[petsc-users] 32-bit vs 64-bit GPU support
Rohan Yadav rohany at alumni.cmu.edu
Fri Aug 11 12:23:15 CDT 2023
I was wondering what the official status of 64-bit integer support in the
PETSc GPU backend is (specifically CUDA). This question comes from the
result of benchmarking some PETSc code and looking at some sources. In
particular, I found that PETSc's call to cuSPARSE SpMV seems to always be
using the 32-bit integer call, even if I compile PETSc with
`--with-64-bit-indices`. After digging around more, I see that PETSc always
only creates 32-bit cuSPARSE matrices as well:
https://gitlab.com/petsc/petsc/-/blob/v3.19.4/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu?ref_type=tags#L2501.
I was looking around for a switch somewhere to 64 bit integers inside this
code, but everything seems to be pretty hardcoded with `THRUSTINTARRAY32`.
As expected, this all works when the range of coordinates in each sparse
matrix partition is less than INT_MAX, but PETSc GPU code breaks in
different ways (calling cuBLAS and cuSPARSE) when trying a (synthetic)
problem that needs 64 bit integers:
#include "petscmat.h"
#include "petscvec.h"
#include "petsc.h"
int main(int argc, char** argv) {
  PetscInt ierr;
  PetscInitialize(&argc, &argv, (char *)0, "GPU bug");
  PetscInt numRows = 1;
  PetscInt numCols = PetscInt(INT_MAX) * 2;
  Mat A;
  PetscInt rowStart, rowEnd;
  ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
  MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, numRows, numCols);
  MatSetType(A, MATMPIAIJ);
  MatSetFromOptions(A);
  MatSetValue(A, 0, 0, 1.0, INSERT_VALUES);
  MatSetValue(A, 0, numCols - 1, 1.0, INSERT_VALUES);
  MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
  MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
  Vec b;
  ierr = VecCreate(PETSC_COMM_WORLD, &b); CHKERRQ(ierr);
  VecSetSizes(b, PETSC_DECIDE, numCols);
  VecSetFromOptions(b);
  VecSet(b, 0.0);
  VecSetValue(b, 0, 42.0, INSERT_VALUES);
  VecSetValue(b, numCols - 1, 58.0, INSERT_VALUES);
  VecAssemblyBegin(b);
  VecAssemblyEnd(b);
  Vec x;
  ierr = VecCreate(PETSC_COMM_WORLD, &x); CHKERRQ(ierr);
  VecSetSizes(x, PETSC_DECIDE, numRows);
  VecSetFromOptions(x);
  VecSet(x, 0.0);
  MatMult(A, b, x);
  PetscScalar result;
  VecSum(x, &result);
  PetscPrintf(PETSC_COMM_WORLD, "Result of mult: %f\n", result);
  PetscFinalize();
When this program is run on CPUs, it outputs 100.0, as expected.
When run on a single GPU with `-vec_type cuda -mat_type aijcusparse
-use_gpu_aware_mpi 0` it fails with
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: 4294967294 is too big for cuBLAS, which may be restricted
to 32-bit integers
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.19.4, unknown
[0]PETSC ERROR: ./gpu-bug on a  named sean-dgx2 by rohany Fri Aug 11
09:34:10 2023
[0]PETSC ERROR: Configure options --with-cuda=1
--prefix=/local/home/rohany/petsc/petsc-install/
--with-cuda-dir=/usr/local/cuda-11.7/ CXXFLAGS=-O3 COPTFLAGS=-O3
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3 --download-fblaslapack=1 --with-debugging=0
[0]PETSC ERROR: #1 checkCupmBlasIntCast() at
/local/home/rohany/petsc/include/petsc/private/cupmblasinterface.hpp:435
[0]PETSC ERROR: #2 VecAllocateCheck_() at
/local/home/rohany/petsc/include/petsc/private/veccupmimpl.h:335
[0]PETSC ERROR: #3 VecCUPMAllocateCheck_() at
/local/home/rohany/petsc/include/petsc/private/veccupmimpl.h:360
[0]PETSC ERROR: #4 DeviceAllocateCheck_() at
/local/home/rohany/petsc/include/petsc/private/veccupmimpl.h:389
[0]PETSC ERROR: #5 GetArray() at
/local/home/rohany/petsc/include/petsc/private/veccupmimpl.h:545
[0]PETSC ERROR: #6 VectorArray() at
/local/home/rohany/petsc/include/petsc/private/veccupmimpl.h:273
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
with errorcode 63.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
and when run with just `-mat_type aijcusparse -use_gpu_aware_mpi 0` it
fails with
 ** On entry to cusparseCreateCsr(): dimension mismatch for
CUSPARSE_INDEX_32I, cols (4294967294) + base (0) > INT32_MAX (2147483647)
[0]PETSC ERROR: GPU error
[0]PETSC ERROR: cuSPARSE errorcode 3 (CUSPARSE_STATUS_INVALID_VALUE) :
invalid value
09:43:07 2023
[0]PETSC ERROR: #1 MatSeqAIJCUSPARSECopyToGPU() at
/local/home/rohany/petsc/src/mat/impls/aij/seq/seqcusparse/
aijcusparse.cu:2503
[0]PETSC ERROR: #2 MatMultAddKernel_SeqAIJCUSPARSE() at
aijcusparse.cu:3544
[0]PETSC ERROR: #3 MatMult_SeqAIJCUSPARSE() at
aijcusparse.cu:3485
[0]PETSC ERROR: #4 MatMult_MPIAIJCUSPARSE() at
/local/home/rohany/petsc/src/mat/impls/aij/mpi/mpicusparse/
mpiaijcusparse.cu:452
[0]PETSC ERROR: #5 MatMult() at
/local/home/rohany/petsc/src/mat/interface/matrix.c:2599
Rohan Yadav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230811/00437b57/attachment.html>
