[petsc-users] CUDA error trying to run a job with two mpi processes and 1 GPU
Vanella, Marcos (Fed) marcos.vanella at nist.gov
Tue Aug 15 09:57:31 CDT 2023
I see. I'm trying to get hypre (or any preconditioner) to run on the GPU and this is what is giving me issues. I can run cases with the CPU only version of PETSc without problems.
I tried running the job both in an interactive session and through slurm with the --with-cuda configured PETSc and passing the cuda vector flag at runtime like you did:
$ mpirun -n 2 /home/mnv/Firemodels_fork/fds/Build/ompi_gnu_linux_db/fds_ompi_gnu_linux_db test.fds -log_view -mat_type aijcusparse -vec_type cuda
and still get the error. So provided we both configured PETSc in the same way I'm thinking there is something going on with the configuration of my cluster.
Even without defining the "-mat_type aijcusparse -vec_type cuda" flags in the submission line I get the same "parallel_for failed: cudaErrorInvalidConfiguration: invalid configuration argument" error instead of what you see ("You need to enable PETSc device support").
I noted you use a Kokkos version of PETSc, is this related to your development?
Thank you,
Marcos
Sent: Tuesday, August 15, 2023 9:59 AM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Satish Balay <balay at mcs.anl.gov>; McDermott, Randall J. (Fed) <randall.mcdermott at nist.gov>
Subject: Re: [petsc-users] CUDA error trying to run a job with two mpi processes and 1 GPU
On Tue, Aug 15, 2023 at 8:55 AM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, thank you for your observations and taking the time to look at this. So if I don't configure PETSc with the --with-cuda flag and still select HYPRE as the preconditioner, I still get Hypre to run on the GPU? I thought I needed that flag to get the solvers to run on the V100 card.
No, to have hypre run on CPU, you need to configure petsc/hypre without  --with-cuda; otherwise, you need --with-cuda and have to always use flags like -vec_type cuda etc.  I admit this is not user-friendly and should be fixed by petsc and hypre developers.
I'll remove the hardwired paths on the link flags, thanks for that!
Marcos
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Sent: Monday, August 14, 2023 7:01 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>; McDermott, Randall J. (Fed) <randall.mcdermott at nist.gov<mailto:randall.mcdermott at nist.gov>>
Marcos,
 These are my findings. I successfully ran the test in the end.
$ mpirun -n 2 ./fds_ompi_gnu_linux_db test.fds -log_view
 Starting FDS ...
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: HYPRE_MEMORY_DEVICE expects a device vector. You need to enable PETSc device support, for example, in some cases, -vec_type cuda
Now I get why you met errors with "CPU runs".  You configured and built hypre with petsc.  Since you added --with-cuda, petsc would configure hypre with its GPU support. However, hypre has a limit/shortcoming that if it is configured with GPU support, you must pass GPU vectors to it. Thus the error. In other words, if you remove --with-cuda, you should be able to run above command.
$ mpirun -n 2 ./fds_ompi_gnu_linux_db test.fds -log_view -mat_type aijcusparse -vec_type cuda
 Starting FDS ...
 MPI Process      0 started on hong-gce-workstation
 MPI Process      1 started on hong-gce-workstation
 Reading FDS input file ...
At line 3014 of file ../../Source/read.f90
Fortran runtime warning: An array temporary was created
At line 3461 of file ../../Source/read.f90
WARNING: SPEC REAC_FUEL is not in the table of pre-defined species. Any unassigned SPEC variables in the input were assigned the properties of nitrogen.
 Fire Dynamics Simulator
STOP: FDS completed successfully (CHID: test)
I guess there were link problems in your makefile.  Actually, in the first try, I failed with
mpifort -m64 -O0 -std=f2018 -ggdb -Wall -Wunused-parameter -Wcharacter-truncation -Wno-target-lifetime -fcheck=all -fbacktrace -ffpe-trap=invalid,zero,overflow -frecursive -ffpe-summary=none -fall-intrinsics -fbounds-check -cpp -DGITHASH_PP=\"FDS6.7.0-11263-g04d5df7-FireX\" -DGITDATE_PP=\""Mon Aug 14 17:07:20 2023 -0400\"" -DBUILDDATE_PP=\""Aug 14, 2023  17:32:12\"" -DCOMPVER_PP=\""Gnu gfortran 11.4.0-1ubuntu1~22.04)"\"   -DWITH_PETSC -I"/home/jczhang/petsc/include/" -I"/home/jczhang/petsc/arch-kokkos-dbg/include"  -fopenmp -o fds_ompi_gnu_linux_db prec.o cons.o prop.o devc.o type.o data.o mesh.o func.o gsmv.o smvv.o rcal.o turb.o soot.o pois.o geom.o ccib.o radi.o part.o vege.o ctrl.o hvac.o mass.o imkl.o wall.o fire.o velo.o pres.o init.o dump.o read.o divg.o main.o  -Wl,-rpath -Wl,/apps/ubuntu-20.04.2/openmpi/4.1.1/gcc-9.3.0/lib -Wl,--enable-new-dtags -L/apps/ubuntu-20.04.2/openmpi/4.1.1/gcc-9.3.0/lib  -lmpi -Wl,-rpath,/home/jczhang/petsc/arch-kokkos-dbg/lib -L/home/jczhang/petsc/arch-kokkos-dbg/lib -lpetsc -ldl -lspqr -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lHYPRE  -Wl,-rpath,/usr/local/cuda/lib64 -L/usr/local/cuda/lib64 -L/usr/local/cuda/lib64/stubs -lcudart -lnvToolsExt -lcufft -lcublas -lcusparse -lcusolver -lcurand -lcuda -lflapack -lfblas -lstdc++ -L/usr/lib64 -lX11
/usr/bin/ld: cannot find -lflapack: No such file or directory
/usr/bin/ld: cannot find -lfblas: No such file or directory
collect2: error: ld returned 1 exit status
make: *** [../makefile:357: ompi_gnu_linux_db] Error 1
That is because you hardwired many link flags in your fds/Build/makefile. Then I changed LFLAGS_PETSC to
   LFLAGS_PETSC = -Wl,-rpath,${PETSC_DIR}/${PETSC_ARCH}/lib -L${PETSC_DIR}/${PETSC_ARCH}/lib -lpetsc
and everything worked.  Could you also try it?
--Junchao Zhang
On Mon, Aug 14, 2023 at 4:53 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Attached is the test.fds test case. Thanks!
From: Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>>
Sent: Monday, August 14, 2023 5:45 PM
To: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
Cc: McDermott, Randall J. (Fed) <randall.mcdermott at nist.gov<mailto:randall.mcdermott at nist.gov>>
All right Junchao, thank you for looking at this!
So, I checked out the /dir_to_petsc/petsc/main branch, setup the petsc env variables:
# PETSc dir and arch, set MYSYS to nisaba dor FDS:
export PETSC_DIR=/dir_to_petsc/petsc
export PETSC_ARCH=arch-linux-c-dbg
export MYSYSTEM=nisaba
 and configured the library with:
$ ./Configure COPTFLAGS="-g -O2" CXXOPTFLAGS="-g -O2" FOPTFLAGS="-g -O2" FCOPTFLAGS="-g -O2" CUDAOPTFLAGS="-g -O2" --with-debugging=yes --with-shared-libraries=0 --download-suitesparse --download-hypre --download-fblaslapack --with-cuda
Then made and checked the PETSc build.
Then for FDS:
  1.  Clone my fds repo in a ~/fds_dir you make, and checkout the FireX branch:
$ cd ~/fds_dir
$ git clone https://github.com/marcosvanella/fds.git
$ cd fds
$ git checkout FireX
  1.  With PETSC_DIR, PETSC_ARCH and MYSYSTEM=nisaba defined, compile a debug target for fds (this is with cuda enabled openmpi compiled with gcc, in my case gcc-11.2 + PETSc):
$ cd Build/ompi_gnu_linux_db
$./make_fds.sh
You should see compilation lines like this, with the WITH_PETSC Preprocessor variable being defined:
Building ompi_gnu_linux_db
mpifort -c -m64 -O0 -std=f2018 -ggdb -Wall -Wunused-parameter -Wcharacter-truncation -Wno-target-lifetime -fcheck=all -fbacktrace -ffpe-trap=invalid,zero,overflow -frecursive -ffpe-summary=none -fall-intrinsics -fbounds-check -cpp -DGITHASH_PP=\"FDS-6.8.0-556-g04d5df7-dirty-FireX\" -DGITDATE_PP=\""Mon Aug 14 17:07:20 2023 -0400\"" -DBUILDDATE_PP=\""Aug 14, 2023  17:34:36\"" -DCOMPVER_PP=\""Gnu gfortran 11.2.1"\"   -DWITH_PETSC -I"/home/mnv/Software/petsc/include/" -I"/home/mnv/Software/petsc/arch-linux-c-dbg/include"  ../../Source/prec.f90
mpifort -c -m64 -O0 -std=f2018 -ggdb -Wall -Wunused-parameter -Wcharacter-truncation -Wno-target-lifetime -fcheck=all -fbacktrace -ffpe-trap=invalid,zero,overflow -frecursive -ffpe-summary=none -fall-intrinsics -fbounds-check -cpp -DGITHASH_PP=\"FDS-6.8.0-556-g04d5df7-dirty-FireX\" -DGITDATE_PP=\""Mon Aug 14 17:07:20 2023 -0400\"" -DBUILDDATE_PP=\""Aug 14, 2023  17:34:36\"" -DCOMPVER_PP=\""Gnu gfortran 11.2.1"\"   -DWITH_PETSC -I"/home/mnv/Software/petsc/include/" -I"/home/mnv/Software/petsc/arch-linux-c-dbg/include"  ../../Source/cons.f90
mpifort -c -m64 -O0 -std=f2018 -ggdb -Wall -Wunused-parameter -Wcharacter-truncation -Wno-target-lifetime -fcheck=all -fbacktrace -ffpe-trap=invalid,zero,overflow -frecursive -ffpe-summary=none -fall-intrinsics -fbounds-check -cpp -DGITHASH_PP=\"FDS-6.8.0-556-g04d5df7-dirty-FireX\" -DGITDATE_PP=\""Mon Aug 14 17:07:20 2023 -0400\"" -DBUILDDATE_PP=\""Aug 14, 2023  17:34:36\"" -DCOMPVER_PP=\""Gnu gfortran 11.2.1"\"   -DWITH_PETSC -I"/home/mnv/Software/petsc/include/" -I"/home/mnv/Software/petsc/arch-linux-c-dbg/include"  ../../Source/prop.f90
mpifort -c -m64 -O0 -std=f2018 -ggdb -Wall -Wunused-parameter -Wcharacter-truncation -Wno-target-lifetime -fcheck=all -fbacktrace -ffpe-trap=invalid,zero,overflow -frecursive -ffpe-summary=none -fall-intrinsics -fbounds-check -cpp -DGITHASH_PP=\"FDS-6.8.0-556-g04d5df7-dirty-FireX\" -DGITDATE_PP=\""Mon Aug 14 17:07:20 2023 -0400\"" -DBUILDDATE_PP=\""Aug 14, 2023  17:34:36\"" -DCOMPVER_PP=\""Gnu gfortran 11.2.1"\"   -DWITH_PETSC -I"/home/mnv/Software/petsc/include/" -I"/home/mnv/Software/petsc/arch-linux-c-dbg/include"  ../../Source/devc.f90
If you are compiling on a Power9 node you might come across this error right off the bat:
../../Source/prec.f90:34:8:
   34 | REAL(QB), PARAMETER :: TWO_EPSILON_QB=2._QB*EPSILON(1._QB) !< A very small number 16 byte accuracy
      |        1
Error: Kind -3 not supported for type REAL at (1)
which means for some reason gcc in the Power9 does not like quad precision definition in this manner. A way around it is to add the intrinsic Fortran2008 module iso_fortran_env:
use, intrinsic :: iso_fortran_env
in the fds/Source/prec.f90 file and change the quad precision denominator to:
INTEGER, PARAMETER :: QB = REAL128
in there. We are investigating the reason why this is happening. This is not related to Petsc in the code, everything related to PETSc calls is integers and double precision reals.
After the code compiles you get the executable in ~/fds_dir/fds/Build/ompi_gnu_linux_db/fds_ompi_gnu_linux_db
With which you can run the attached 2 mesh case as:
$ mpirun -n 2 ~/fds_dir/fds/Build/ompi_gnu_linux_db/fds_ompi_gnu_linux_db test.fds -log_view
and change PETSc ksp, pc runtime flags, etc. The default is PCG + HYPRE which is what I was testing in CPU. This is the result I get from the previous submission in an interactive job in Enki (similar with batch submissions, gmres ksp, gamg pc):
 Starting FDS ...
 MPI Process      1 started on enki11.adlp
 MPI Process      0 started on enki11.adlp
WARNING: DEVC Device is not within any mesh.
 Current Date     : August 14, 2023  17:26:22
 Revision         : FDS6.7.0-11263-g04d5df7-dirty-FireX
 Revision Date    : Mon Aug 14 17:07:20 2023 -0400
 Compiler         : Gnu gfortran 11.2.1
 Compilation Date : Aug 14, 2023  17:11:05
 MPI Enabled;    Number of MPI Processes:       2
 OpenMP Enabled; Number of OpenMP Threads:      1
 MPI version: 3.1
 MPI library version: Open MPI v4.1.4, package: Open MPI xng4 at enki01.adlp Distribution, ident: 4.1.4, repo rev: v4.1.4, May 26, 2022
 Job TITLE        :
 Job ID string    : test
terminate called after throwing an instance of 'thrust::system::system_error'
  what():  parallel_for failed: cudaErrorInvalidConfiguration: invalid configuration argument
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
#0  0x2000397fcd8f in ???
#1  0x2000397fb657 in ???
#2  0x2000000604d7 in ???
#3  0x200039cb9628 in ???
#4  0x200039c93eb3 in ???
#5  0x200039364a97 in ???
#6  0x20003935f6d3 in ???
#7  0x20003935f78f in ???
#8  0x20003935fc6b in ???
#9  0x11ec67db in _ZN6thrust8cuda_cub14throw_on_errorE9cudaErrorPKc
      at /usr/local/cuda-11.7/include/thrust/system/cuda/detail/util.h:225
#10  0x11ec67db in _ZN6thrust8cuda_cub20uninitialized_fill_nINS0_3tagENS_10device_ptrIiEEmiEET0_RNS0_16execution_policyIT_EES5_T1_RKT2_
      at /usr/local/cuda-11.7/include/thrust/system/cuda/detail/uninitialized_fill.h:88
#11  0x11efc7e3 in _ZN6thrust20uninitialized_fill_nINS_8cuda_cub3tagENS_10device_ptrIiEEmiEET0_RKNS_6detail21execution_policy_baseIT_EES5_T1_RKT2_
      at /usr/local/cuda-11.7/include/thrust/detail/uninitialized_fill.inl:55
#12  0x11efc7e3 in _ZN6thrust6detail23allocator_traits_detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEENS0_10disable_ifIXsrNS1_37needs_default_construct_via_allocatorIT_NS0_15pointer_elementIT0_E4typeEEE5valueEvE4typeERS9_SB_T1_
      at /usr/local/cuda-11.7/include/thrust/detail/allocator/default_construct_range.inl:93
#13  0x11efc7e3 in _ZN6thrust6detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEEvRT_T0_T1_
      at /usr/local/cuda-11.7/include/thrust/detail/allocator/default_construct_range.inl:104
#14  0x11efc7e3 in _ZN6thrust6detail18contiguous_storageIiNS_16device_allocatorIiEEE19default_construct_nENS0_15normal_iteratorINS_10device_ptrIiEEEEm
      at /usr/local/cuda-11.7/include/thrust/detail/contiguous_storage.inl:254
#15  0x11efc7e3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
      at /usr/local/cuda-11.7/include/thrust/detail/vector_base.inl:220
#16  0x11efc7e3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
      at /usr/local/cuda-11.7/include/thrust/detail/vector_base.inl:213
#17  0x11efc7e3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEEC2Em
      at /usr/local/cuda-11.7/include/thrust/detail/vector_base.inl:65
#18  0x11eda3c7 in _ZN6thrust13device_vectorIiNS_16device_allocatorIiEEEC4Em
      at /usr/local/cuda-11.7/include/thrust/device_vector.h:88
#19  0x11eda3c7 in MatSeqAIJCUSPARSECopyToGPU
      at /home/mnv/Software/petsc/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu:2488<http://aijcusparse.cu:2488/>
#20  0x11edc6b7 in MatSetPreallocationCOO_SeqAIJCUSPARSE
      at /home/mnv/Software/petsc/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu:4300<http://aijcusparse.cu:4300/>
#21  0x11e91bc7 in MatSetPreallocationCOO
      at /home/mnv/Software/petsc/src/mat/utils/gcreate.c:650
#22  0x1316d5ab in MatConvert_AIJ_HYPRE
      at /home/mnv/Software/petsc/src/mat/impls/hypre/mhypre.c:648
#23  0x11e3b463 in MatConvert
      at /home/mnv/Software/petsc/src/mat/interface/matrix.c:4428
#24  0x14072213 in PCSetUp_HYPRE
      at /home/mnv/Software/petsc/src/ksp/pc/impls/hypre/hypre.c:254
#25  0x1276a9db in PCSetUp
      at /home/mnv/Software/petsc/src/ksp/pc/interface/precon.c:1069
#26  0x127d923b in KSPSetUp
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:415
#27  0x127e033f in KSPSolve_Private
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:836
#28  0x127e6f07 in KSPSolve
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:1082
#29  0x1280d70b in kspsolve_
      at /home/mnv/Software/petsc/arch-linux-c-dbg/src/ksp/ksp/interface/ftn-auto/itfuncf.c:335
#30  0x1140858f in __globmat_solver_MOD_glmat_solver
      at ../../Source/pres.f90:3130
#31  0x119faddf in pressure_iteration_scheme
      at ../../Source/main.f90:1449
#32  0x1196c15f in fds
      at ../../Source/main.f90:688
#33  0x11a126f3 in main
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 1 with PID 3028180 on node enki11 exited on signal 6 (Aborted).
Seems the issue stems from the call to KSPSOLVE, line 3130 in fds/Source/pres.f90.
Well, thank you for taking the time to look at this and also let me know if these threads should be moved to the issue tracker, or other venue.
Best,
Marcos
Sent: Monday, August 14, 2023 4:37 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>>; PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
I don't see a problem in the matrix assembly.
If you point me to your repo and show me how to build it, I can try to reproduce.
--Junchao Zhang
On Mon, Aug 14, 2023 at 2:53 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, I've tried for my case using the -ksp_type gmres and -pc_type asm with -mat_type aijcusparse -sub_pc_factor_mat_solver_type cusparse as (I understand) is done in the ex60. The error is always the same, so it seems it is not related to ksp,pc. Indeed it seems to happen when trying to offload the Matrix to the GPU:
#9  0x11ec769b in _ZN6thrust8cuda_cub14throw_on_errorE9cudaErrorPKc
#10  0x11ec769b in _ZN6thrust8cuda_cub20uninitialized_fill_nINS0_3tagENS_10device_ptrIiEEmiEET0_RNS0_16execution_policyIT_EES5_T1_RKT2_
#11  0x11efd6a3 in _ZN6thrust20uninitialized_fill_nINS_8cuda_cub3tagENS_10device_ptrIiEEmiEET0_RKNS_6detail21execution_policy_baseIT_EES5_T1_RKT2_
#12  0x11efd6a3 in _ZN6thrust6detail23allocator_traits_detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEENS0_10disable_ifIXsrNS1_37needs_default_construct_via_allocatorIT_NS0_15pointer_elementIT0_E4typeEEE5valueEvE4typeERS9_SB_T1_
#13  0x11efd6a3 in _ZN6thrust6detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEEvRT_T0_T1_
#14  0x11efd6a3 in _ZN6thrust6detail18contiguous_storageIiNS_16device_allocatorIiEEE19default_construct_nENS0_15normal_iteratorINS_10device_ptrIiEEEEm
#15  0x11efd6a3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
#16  0x11efd6a3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
#17  0x11efd6a3 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEEC2Em
#18  0x11edb287 in _ZN6thrust13device_vectorIiNS_16device_allocatorIiEEEC4Em
#19  0x11edb287 in MatSeqAIJCUSPARSECopyToGPU
#20  0x11edfd1b in MatSeqAIJCUSPARSEGetIJ
This is the piece of fortran code I have doing this within my Poisson solver:
! Create Parallel PETSc Sparse matrix for this ZSL: Set diag/off diag blocks nonzeros per row to 5.
CALL MATCREATEAIJ(MPI_COMM_WORLD,ZSL%NUNKH_LOCAL,ZSL%NUNKH_LOCAL,ZSL%NUNKH_TOTAL,ZSL%NUNKH_TOTAL,&
                  7,PETSC_NULL_INTEGER,7,PETSC_NULL_INTEGER,ZSL%PETSC_ZS%A_H,PETSC_IERR)
CALL MATSETFROMOPTIONS(ZSL%PETSC_ZS%A_H,PETSC_IERR)
DO IROW=1,ZSL%NUNKH_LOCAL
   DO JCOL=1,ZSL%NNZ_D_MAT_H(IROW)
      ! PETSC expects zero based indexes.1,Global I position (zero base),1,Global J position (zero base)
      CALL MATSETVALUES(ZSL%PETSC_ZS%A_H,1,ZSL%UNKH_IND(NM_START)+IROW-1,1,ZSL%JD_MAT_H(JCOL,IROW)-1,&
                        ZSL%D_MAT_H(JCOL,IROW),INSERT_VALUES,PETSC_IERR)
   ENDDO
ENDDO
CALL MATASSEMBLYBEGIN(ZSL%PETSC_ZS%A_H, MAT_FINAL_ASSEMBLY, PETSC_IERR)
CALL MATASSEMBLYEND(ZSL%PETSC_ZS%A_H, MAT_FINAL_ASSEMBLY, PETSC_IERR)
Note that I allocate d_nz=7 and o_nz=7 per row (more than enough size), and add nonzero values one by one. I wonder if there is something related to this that the copying to GPU does not like.
Marcos
Sent: Monday, August 14, 2023 3:24 PM
Cc: PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
Yeah, it looks like ex60 was run correctly.
Double check your code again and if you still run into errors, we can try to reproduce on our end.
Thanks.
--Junchao Zhang
On Mon, Aug 14, 2023 at 1:05 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, I compiled and run ex60 through slurm in our Enki system. The batch script for slurm submission, ex60.log and gpu stats files are attached.
Nothing stands out as wrong to me but please have a look.
I'll revisit running the original 2 MPI process + 1 GPU Poisson problem.
Thanks!
Marcos
Sent: Friday, August 11, 2023 5:52 PM
Before digging into the details, could you try to run src/ksp/ksp/tests/ex60.c to make sure the environment is ok.
The comment at the end shows how to run it
   test:
      requires: cuda
      suffix: 1_cuda
      nsize: 4
      args: -ksp_view -mat_type aijcusparse -sub_pc_factor_mat_solver_type cusparse
--Junchao Zhang
On Fri, Aug 11, 2023 at 4:36 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, thank you for the info. I compiled the main branch of PETSc in another machine that has the  openmpi/4.1.4/gcc-11.2.1-cuda-11.7 toolchain and don't see the fortran compilation error. It might have been related to gcc-9.3.
I tried the case again, 2 CPUs and one GPU and get this error now:
#9  0x11ec425b in _ZN6thrust8cuda_cub14throw_on_errorE9cudaErrorPKc
#10  0x11ec425b in _ZN6thrust8cuda_cub20uninitialized_fill_nINS0_3tagENS_10device_ptrIiEEmiEET0_RNS0_16execution_policyIT_EES5_T1_RKT2_
#11  0x11efa263 in _ZN6thrust20uninitialized_fill_nINS_8cuda_cub3tagENS_10device_ptrIiEEmiEET0_RKNS_6detail21execution_policy_baseIT_EES5_T1_RKT2_
#12  0x11efa263 in _ZN6thrust6detail23allocator_traits_detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEENS0_10disable_ifIXsrNS1_37needs_default_construct_via_allocatorIT_NS0_15pointer_elementIT0_E4typeEEE5valueEvE4typeERS9_SB_T1_
#13  0x11efa263 in _ZN6thrust6detail23default_construct_rangeINS_16device_allocatorIiEENS_10device_ptrIiEEmEEvRT_T0_T1_
#14  0x11efa263 in _ZN6thrust6detail18contiguous_storageIiNS_16device_allocatorIiEEE19default_construct_nENS0_15normal_iteratorINS_10device_ptrIiEEEEm
#15  0x11efa263 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
#16  0x11efa263 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEE12default_initEm
#17  0x11efa263 in _ZN6thrust6detail11vector_baseIiNS_16device_allocatorIiEEEC2Em
#18  0x11ed7e47 in _ZN6thrust13device_vectorIiNS_16device_allocatorIiEEEC4Em
#19  0x11ed7e47 in MatSeqAIJCUSPARSECopyToGPU
#20  0x11eef623 in MatSeqAIJCUSPARSEMergeMats
      at /home/mnv/Software/petsc/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu:4696<http://aijcusparse.cu:4696/>
#21  0x11f0682b in MatMPIAIJGetLocalMatMerge_MPIAIJCUSPARSE
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu:251<http://mpiaijcusparse.cu:251/>
#22  0x133f141f in MatMPIAIJGetLocalMatMerge
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpiaij.c:5342
#23  0x133fe9cb in MatProductSymbolic_MPIAIJBACKEND
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpiaij.c:7368
#24  0x1377e1df in MatProductSymbolic
      at /home/mnv/Software/petsc/src/mat/interface/matproduct.c:795
#25  0x11e4dd1f in MatPtAP
      at /home/mnv/Software/petsc/src/mat/interface/matrix.c:9934
#26  0x130d792f in MatCoarsenApply_MISK_private
      at /home/mnv/Software/petsc/src/mat/coarsen/impls/misk/misk.c:283
#27  0x130db89b in MatCoarsenApply_MISK
      at /home/mnv/Software/petsc/src/mat/coarsen/impls/misk/misk.c:368
#28  0x130bf5a3 in MatCoarsenApply
      at /home/mnv/Software/petsc/src/mat/coarsen/coarsen.c:97
#29  0x141518ff in PCGAMGCoarsen_AGG
      at /home/mnv/Software/petsc/src/ksp/pc/impls/gamg/agg.c:524
#30  0x13b3a43f in PCSetUp_GAMG
      at /home/mnv/Software/petsc/src/ksp/pc/impls/gamg/gamg.c:631
#31  0x1276845b in PCSetUp
#32  0x127d6cbb in KSPSetUp
#33  0x127dddbf in KSPSolve_Private
#34  0x127e4987 in KSPSolve
#35  0x1280b18b in kspsolve_
#36  0x1140945f in __globmat_solver_MOD_glmat_solver
      at ../../Source/pres.f90:3128
#37  0x119f8853 in pressure_iteration_scheme
#38  0x11969bd3 in fds
#39  0x11a10167 in main
srun: error: enki12: tasks 0-1: Aborted (core dumped)
This was the slurm submission script in this case:
#!/bin/bash
# ../../Utilities/Scripts/qfds.sh -p 2  -T db -d test.fds
#SBATCH -J test
#SBATCH -e /home/mnv/Firemodels_fork/fds/Issues/PETSc/test.err
#SBATCH -o /home/mnv/Firemodels_fork/fds/Issues/PETSc/test.log
#SBATCH --partition=debug
#SBATCH --ntasks=2
#SBATCH --nodes=1
#SBATCH --cpus-per-task=1
#SBATCH --ntasks-per-node=2
#SBATCH --time=01:00:00
#SBATCH --gres=gpu:1
export OMP_NUM_THREADS=1
# PETSc dir and arch:
export PETSC_DIR=/home/mnv/Software/petsc
# SYSTEM name:
export MYSYSTEM=enki
# modules
module load cuda/11.7
module load gcc/11.2.1/toolset
module load openmpi/4.1.4/gcc-11.2.1-cuda-11.7
cd /home/mnv/Firemodels_fork/fds/Issues/PETSc
srun -N 1 -n 2 --ntasks-per-node 2 --mpi=pmi2 /home/mnv/Firemodels_fork/fds/Build/ompi_gnu_linux_db/fds_ompi_gnu_linux_db test.fds -vec_type mpicuda -mat_type mpiaijcusparse -pc_type gamg
The configure.log for the PETSc build is attached.  Another clue to what is happening is that even setting the matrices/vectors to be mpi (-vec_type mpi -mat_type mpiaij) and not requesting a gpu I get a GPU warning :
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: GPU error
[1]PETSC ERROR: Cannot lazily initialize PetscDevice: cuda error 100 (cudaErrorNoDevice) : no CUDA-capable device is detected
[1]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: GPU error
[0]PETSC ERROR: Cannot lazily initialize PetscDevice: cuda error 100 (cudaErrorNoDevice) : no CUDA-capable device is detected
[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR:   Option left: name:-pc_type value: gamg source: command line
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR:   Option left: name:-pc_type value: gamg source: command line
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.19.4-946-g590ad0f52ad  GIT Date: 2023-08-11 15:13:02 +0000
[0]PETSC ERROR: Petsc Development GIT revision: v3.19.4-946-g590ad0f52ad  GIT Date: 2023-08-11 15:13:02 +0000
[0]PETSC ERROR: /home/mnv/Firemodels_fork/fds/Build/ompi_gnu_linux_db/fds_ompi_gnu_linux_db on a arch-linux-c-dbg named enki11.adlp by mnv Fri Aug 11 17:04:55 2023
[0]PETSC ERROR: Configure options COPTFLAGS="-g -O2" CXXOPTFLAGS="-g -O2" FOPTFLAGS="-g -O2" FCOPTFLAGS="-g -O2" CUDAOPTFLAGS="-g -O2" --with-debugging=yes --with-shared-libraries=0 --download-suitesparse --download-hypre --download-fblaslapack --with-cuda
I would have expected not to see GPU errors being printed out, given I did not request cuda matrix/vectors. The case run anyways, I assume it defaulted to the CPU solver.
Let me know if you have any ideas as to what is happening. Thanks,
Marcos
Sent: Friday, August 11, 2023 3:35 PM
To: Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>>; PETSc users list <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
Marcos,
  We do not have good petsc/gpu documentation, but see https://petsc.org/main/faq/#doc-faq-gpuhowto, and also search "requires: cuda" in petsc tests and you will find examples using GPU.
  For the Fortran compile errors, attach your configure.log and Satish (Cc'ed) or others should know how to fix them.
  Thanks.
--Junchao Zhang
On Fri, Aug 11, 2023 at 2:22 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, thanks for the explanation. Is there some development documentation on the GPU work? I'm interested learning about it.
I checked out the main branch and configured petsc. when compiling with gcc/gfortran I come across this error:
      CUDAC arch-linux-c-opt/obj/src/mat/impls/aij/seq/seqcusparse/aijcusparse.o
  CUDAC.dep arch-linux-c-opt/obj/src/mat/impls/aij/seq/seqcusparse/aijcusparse.o
         FC arch-linux-c-opt/obj/src/ksp/f90-mod/petsckspdefmod.o
         FC arch-linux-c-opt/obj/src/ksp/f90-mod/petscpcmod.o
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:37:61:
   37 |       subroutine PCASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,z)
      |                                                             1
Error: Symbol ‘pcasmcreatesubdomains2d’ at (1) already has an explicit interface
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:38:13:
   38 |        import tIS
      |             1
Error: IMPORT statement at (1) only permitted in an INTERFACE body
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:39:80:
   39 |        PetscInt a ! PetscInt
      |        1
Error: Unexpected data declaration statement in INTERFACE block at (1)
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:40:80:
   40 |        PetscInt b ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:41:80:
   41 |        PetscInt c ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:42:80:
   42 |        PetscInt d ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:43:80:
   43 |        PetscInt e ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:44:80:
   44 |        PetscInt f ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:45:80:
   45 |        PetscInt g ! PetscInt
      |        1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:46:30:
   46 |        IS h ! IS
      |                              1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:47:30:
   47 |        IS i ! IS
      |                              1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:48:43:
   48 |        PetscErrorCode z
      |                                           1
/home/mnv/Software/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90:49:10:
   49 |        end subroutine PCASMCreateSubdomains2D
      |          1
Error: Expecting END INTERFACE statement at (1)
make[3]: *** [gmakefile:225: arch-linux-c-opt/obj/src/ksp/f90-mod/petscpcmod.o] Error 1
make[3]: *** Waiting for unfinished jobs....
         CC arch-linux-c-opt/obj/src/tao/leastsquares/impls/pounders/pounders.o
         CC arch-linux-c-opt/obj/src/ksp/pc/impls/bddc/bddcprivate.o
      CUDAC arch-linux-c-opt/obj/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.o
  CUDAC.dep arch-linux-c-opt/obj/src/vec/vec/impls/seq/cupm/cuda/vecseqcupm.o
make[3]: Leaving directory '/home/mnv/Software/petsc'
make[2]: *** [/home/mnv/Software/petsc/lib/petsc/conf/rules.doc:28: libs] Error 2
make[2]: Leaving directory '/home/mnv/Software/petsc'
**************************ERROR*************************************
  Error during compile, check arch-linux-c-opt/lib/petsc/conf/make.log
  Send it and arch-linux-c-opt/lib/petsc/conf/configure.log to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>
make[1]: *** [makefile:45: all] Error 1
make: *** [GNUmakefile:9: all] Error 2
Sent: Friday, August 11, 2023 3:04 PM
Hi, Macros,
  I saw MatSetPreallocationCOO_MPIAIJCUSPARSE_Basic() in the error stack.  We recently refactored the COO code and got rid of that function.  So could you try petsc/main?
  We map MPI processes to GPUs in a round-robin fashion. We query the number of visible CUDA devices (g), and assign the device (rank%g) to the MPI process (rank).   In that sense, the work distribution is totally determined by your MPI work partition (i.e, yourself).
  On clusters, this MPI process to GPU binding is usually done by the job scheduler like slurm.  You need to check your cluster's users' guide to see how to bind MPI processes to GPUs. If the job scheduler has done that, the number of visible CUDA devices to a process might just appear to be 1, making petsc's own mapping void.
   Thanks.
--Junchao Zhang
On Fri, Aug 11, 2023 at 12:43 PM Vanella, Marcos (Fed) <marcos.vanella at nist.gov<mailto:marcos.vanella at nist.gov>> wrote:
Hi Junchao, thank you for replying. I compiled petsc in debug mode and this is what I get for the case:
  what():  merge_sort: failed to synchronize: cudaErrorIllegalAddress: an illegal memory access was encountered
#0  0x15264731ead0 in ???
#1  0x15264731dc35 in ???
#2  0x15264711551f in ???
#3  0x152647169a7c in ???
#4  0x152647115475 in ???
#5  0x1526470fb7f2 in ???
#6  0x152647678bbd in ???
#7  0x15264768424b in ???
#8  0x1526476842b6 in ???
#9  0x152647684517 in ???
#10  0x55bb46342ebb in _ZN6thrust8cuda_cub14throw_on_errorE9cudaErrorPKc
      at /usr/local/cuda/include/thrust/system/cuda/detail/util.h:224
#11  0x55bb46342ebb in _ZN6thrust8cuda_cub12__merge_sort10merge_sortINS_6detail17integral_constantIbLb1EEENS4_IbLb0EEENS0_3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEESB_NS_9null_typeESC_SC_SC_SC_SC_SC_SC_EEEENS3_15normal_iteratorISB_EE9IJCompareEEvRNS0_16execution_policyIT1_EET2_SM_T3_T4_
      at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1316
#12  0x55bb46342ebb in _ZN6thrust8cuda_cub12__smart_sort10smart_sortINS_6detail17integral_constantIbLb1EEENS4_IbLb0EEENS0_16execution_policyINS0_3tagEEENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEESD_NS_9null_typeESE_SE_SE_SE_SE_SE_SE_EEEENS3_15normal_iteratorISD_EE9IJCompareEENS1_25enable_if_comparison_sortIT2_T4_E4typeERT1_SL_SL_T3_SM_
      at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1544
#13  0x55bb46342ebb in _ZN6thrust8cuda_cub11sort_by_keyINS0_3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES6_NS_9null_typeES7_S7_S7_S7_S7_S7_S7_EEEENS_6detail15normal_iteratorIS6_EE9IJCompareEEvRNS0_16execution_policyIT_EET0_SI_T1_T2_
      at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1669
#14  0x55bb46317bc5 in _ZN6thrust11sort_by_keyINS_8cuda_cub3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES6_NS_9null_typeES7_S7_S7_S7_S7_S7_S7_EEEENS_6detail15normal_iteratorIS6_EE9IJCompareEEvRKNSA_21execution_policy_baseIT_EET0_SJ_T1_T2_
      at /usr/local/cuda/include/thrust/detail/sort.inl:115
#15  0x55bb46317bc5 in _ZN6thrust11sort_by_keyINS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES4_NS_9null_typeES5_S5_S5_S5_S5_S5_S5_EEEENS_6detail15normal_iteratorIS4_EE9IJCompareEEvT_SC_T0_T1_
      at /usr/local/cuda/include/thrust/detail/sort.inl:305
#16  0x55bb46317bc5 in MatSetPreallocationCOO_SeqAIJCUSPARSE_Basic
      at /home/mnv/Software/petsc/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu:4452<http://aijcusparse.cu:4452/>
#17  0x55bb46c5b27c in MatSetPreallocationCOO_MPIAIJCUSPARSE_Basic
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu:173<http://mpiaijcusparse.cu:173/>
#18  0x55bb46c5b27c in MatSetPreallocationCOO_MPIAIJCUSPARSE
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu:222<http://mpiaijcusparse.cu:222/>
#19  0x55bb468e01cf in MatSetPreallocationCOO
      at /home/mnv/Software/petsc/src/mat/utils/gcreate.c:606
#20  0x55bb46b39c9b in MatProductSymbolic_MPIAIJBACKEND
      at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpiaij.c:7547
#21  0x55bb469015e5 in MatProductSymbolic
      at /home/mnv/Software/petsc/src/mat/interface/matproduct.c:803
#22  0x55bb4694ade2 in MatPtAP
      at /home/mnv/Software/petsc/src/mat/interface/matrix.c:9897
#23  0x55bb4696d3ec in MatCoarsenApply_MISK_private
#24  0x55bb4696eb67 in MatCoarsenApply_MISK
#25  0x55bb4695bd91 in MatCoarsenApply
#26  0x55bb478294d8 in PCGAMGCoarsen_AGG
#27  0x55bb471d1cb4 in PCSetUp_GAMG
#28  0x55bb464022cf in PCSetUp
      at /home/mnv/Software/petsc/src/ksp/pc/interface/precon.c:994
#29  0x55bb4718b8a7 in KSPSetUp
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:406
#30  0x55bb4718f22e in KSPSolve_Private
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:824
#31  0x55bb47192c0c in KSPSolve
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:1070
#32  0x55bb463efd35 in kspsolve_
      at /home/mnv/Software/petsc/src/ksp/ksp/interface/ftn-auto/itfuncf.c:320
#33  0x55bb45e94b32 in ???
#34  0x55bb46048044 in ???
#35  0x55bb46052ea1 in ???
#36  0x55bb45ac5f8e in ???
#37  0x1526470fcd8f in ???
#38  0x1526470fce3f in ???
#39  0x55bb45aef55d in ???
#40  0xffffffffffffffff in ???
mpirun noticed that process rank 0 with PID 1771753 on node dgx02 exited on signal 6 (Aborted).
BTW, I'm curious. If I set n MPI processes, each of them building a part of the linear system, and g GPUs, how does PETSc distribute those n pieces of system matrix and rhs in the g GPUs? Does it do some load balancing algorithm? Where can I read about this?
Thank you and best Regards, I can also point you to my code repo in GitHub if you want to take a closer look.
Best Regards,
Marcos
Sent: Friday, August 11, 2023 10:52 AM
Hi, Marcos,
  Could you build petsc in debug mode and then copy and paste the whole error stack message?
   Thanks
--Junchao Zhang
On Thu, Aug 10, 2023 at 5:51 PM Vanella, Marcos (Fed) via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi, I'm trying to run a parallel matrix vector build and linear solution with PETSc on 2 MPI processes + one V100 GPU. I tested that the matrix build and solution is successful in CPUs only. I'm using cuda 11.5 and cuda enabled openmpi and gcc 9.3. When I run the job with GPU enabled I get the following error:
I'm new to submitting jobs in slurm that also use GPU resources, so I might be doing something wrong in my submission script. This is it:
#!/bin/bash
#SBATCH -J test
#SBATCH -e /home/Issues/PETSc/test.err
#SBATCH -o /home/Issues/PETSc/test.log
#SBATCH --partition=batch
#SBATCH --ntasks=2
#SBATCH --nodes=1
module load cuda/11.5
module load openmpi/4.1.1
cd /home/Issues/PETSc
mpirun -n 2 /home/fds/Build/ompi_gnu_linux/fds_ompi_gnu_linux test.fds -vec_type mpicuda -mat_type mpiaijcusparse -pc_type gamg
If anyone has any suggestions on how o troubleshoot this please let me know.
Thanks!
Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230815/f1092232/attachment-0001.html>
