[petsc-users] Some questions about the directory structure
meator meator.dev at gmail.com
Mon Aug 21 13:09:10 CDT 2023
Thanks for your reply! It has clarified many things I was unsure about.
On 8/21/23 19:54, Satish Balay wrote:
>> What are the contents of the /usr/lib/petsc directory in destdir for? This
>> directory has two subrirectories: bin and conf. Why is the bin/ directory in
>> lib/? lib/ should be for libraries.
> balay at p1 /home/balay
> $ find /usr/lib -name bin
> /usr/lib/debug/bin
> /usr/lib/debug/usr/bin
> /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.372.b07-6.fc38.x86_64/jre/bin
> /usr/lib/jvm/java-17-openjdk-17.0.8.0.7-1.fc38.x86_64/bin
> /usr/lib/jvm/java-11-openjdk-11.0.20.0.8-1.fc38.x86_64/bin
> $ find /usr/lib64 -name bin
> /usr/lib64/qt5/bin
> /usr/lib64/R/bin
I see.
>> The /usr/lib/petsc/conf directory seems to be related to the build process. Is
>> that correct?
> These have makefiles that can be included from user/application makefiles - to get compile/link working seamlessly.
Thanks for the feedback. I would have removed this directory otherwise.
>> /usr/share/petsc looks like it contains additional info useful to the
>> developers, therefore it should be in a -devel subpackage.
>> I see that the docs directory contains .buildinfo. Does this directory contain
>> additional build artifacts (that should be removed)?
> I guess some of these files should be excluded from tarball.
It might be just this file alone. But I'm not familiar with the
documentation generator software you're using so I have asked just to be
sure.
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230821/c5de39ba/attachment.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230821/c5de39ba/attachment.sig>
