[petsc-users] eigenvalue problem involving inverse of a matrix
Jose E. Roman jroman at dsic.upv.es
Mon Aug 14 04:50:56 CDT 2023
See for instance ex3.c and ex9.c
https://slepc.upv.es/documentation/current/src/eps/tutorials/index.html
Jose
> El 14 ago 2023, a las 10:45, Pierre Jolivet <pierre.jolivet at lip6.fr> escribió:
>> On 14 Aug 2023, at 10:39 AM, maitri ksh <maitri.ksh at gmail.com> wrote:
>> Hi,
>> I need to solve an eigenvalue problem  Ax=lmbda*x, where A=(B^-H)*Q*B^-1 is a hermitian matrix, 'B^-H' refers to the hermitian of the inverse of the matrix B. Theoretically it would take around 1.8TB to explicitly compute the matrix B^-1 . A feasible way to solve this eigenvalue problem would be to use the LU factors of the B matrix instead. So the problem looks something like this:
>>                      (((LU)^-H)*Q*(LU)^-1)*x = lmbda*x
>> For a guess value of the (normalised) eigen-vector 'x',
>> 1) one would require to solve two linear equations to get 'Ax',
>>         (LU)*y=x,             solve for 'y',
>>        ((LU)^H)*z=Q*y,   solve for 'z'
>>     then one can follow the conventional power-iteration procedure
>> 2) update eigenvector: x= z/||z||
>> 3) get eigenvalue using the Rayleigh quotient
>> 4) go to step-1 and loop through with a conditional break.
>> Is there any example in petsc that does not require explicit declaration of the matrix 'A' (Ax=lmbda*x) and instead takes a vector 'Ax' as input for an iterative algorithm (like the one above). I looked into some of the examples of eigenvalue problems ( it's highly possible that I might have overlooked, I am new to petsc) but I couldn't find a way to circumvent the explicit declaration of matrix A.
> You could use SLEPc with a MatShell, that’s the very purpose of this MatType.
> Thanks,
> Pierre
>> Maitri
