[petsc-users] C++11 related issue
maitri ksh maitri.ksh at gmail.com
Fri Aug 25 06:04:30 CDT 2023
Thanks Matt for the clarification, I used gcc11.2 instead and the
petsc-configuration worked out fine. But now, I am facing an issue while
doing the 'make check' of the libraries. The error points to some
unbalanced or mismatch of double-quote (")
/usr/bin/bash: -c: line 6: unexpected EOF while looking for matching `"'
/usr/bin/bash: -c: line 7: syntax error: unexpected end of file
The error seems to be related to a shell script, I am unable to debug the
error,  I looked for instances where 'bash -c' is being used, I couldn't
locate any. How should I proceed?
On Thu, Aug 24, 2023 at 1:37 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 24, 2023 at 6:10 AM maitri ksh <maitri.ksh at gmail.com> wrote:
>> I was facing a problem while compiling a code (which earlier, got
>> compiled successfully using the same petsc set up), the problem was related
>> to compilers. I decided to reconfigure petsc but ran into errors which are
>> related to non-compliance of the compiler with  'C++11'. I had faced this
>> issue earlier when I was installing Petsc and I had it resolved by using a
>> newer version of compiler (openmpi-4.1.5).
> OpenMPI is not a compiler. It is an implementation of MPI that produces
> compiler wrappers. Your actual compiler appears to be GCC 4.8.2:
>               Output from compiling with  -std=c++11
> In file included from /usr/include/c++/4.8.2/algorithm:62:0,
>                  from
> /tmp/petsc-hl_0r720/config.setCompilers/conftest.cc:9:
> /usr/include/c++/4.8.2/bits/stl_algo.h: In instantiation of
> ‘_RandomAccessIterator std::__unguarded_partition(_RandomAccessIterator,
> _RandomAccessIterator, const _Tp&, _Compare) [with _RandomAccessIterator =
> __gnu_cxx::__normal_iterator<std::unique_ptr<double>*,
> std::vector<std::unique_ptr<double> > >; _Tp = std::unique_ptr<double>;
> _Compare = main()::__lambda0]’:
> /usr/include/c++/4.8.2/bits/stl_algo.h:2296:78:   required from
> std::__unguarded_partition_pivot(_RandomAccessIterator,
> _RandomAccessIterator, _Compare) [with _RandomAccessIterator =
> std::vector<std::unique_ptr<double> > >; _Compare = main()::__lambda0]’
> /usr/include/c++/4.8.2/bits/stl_algo.h:2337:62:   required from ‘void
> std::__introsort_loop(_RandomAccessIterator, _RandomAccessIterator, _Size,
> std::vector<std::unique_ptr<double> > >; _Size = long int; _Compare =
> main()::__lambda0]’
> /usr/include/c++/4.8.2/bits/stl_algo.h:5499:44:   required from ‘void
> std::sort(_RAIter, _RAIter, _Compare) [with _RAIter =
> /tmp/petsc-hl_0r720/config.setCompilers/conftest.cc:58:119:   required
> from here
> /usr/include/c++/4.8.2/bits/stl_algo.h:2263:35: error: no match for call
> to ‘(main()::__lambda0) (std::unique_ptr<double>&, const
> std::unique_ptr<double>&)’
>     while (__comp(*__first, __pivot))
> /tmp/petsc-hl_0r720/config.setCompilers/conftest.cc:58:42: note:
> candidates are:
>  std::sort(vector.begin(), vector.end(), [](std::unique_ptr<double> &a,
> std::unique_ptr<double> &b) { return *a < *b; });
>                  from
> /usr/include/c++/4.8.2/bits/stl_algo.h:2263:35: note: bool
> (*)(std::unique_ptr<double>&, std::unique_ptr<double>&) <conversion>
> This compiler was released almost 10 years ago and has incomplete support
> for C++11.
>> Now, I am trying to use the same compiler (openmpi-4.1.5) to reconfigure
>> petsc but the old issue (related to 'C++11') pops up. I used a code that
>> was available online
>> <https://stackoverflow.com/questions/5047971/how-do-i-check-for-c11-support>
>> to check if the present compiler supports C++11, and it shows it does
>> support.
> You may not have read to the bottom of the answer, but it tells you how to
> check for complete support for C++11 and this compiler definitely does not
> have it.
>   Thanks,
>      Matt
>> I have attached the '*configure.log*' herewith for your reference.
>> Can anyone suggest how to resolve/work-around this issue?
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230825/0945d4a9/attachment.html>
