[petsc-users] eigenvalue problem involving inverse of a matrix
Jose E. Roman jroman at dsic.upv.es
Tue Aug 15 05:12:26 CDT 2023
The computed residuals are not good. Something went wrong during the eigensolve, probably within your shell matrix multiply. You should check all operations, specially within your shell matrix ops, wrapping them with PetscCall(). Otherwise, failures go unnoticed.
Regarding shift-and-invert, you cannot use PCLU with a shell matrix. You should use an iterative KSP/PC, but this will likely be very inefficient. An alternative would be to implement the shift-and-invert transformation yourself as a shell matrix.
Probably you are doing things too complicated. Instead I would try solving the generalized eigenproblem Q*y=lambda*C*y  with C=B^H*B and y=B^-1*x. You can build C explicitly with PETSc Mat-Mat product operations, see https://petsc.org/release/manualpages/Mat/MatMatMult/ - then you will be able to use STSINVERT.
Jose
> El 15 ago 2023, a las 11:21, maitri ksh <maitri.ksh at gmail.com> escribió:
> I used 'Matshell' and associated it with a custom-defined matrix-vector multiplication and used it to solve the eigenvalue problem ((((LU)^-H)*Q*(LU)^-1)*x = lmbda*x, where LU is the factor of a matrix B). I compared the eigenvalue results with matlab, however in matlab, I computed the matrix A=(B^-H)*Q*B^-1 directly and used eig(A).  Here are the results:
> petsc('eigVal.png'): (method: krylovschur)
> lmbd1 = 22.937184
> lmbd2 = -6.306099
> lmbd3 =  2.904980
> lmbd4 = 0.026435
> Matlab:
> lmbd1 = 0.0021
> lmbd2 = 0.0840
> lmbd3 = 3.9060
> lmbd4 = 22.7579
> It appears that the iterative procedure that I have adopted (in petsc) is accurate only for the largest eigenvalue. Is this correct? or is it due to some error in my code?
> Also, I tried using shift-invert-strategy ('code_snippet_sinvert.png') to see if I can get accurate non-largest eigenvalue, but it throws error ('error.png') related to 'MatSolverType mumps does not support matrix type shell', and it gives the same error message with petsc's native MATSOLVERSUPERLU. How to resolve this?
> On Mon, Aug 14, 2023 at 1:20 PM maitri ksh <maitri.ksh at gmail.com> wrote:
> got it, thanks Pierre & Jose.
> On Mon, Aug 14, 2023 at 12:50 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> See for instance ex3.c and ex9.c
> https://slepc.upv.es/documentation/current/src/eps/tutorials/index.html
> Jose
> > El 14 ago 2023, a las 10:45, Pierre Jolivet <pierre.jolivet at lip6.fr> escribió:
> >> On 14 Aug 2023, at 10:39 AM, maitri ksh <maitri.ksh at gmail.com> wrote:
> >> Hi,
> >> I need to solve an eigenvalue problem  Ax=lmbda*x, where A=(B^-H)*Q*B^-1 is a hermitian matrix, 'B^-H' refers to the hermitian of the inverse of the matrix B. Theoretically it would take around 1.8TB to explicitly compute the matrix B^-1 . A feasible way to solve this eigenvalue problem would be to use the LU factors of the B matrix instead. So the problem looks something like this:
> >> For a guess value of the (normalised) eigen-vector 'x',
> >> 1) one would require to solve two linear equations to get 'Ax',
> >>         (LU)*y=x,             solve for 'y',
> >>        ((LU)^H)*z=Q*y,   solve for 'z'
> >>     then one can follow the conventional power-iteration procedure
> >> 2) update eigenvector: x= z/||z||
> >> 3) get eigenvalue using the Rayleigh quotient
> >> 4) go to step-1 and loop through with a conditional break.
> >> Is there any example in petsc that does not require explicit declaration of the matrix 'A' (Ax=lmbda*x) and instead takes a vector 'Ax' as input for an iterative algorithm (like the one above). I looked into some of the examples of eigenvalue problems ( it's highly possible that I might have overlooked, I am new to petsc) but I couldn't find a way to circumvent the explicit declaration of matrix A.
> > You could use SLEPc with a MatShell, that’s the very purpose of this MatType.
> > Thanks,
> > Pierre
> >> Maitri
> <eigVal.png><code_snippet_sinvert.png><error.png>
