[petsc-users] Error while building PETSc with MATLAB
INTURU SRINIVAS 20PHD0548 inturu.srinivas2020 at vitstudent.ac.in
Mon Aug 28 11:14:35 CDT 2023
I will try it.
On Mon, Aug 28, 2023, 21:43 Satish Balay <balay at mcs.anl.gov> wrote:
> https://ibamr.github.io/linux says petsc-3.17
> Here you are using 3.13
> Can you retry with petsc-3.17.5?
> Satish
> On Mon, 28 Aug 2023, INTURU SRINIVAS 20PHD0548 via petsc-users wrote:
> > Hello,
> > I want to build PETSc with MATLAB for working on the simulation using
> IBAMR
> > open software. While building the PETSc, using the following
> > export PETSC_DIR=$PWD
> > export PETSC_ARCH=linux-debug
> > ./configure \
> >   --CC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicc \
> >   --CXX=$HOME/sfw/linux/openmpi/4.1.4/bin/mpicxx \
> >   --FC=$HOME/sfw/linux/openmpi/4.1.4/bin/mpif90 \
> >   --with-debugging=1 \
> >   --download-hypre=1 \
> >   --download-fblaslapack=1 \
> >   --with-x=0 \
> >   --with-matlab-dir=/usr/local/MATLAB/R2020b/
> >   --with-matlab-engine=1
> >   --with-matlab-engine-dir=/usr/local/MATLAB/R2020b/extern/engines/
> > make -j4
> > make -j4 test
> > I got the following error
> > CLINKER
> linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test
> > /usr/bin/ld:
> > linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test.o: in
> > function `EvaluateResidual':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:32:
> > undefined reference to `PetscMatlabEnginePut'
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:33:
> > undefined reference to `PetscMatlabEngineEvaluate'
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:35:
> > undefined reference to `PetscMatlabEngineGet'
> > /usr/bin/ld:
> > function `EvaluateJacobian':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:46:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:47:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:49:
> > /usr/bin/ld:
> > function `TaoPounders':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:75:
> > /usr/bin/ld:
> > function `main':
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:126:
> > undefined reference to `PetscMatlabEngineCreate'
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:127:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:139:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:140:
> > undefined reference to `PetscMatlabEngineGetArray'
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:142:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:144:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:146:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:148:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:154:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:157:
> > /usr/bin/ld:
> /home/vit/sfw/petsc/3.13.4/src/tao/leastsquares/tutorials/matlab/matlab_ls_test.c:158:
> > undefined reference to `PetscMatlabEngineDestroy'
> > collect2: error: ld returned 1 exit status
> > make: *** [gmakefile.test:185:
> > linux-debug/tests/tao/leastsquares/tutorials/matlab/matlab_ls_test]
> Error 1
> > make: *** Waiting for unfinished jobs....
> > Please help me to solve this issue
> > Thank you
> > Srinivas
**Disclaimer:*
This message was sent from Vellore Institute of Technology.
The contents of this email may contain legally protected confidential or
privileged information of “Vellore Institute of Technology”.  If you are
not the intended recipient, you should not disseminate, distribute or copy
this e-mail. Please notify the sender immediately and destroy all copies of
this message and any attachments. If you have received this email in error,
please promptly notify the sender by reply email and delete the original
email and any backup copies without reading them.*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230828/17629862/attachment-0001.html>
