[petsc-users] CUDA error trying to run a job with two mpi processes and 1 GPU
Vanella, Marcos (Fed) marcos.vanella at nist.gov
Tue Aug 22 14:53:44 CDT 2023
Hi Junchao, both the slurm scontrol show job_id -dd and looking at CUDA_VISIBLE_DEVICES does not provide information about which MPI process is associated to which GPU in the node in our system. I can see this with nvidia-smi, but if you have any other suggestion using slurm I would like to hear it.
I've been trying to compile the code+Petsc in summit, but have been having all sorts of issues related to spectrum-mpi, and the different compilers they provide (I tried gcc, nvhpc, pgi, xl. Some of them don't handle Fortran 2018, others give issues of repeated MPI definitions, etc.).
I also wanted to ask you, do you know if it is possible to compile PETSc with the xl/16.1.1-10 suite?
Thanks!
I configured the library --with-cuda and when compiling I get a compilation error with CUDAC:
CUDAC arch-linux-opt-xl/obj/src/sys/classes/random/impls/curand/curand2.o
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/src/sys/classes/random/impls/curand/curand2.cu:1:
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petsc/private/randomimpl.h:5:
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petsc/private/petscimpl.h:7:
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscsys.h:44:
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscsystypes.h:532:
In file included from /sw/summit/cuda/11.7.1/include/thrust/complex.h:24:
In file included from /sw/summit/cuda/11.7.1/include/thrust/detail/config.h:23:
In file included from /sw/summit/cuda/11.7.1/include/thrust/detail/config/config.h:27:
/sw/summit/cuda/11.7.1/include/thrust/detail/config/cpp_dialect.h:112:6: warning: Thrust requires at least Clang 7.0. Define THRUST_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message. [-W#pragma-messages]
     THRUST_COMPILER_DEPRECATION(Clang 7.0);
/sw/summit/cuda/11.7.1/include/thrust/detail/config/cpp_dialect.h:101:3: note: expanded from macro 'THRUST_COMPILER_DEPRECATION'
  THRUST_COMP_DEPR_IMPL(Thrust requires at least REQ. Define THRUST_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.)
/sw/summit/cuda/11.7.1/include/thrust/detail/config/cpp_dialect.h:95:38: note: expanded from macro 'THRUST_COMP_DEPR_IMPL'
#  define THRUST_COMP_DEPR_IMPL(msg) THRUST_COMP_DEPR_IMPL0(GCC warning #msg)
/sw/summit/cuda/11.7.1/include/thrust/detail/config/cpp_dialect.h:96:40: note: expanded from macro 'THRUST_COMP_DEPR_IMPL0'
#  define THRUST_COMP_DEPR_IMPL0(expr) _Pragma(#expr)
<scratch space>:141:6: note: expanded from here
 GCC warning "Thrust requires at least Clang 7.0. Define THRUST_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message."
In file included from /autofs/nccs-svm1_home1/vanellam/Software/petsc/src/sys/classes/random/impls/curand/curand2.cu:2:
In file included from /sw/summit/cuda/11.7.1/include/thrust/transform.h:721:
In file included from /sw/summit/cuda/11.7.1/include/thrust/detail/transform.inl:27:
In file included from /sw/summit/cuda/11.7.1/include/thrust/system/detail/generic/transform.h:104:
In file included from /sw/summit/cuda/11.7.1/include/thrust/system/detail/generic/transform.inl:19:
In file included from /sw/summit/cuda/11.7.1/include/thrust/for_each.h:277:
In file included from /sw/summit/cuda/11.7.1/include/thrust/detail/for_each.inl:27:
In file included from /sw/summit/cuda/11.7.1/include/thrust/system/detail/adl/for_each.h:42:
In file included from /sw/summit/cuda/11.7.1/include/thrust/system/cuda/detail/for_each.h:35:
In file included from /sw/summit/cuda/11.7.1/include/thrust/system/cuda/detail/util.h:36:
In file included from /sw/summit/cuda/11.7.1/include/cub/detail/device_synchronize.cuh:19:
In file included from /sw/summit/cuda/11.7.1/include/cub/util_arch.cuh:36:
/sw/summit/cuda/11.7.1/include/cub/util_cpp_dialect.cuh:123:6: warning: CUB requires at least Clang 7.0. Define CUB_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message. [-W#pragma-messages]
     CUB_COMPILER_DEPRECATION(Clang 7.0);
/sw/summit/cuda/11.7.1/include/cub/util_cpp_dialect.cuh:112:3: note: expanded from macro 'CUB_COMPILER_DEPRECATION'
  CUB_COMP_DEPR_IMPL(CUB requires at least REQ. Define CUB_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.)
/sw/summit/cuda/11.7.1/include/cub/util_cpp_dialect.cuh:106:35: note: expanded from macro 'CUB_COMP_DEPR_IMPL'
#  define CUB_COMP_DEPR_IMPL(msg) CUB_COMP_DEPR_IMPL0(GCC warning #msg)
/sw/summit/cuda/11.7.1/include/cub/util_cpp_dialect.cuh:107:37: note: expanded from macro 'CUB_COMP_DEPR_IMPL0'
#  define CUB_COMP_DEPR_IMPL0(expr) _Pragma(#expr)
<scratch space>:198:6: note: expanded from here
 GCC warning "CUB requires at least Clang 7.0. Define CUB_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message."
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscsystypes.h(68): warning #1835-D: attribute "warn_unused_result" does not apply here
<scratch space>:149:6: note: expanded from here
<scratch space>:208:6: note: expanded from here
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:55:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(a);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:78:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:107:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(len);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:144:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(t);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:150:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(s);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:198:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(flg);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:249:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(n);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:251:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:291:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:330:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:333:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:334:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(b);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:367:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:368:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:369:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(tmp);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:403:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(haystack);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:404:3: error: use of undeclared identifier '__builtin_assume'
; __builtin_assume(needle);
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:405:3: error: use of undeclared identifier '__builtin_assume'
/autofs/nccs-svm1_home1/vanellam/Software/petsc/include/petscstring.h:437:3: error: use of undeclared identifier '__builtin_assume'
fatal error: too many errors emitted, stopping now [-ferror-limit=]
20 errors generated.
Error while processing /tmp/tmpxft_0001add6_00000000-6_curand2.cudafe1.cpp.
gmake[3]: *** [gmakefile:209: arch-linux-opt-xl/obj/src/sys/classes/random/impls/curand/curand2.o] Error 1
gmake[2]: *** [/autofs/nccs-svm1_home1/vanellam/Software/petsc/lib/petsc/conf/rules.doc:28: libs] Error 2
**************************ERROR*************************************
  Error during compile, check arch-linux-opt-xl/lib/petsc/conf/make.log
  Send it and arch-linux-opt-xl/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov
Sent: Monday, August 21, 2023 4:17 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
Cc: PETSc users list <petsc-users at mcs.anl.gov>; Guan, Collin X. (Fed) <collin.guan at nist.gov>
Subject: Re: [petsc-users] CUDA error trying to run a job with two mpi processes and 1 GPU
That is a good question.  Looking at https://slurm.schedmd.com/gres.html#GPU_Management,  I was wondering if you can share the output of your job so we can search CUDA_VISIBLE_DEVICES and see how GPUs were allocated.
--Junchao Zhang
On Mon, Aug 21, 2023 at 2:38 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Ok thanks Junchao, so is GPU 0 actually allocating memory for the 8 MPI processes meshes but only working on 2 of them?
It says in the script it has allocated 2.4GB
Best,
Marcos
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Sent: Monday, August 21, 2023 3:29 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>>
Cc: PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Guan, Collin X. (Fed) <collin.guan at nist.gov<mailto:collin.guan at nist.gov>>
Hi, Macros,
  If you look at the PIDs of the nvidia-smi output, you will only find 8 unique PIDs, which is expected since you allocated 8 MPI ranks per node.
  The duplicate PIDs are usually for threads spawned by the MPI runtime (for example, progress threads in MPI implementation).   So your job script and output are all good.
  Thanks.
On Mon, Aug 21, 2023 at 2:00 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, something I'm noting related to running with cuda enabled linear solvers (CG+HYPRE, CG+GAMG) is that for multi cpu-multi gpu calculations, the GPU 0 in the node is taking what seems to be all sub-matrices corresponding to all the MPI processes in the node. This is the result of the nvidia-smi command on a node with 8 MPI processes (each advancing the same number of unknowns in the calculation) and 4 GPU V100s:
Mon Aug 21 14:36:07 2023
| NVIDIA-SMI 535.54.03              Driver Version: 535.54.03    CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Tesla V100-SXM2-16GB           On  | 00000004:04:00.0 Off |                    0 |
| N/A   34C    P0              63W / 300W |   2488MiB / 16384MiB |      0%      Default |
|                                         |                      |                  N/A |
|   1  Tesla V100-SXM2-16GB           On  | 00000004:05:00.0 Off |                    0 |
| N/A   38C    P0              56W / 300W |    638MiB / 16384MiB |      0%      Default |
|                                         |                      |                  N/A |
|   2  Tesla V100-SXM2-16GB           On  | 00000035:03:00.0 Off |                    0 |
| N/A   35C    P0              52W / 300W |    638MiB / 16384MiB |      0%      Default |
|                                         |                      |                  N/A |
|   3  Tesla V100-SXM2-16GB           On  | 00000035:04:00.0 Off |                    0 |
| N/A   38C    P0              53W / 300W |    638MiB / 16384MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A    214626      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    0   N/A  N/A    214627      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    0   N/A  N/A    214628      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    0   N/A  N/A    214629      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    0   N/A  N/A    214630      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    0   N/A  N/A    214631      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    0   N/A  N/A    214632      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    0   N/A  N/A    214633      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      308MiB |
|    1   N/A  N/A    214627      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    1   N/A  N/A    214631      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    2   N/A  N/A    214628      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    2   N/A  N/A    214632      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    3   N/A  N/A    214629      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
|    3   N/A  N/A    214633      C   ...d/ompi_gnu_linux/fds_ompi_gnu_linux      318MiB |
You can see that GPU 0 is connected to all 8 MPI Processes, each taking about 300MB on it, whereas GPUs 1,2 and 3 are working with 2 MPI Processes. I'm wondering if this is expected or there are some changes I need to do on my submission script/runtime parameters.
This is the script in this case (2 nodes, 8 MPI processes/node, 4 GPU/node):
#!/bin/bash
# ../../Utilities/Scripts/qfds.sh -p 2  -T db -d test.fds
#SBATCH -J test
#SBATCH -e /home/mnv/Firemodels_fork/fds/Issues/PETSc/test.err
#SBATCH -o /home/mnv/Firemodels_fork/fds/Issues/PETSc/test.log
#SBATCH --partition=gpu
#SBATCH --ntasks=16
#SBATCH --ntasks-per-node=8
#SBATCH --cpus-per-task=1
#SBATCH --nodes=2
#SBATCH --time=01:00:00
#SBATCH --gres=gpu:4
export OMP_NUM_THREADS=1
# modules
module load cuda/11.7
module load gcc/11.2.1/toolset
module load openmpi/4.1.4/gcc-11.2.1-cuda-11.7
cd /home/mnv/Firemodels_fork/fds/Issues/PETSc
srun -N 2 -n 16 /home/mnv/Firemodels_fork/fds/Build/ompi_gnu_linux/fds_ompi_gnu_linux test.fds -pc_type gamg -mat_type aijcusparse -vec_type cuda
Thank you for the advice,
Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230822/3c93f004/attachment-0001.html>
