[petsc-users] performance regression with GAMG
Stephan Kramer s.kramer at imperial.ac.uk
Mon Aug 14 10:00:53 CDT 2023
Many thanks for looking into this, Mark
> My 3D tests were not that different and I see you lowered the threshold.
> Note, you can set the threshold to zero, but your test is running so much
> differently than mine there is something else going on.
> Note, the new, bad, coarsening rate of 30:1 is what we tend to shoot for
> in 3D.
> So it is not clear what the problem is.  Some questions:
> * do you have a picture of this mesh to show me?
It's just a standard hexahedral cubed sphere mesh with the refinement
level giving the number of times each of the six sides have been
subdivided: so Level_5 mean 2^5 x 2^5 squares which is extruded to 16
layers. So the total number of elements at Level_5 is 6 x 32 x 32 x 16 =
98304  hexes. And everything doubles in all 3 dimensions (so 2^3) going
to the next Level
> * what do you mean by Q1-Q2 elements?
Q2-Q1, basically Taylor hood on hexes, so (tri)quadratic for velocity
and (tri)linear for pressure
I guess you could argue we could/should just do good old geometric
multigrid instead. More generally we do use this solver configuration a
lot for tetrahedral Taylor Hood (P2-P1) in particular also for our
adaptive mesh runs - would it be worth to see if we have the same
performance issues with tetrahedral P2-P1?
> It would be nice to see if the new and old codes are similar without
> aggressive coarsening.
> This was the intended change of the major change in this time frame as you
> noticed.
> If these jobs are easy to run, could you check that the old and new
> versions are similar with "-pc_gamg_square_graph  0 ",  ( and you only need
> one time step).
> All you need to do is check that the first coarse grid has about the same
> number of equations (large).
Unfortunately we're seeing some memory errors when we use this option,
and I'm not entirely clear whether we're just running out of memory and
need to put it on a special queue.
The run with square_graph 0 using new PETSc managed to get through one
solve at level 5, and is giving the following mg levels:
         rows=174, cols=174, bs=6
           total: nonzeros=30276, allocated nonzeros=30276
           rows=2106, cols=2106, bs=6
           total: nonzeros=4238532, allocated nonzeros=4238532
           rows=21828, cols=21828, bs=6
           total: nonzeros=62588232, allocated nonzeros=62588232
           rows=589824, cols=589824, bs=6
           total: nonzeros=1082528928, allocated nonzeros=1082528928
           rows=2433222, cols=2433222, bs=3
           total: nonzeros=456526098, allocated nonzeros=456526098
comparing with square_graph 100 with new PETSc
           rows=96, cols=96, bs=6
           total: nonzeros=9216, allocated nonzeros=9216
           rows=1440, cols=1440, bs=6
           total: nonzeros=647856, allocated nonzeros=647856
           rows=97242, cols=97242, bs=6
           total: nonzeros=65656836, allocated nonzeros=65656836
and old PETSc with square_graph 100
           rows=90, cols=90, bs=6
           total: nonzeros=8100, allocated nonzeros=8100
           rows=1872, cols=1872, bs=6
           total: nonzeros=1234080, allocated nonzeros=1234080
           rows=47652, cols=47652, bs=6
           total: nonzeros=23343264, allocated nonzeros=23343264
Unfortunately old PETSc with square_graph 0 did not complete a single
solve before giving the memory error
> BTW, I am starting to think I should add the old method back as an option.
> I did not think this change would cause large differences.
Yes, I think that would be much appreciated. Let us know if we can do
any testing
Best wishes
Stephan
> Thanks,
> Mark
>> Note that we are providing the rigid body near nullspace,
>> hence the bs=3 to bs=6.
>> We have tried different values for the gamg_threshold but it doesn't
>> really seem to significantly alter the coarsening amount in that first
>> step.
>> Do you have any suggestions for further things we should try/look at?
>> Any feedback would be much appreciated
>> Best wishes
>> Stephan Kramer
>> Full logs including log_view timings available from
>> https://github.com/stephankramer/petsc-scaling/
>> In particular:
>> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_5/output_2.dat
>> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_5/output_2.dat
>> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_6/output_2.dat
>> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_6/output_2.dat
>> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_7/output_2.dat
>> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_7/output_2.dat
