[petsc-users] 32-bit vs 64-bit GPU support
Jed Brown jed at jedbrown.org
Fri Aug 11 15:13:04 CDT 2023
Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
> More generally, it would be interesting to know the breakdown of installed CUDA versions for users. Unlike compilers etc, I suspect that cluster admins (and those running on local machines) are much more likely to be updating their CUDA toolkits to the latest versions as they often contain critical performance improvements.
One difference is that some sites (not looking at you at all, ALCF) still run pretty ancient drivers and/or have broken GPU-aware MPI with all but a specific ancient version of CUDA (OLCF, LLNL). With a normal compiler, you can choose to use the latest version, but with CUDA, people are firmly stuck on old versions.
