[petsc-users] CUDA error trying to run a job with two mpi processes and 1 GPU
Junchao Zhang junchao.zhang at gmail.com
Fri Aug 11 14:04:58 CDT 2023
Hi, Macros,
  I saw MatSetPreallocationCOO_MPIAIJCUSPARSE_Basic() in the error stack.
We recently refactored the COO code and got rid of that function.  So could
you try petsc/main?
  We map MPI processes to GPUs in a round-robin fashion. We query the
number of visible CUDA devices (g), and assign the device (rank%g) to the
MPI process (rank).   In that sense, the work distribution is totally
determined by your MPI work partition (i.e, yourself).
  On clusters, this MPI process to GPU binding is usually done by the job
scheduler like slurm.  You need to check your cluster's users' guide to see
how to bind MPI processes to GPUs. If the job scheduler has done that, the
number of visible CUDA devices to a process might just appear to be 1,
making petsc's own mapping void.
   Thanks.
--Junchao Zhang
On Fri, Aug 11, 2023 at 12:43 PM Vanella, Marcos (Fed) <
marcos.vanella at nist.gov> wrote:
> Hi Junchao, thank you for replying. I compiled petsc in debug mode and
> this is what I get for the case:
> terminate called after throwing an instance of
> 'thrust::system::system_error'
>   what():  merge_sort: failed to synchronize: cudaErrorIllegalAddress: an
> illegal memory access was encountered
> Program received signal SIGABRT: Process abort signal.
> Backtrace for this error:
> #0  0x15264731ead0 in ???
> #1  0x15264731dc35 in ???
> #2  0x15264711551f in ???
> #3  0x152647169a7c in ???
> #4  0x152647115475 in ???
> #5  0x1526470fb7f2 in ???
> #6  0x152647678bbd in ???
> #7  0x15264768424b in ???
> #8  0x1526476842b6 in ???
> #9  0x152647684517 in ???
> #10  0x55bb46342ebb in _ZN6thrust8cuda_cub14throw_on_errorE9cudaErrorPKc
> at /usr/local/cuda/include/thrust/system/cuda/detail/util.h:224
> #11  0x55bb46342ebb in
> _ZN6thrust8cuda_cub12__merge_sort10merge_sortINS_6detail17integral_constantIbLb1EEENS4_IbLb0EEENS0_3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEESB_NS_9null_typeESC_SC_SC_SC_SC_SC_SC_EEEENS3_15normal_iteratorISB_EE9IJCompareEEvRNS0_16execution_policyIT1_EET2_SM_T3_T4_
> at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1316
> #12  0x55bb46342ebb in
> _ZN6thrust8cuda_cub12__smart_sort10smart_sortINS_6detail17integral_constantIbLb1EEENS4_IbLb0EEENS0_16execution_policyINS0_3tagEEENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEESD_NS_9null_typeESE_SE_SE_SE_SE_SE_SE_EEEENS3_15normal_iteratorISD_EE9IJCompareEENS1_25enable_if_comparison_sortIT2_T4_E4typeERT1_SL_SL_T3_SM_
> at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1544
> #13  0x55bb46342ebb in
> _ZN6thrust8cuda_cub11sort_by_keyINS0_3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES6_NS_9null_typeES7_S7_S7_S7_S7_S7_S7_EEEENS_6detail15normal_iteratorIS6_EE9IJCompareEEvRNS0_16execution_policyIT_EET0_SI_T1_T2_
> at /usr/local/cuda/include/thrust/system/cuda/detail/sort.h:1669
> #14  0x55bb46317bc5 in
> _ZN6thrust11sort_by_keyINS_8cuda_cub3tagENS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES6_NS_9null_typeES7_S7_S7_S7_S7_S7_S7_EEEENS_6detail15normal_iteratorIS6_EE9IJCompareEEvRKNSA_21execution_policy_baseIT_EET0_SJ_T1_T2_
> at /usr/local/cuda/include/thrust/detail/sort.inl:115
> #15  0x55bb46317bc5 in
> _ZN6thrust11sort_by_keyINS_12zip_iteratorINS_5tupleINS_10device_ptrIiEES4_NS_9null_typeES5_S5_S5_S5_S5_S5_S5_EEEENS_6detail15normal_iteratorIS4_EE9IJCompareEEvT_SC_T0_T1_
> at /usr/local/cuda/include/thrust/detail/sort.inl:305
> #16  0x55bb46317bc5 in MatSetPreallocationCOO_SeqAIJCUSPARSE_Basic
> at /home/mnv/Software/petsc/src/mat/impls/aij/seq/seqcusparse/
> aijcusparse.cu:4452
> #17  0x55bb46c5b27c in MatSetPreallocationCOO_MPIAIJCUSPARSE_Basic
> at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpicusparse/
> mpiaijcusparse.cu:173
> #18  0x55bb46c5b27c in MatSetPreallocationCOO_MPIAIJCUSPARSE
> mpiaijcusparse.cu:222
> #19  0x55bb468e01cf in MatSetPreallocationCOO
> at /home/mnv/Software/petsc/src/mat/utils/gcreate.c:606
> #20  0x55bb46b39c9b in MatProductSymbolic_MPIAIJBACKEND
> at /home/mnv/Software/petsc/src/mat/impls/aij/mpi/mpiaij.c:7547
> #21  0x55bb469015e5 in MatProductSymbolic
> at /home/mnv/Software/petsc/src/mat/interface/matproduct.c:803
> #22  0x55bb4694ade2 in MatPtAP
> at /home/mnv/Software/petsc/src/mat/interface/matrix.c:9897
> #23  0x55bb4696d3ec in MatCoarsenApply_MISK_private
> at /home/mnv/Software/petsc/src/mat/coarsen/impls/misk/misk.c:283
> #24  0x55bb4696eb67 in MatCoarsenApply_MISK
> at /home/mnv/Software/petsc/src/mat/coarsen/impls/misk/misk.c:368
> #25  0x55bb4695bd91 in MatCoarsenApply
> at /home/mnv/Software/petsc/src/mat/coarsen/coarsen.c:97
> #26  0x55bb478294d8 in PCGAMGCoarsen_AGG
> at /home/mnv/Software/petsc/src/ksp/pc/impls/gamg/agg.c:524
> #27  0x55bb471d1cb4 in PCSetUp_GAMG
> at /home/mnv/Software/petsc/src/ksp/pc/impls/gamg/gamg.c:631
> #28  0x55bb464022cf in PCSetUp
> at /home/mnv/Software/petsc/src/ksp/pc/interface/precon.c:994
> #29  0x55bb4718b8a7 in KSPSetUp
> at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:406
> #30  0x55bb4718f22e in KSPSolve_Private
> at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:824
> #31  0x55bb47192c0c in KSPSolve
> at /home/mnv/Software/petsc/src/ksp/ksp/interface/itfunc.c:1070
> #32  0x55bb463efd35 in kspsolve_
> at /home/mnv/Software/petsc/src/ksp/ksp/interface/ftn-auto/itfuncf.c:320
> #33  0x55bb45e94b32 in ???
> #34  0x55bb46048044 in ???
> #35  0x55bb46052ea1 in ???
> #36  0x55bb45ac5f8e in ???
> #37  0x1526470fcd8f in ???
> #38  0x1526470fce3f in ???
> #39  0x55bb45aef55d in ???
> #40  0xffffffffffffffff in ???
> Primary job  terminated normally, but 1 process returned
> a non-zero exit code. Per user-direction, the job has been aborted.
> mpirun noticed that process rank 0 with PID 1771753 on node dgx02 exited
> on signal 6 (Aborted).
> BTW, I'm curious. If I set n MPI processes, each of them building a part
> of the linear system, and g GPUs, how does PETSc distribute those n pieces
> of system matrix and rhs in the g GPUs? Does it do some load balancing
> algorithm? Where can I read about this?
> Thank you and best Regards, I can also point you to my code repo in GitHub
> if you want to take a closer look.
> Best Regards,
> Marcos
> *From:* Junchao Zhang <junchao.zhang at gmail.com>
> *Sent:* Friday, August 11, 2023 10:52 AM
> *To:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] CUDA error trying to run a job with two mpi
> processes and 1 GPU
> Hi, Marcos,
>   Could you build petsc in debug mode and then copy and paste the whole
> error stack message?
>    Thanks
> --Junchao Zhang
> On Thu, Aug 10, 2023 at 5:51 PM Vanella, Marcos (Fed) via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi, I'm trying to run a parallel matrix vector build and linear solution
> with PETSc on 2 MPI processes + one V100 GPU. I tested that the matrix
> build and solution is successful in CPUs only. I'm using cuda 11.5 and cuda
> enabled openmpi and gcc 9.3. When I run the job with GPU enabled I get the
> following error:
>   *what():  merge_sort: failed to synchronize: cudaErrorIllegalAddress:
> an illegal memory access was encountered*
> I'm new to submitting jobs in slurm that also use GPU resources, so I
> might be doing something wrong in my submission script. This is it:
> #!/bin/bash
> #SBATCH -J test
> #SBATCH -e /home/Issues/PETSc/test.err
> #SBATCH -o /home/Issues/PETSc/test.log
> #SBATCH --partition=batch
> #SBATCH --ntasks=2
> #SBATCH --nodes=1
> #SBATCH --cpus-per-task=1
> #SBATCH --ntasks-per-node=2
> #SBATCH --time=01:00:00
> #SBATCH --gres=gpu:1
> export OMP_NUM_THREADS=1
> module load cuda/11.5
> module load openmpi/4.1.1
> cd /home/Issues/PETSc
> *mpirun -n 2 */home/fds/Build/ompi_gnu_linux/fds_ompi_gnu_linux test.fds *-vec_type
> mpicuda -mat_type mpiaijcusparse -pc_type gamg*
> If anyone has any suggestions on how o troubleshoot this please let me
> know.
> Thanks!
> Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230811/2e56a437/attachment-0001.html>
