And does test suite work with 3.17? [or 3.19?]
Satish
On Tue, 29 Aug 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
> I am sharing the make.log file while building petsc-3.13.4 with Matlab.
> Please find the attachment and do the needful.
> On Tue, Aug 29, 2023 at 10:19 AM INTURU SRINIVAS 20PHD0548 <
> inturu.srinivas2020 at vitstudent.ac.in> wrote:
> > I tried with petsc-3.17.5. During building of libmesh, the error shows
> > petsc was not found
> > On Mon, Aug 28, 2023 at 9:43 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >> https://ibamr.github.io/linux says petsc-3.17
> >> Here you are using 3.13
> >> Can you retry with petsc-3.17.5?
> >> Satish
> >> On Mon, 28 Aug 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
> >> > Hello,
> >> > I want to build PETSc with MATLAB for working on the simulation using
> >> IBAMR
> >> > open software. While building the PETSc, using the following
> >> > export PETSC_DIR=$PWD
> >> > export PETSC_ARCH=linux-debug
> >> > ./configure \
> >> >   --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
> >> >   --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
> >> >   --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
> >> >   --with-debugging=1 \
> >> >   --download-hypre=1 \
> >> >   --download-fblaslapack=1 \
> >> >   --with-x=0 \
> >> >   --with-matlab-dir=/usr/local/MATLAB/R2020b/
> >> >   --with-matlab-engine=1
> >> >   --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
> >> > make -j4
> >> > make -j4 test
> >> > I got the following error
> >> > CLINKER
> >> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
> >> > /usr/bin/ld:
> >> > linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
> >> > function `EvaluateResidual':
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
> >> > undefined reference to `PetscMatlabEnginePut'
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
> >> > undefined reference to `PetscMatlabEngineEvaluate'
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
> >> > undefined reference to `PetscMatlabEngineGet'
> >> > /usr/bin/ld:
> >> > function `EvaluateJacobian':
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
> >> > /usr/bin/ld:
> >> > function `TaoPounders':
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
> >> > /usr/bin/ld:
> >> > function `main':
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
> >> > undefined reference to `PetscMatlabEngineCreate'
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
> >> > undefined reference to `PetscMatlabEngineGetArray'
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
> >> > /usr/bin/ld:
> >> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
> >> > undefined reference to `PetscMatlabEngineDestroy'
> >> > collect2: error: ld returned 1 exit status
> >> > make: *** [gmakefile.test:185:
> >> > linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
> >> Error 1
> >> > make: *** Waiting for unfinished jobs....
> >> > Please help me to solve this issue
> >> > Thank you
> >> > Srinivas
