[petsc-users] performance regression with GAMG
Mark Adams mfadams at lbl.gov
Thu Aug 10 09:08:19 CDT 2023
Hi Stephan,
Yes, MIS(A^T A) -> MIS(MIS(A)) change?
Yep, that is it.
This change was required because A^T A is super expensive. This change did
not do much to my tests but this is complex.
I am on travel now, but I can get to this in a few days. You provided me
with a lot of data and I can take a look, but I think we need to look at
parameters,
On Wed, Aug 9, 2023 at 10:08 AM Stephan Kramer <s.kramer at imperial.ac.uk>
wrote:
> Dear petsc devs
> We have noticed a performance regression using GAMG as the
> preconditioner to solve the velocity block in a Stokes equations saddle
> point system with variable viscosity solved on a 3D hexahedral mesh of a
> spherical shell using Q2-Q1 elements. This is comparing performance from
> the beginning of last year (petsc 3.16.4) and a more recent petsc master
> (from around May this year). This is the weak scaling analysis we
> published in https://doi.org/10.5194/gmd-15-5127-2022 Previously the
> number of iterations for the velocity block (inner solve of the Schur
> complement) starts at 40 iterations
> https://gmd.copernicus.org/articles/15/5127/2022/gmd-15-5127-2022-f10-web.png)
> and only slowly going for larger problems (+more cores). Now the number
> of iterations now starts at 60
> https://github.com/stephankramer/petsc-scaling/blob/main/after/SPD_Combined_Iterations.png),
> same tolerances, again slowly going up with increasing size, with the
> cost per iteration also gone up (slightly) - resulting in an increased
> runtime of > 50%.
> The main change we can see is that the coarsening seems to have gotten a
> lot less aggressive at the first coarsening stage (finest->to
> one-but-finest) - presumably after the MIS(A^T A) -> MIS(MIS(A)) change?
> The performance issues might be similar to
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2023-April/048366.html
> As an example at "Level 7" (6,389,890 vertices, run on 1536 cpus) on the
> older petsc version we had:
>            rows=126, cols=126, bs=6
>            total: nonzeros=15876, allocated nonzeros=15876
>            rows=3072, cols=3072, bs=6
>            total: nonzeros=3344688, allocated nonzeros=3344688
>            rows=91152, cols=91152, bs=6
>            total: nonzeros=109729584, allocated nonzeros=109729584
>            rows=2655378, cols=2655378, bs=6
>            total: nonzeros=1468980252, allocated nonzeros=1468980252
>            rows=152175366, cols=152175366, bs=3
>            total: nonzeros=29047661586, allocated nonzeros=29047661586
> Whereas with the newer version we get:
>            rows=420, cols=420, bs=6
>            total: nonzeros=176400, allocated nonzeros=176400
>            rows=6462, cols=6462, bs=6
>            total: nonzeros=10891908, allocated nonzeros=10891908
>            rows=91716, cols=91716, bs=6
>            total: nonzeros=81687384, allocated nonzeros=81687384
>            rows=5419362, cols=5419362, bs=6
>            total: nonzeros=3668190588, allocated nonzeros=3668190588
> So in the first step it coarsens from 150e6 to 5.4e6 DOFs instead of to
> 2.6e6 DOFs. Note that we are providing the rigid body near nullspace,
> hence the bs=3 to bs=6.
> We have tried different values for the gamg_threshold but it doesn't
> really seem to significantly alter the coarsening amount in that first
> step.
> Do you have any suggestions for further things we should try/look at?
> Any feedback would be much appreciated
> Best wishes
> Stephan Kramer
> Full logs including log_view timings available from
> In particular:
> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_5/output_2.dat
> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_5/output_2.dat
> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_6/output_2.dat
> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_6/output_2.dat
> https://github.com/stephankramer/petsc-scaling/blob/main/before/Level_7/output_2.dat
> https://github.com/stephankramer/petsc-scaling/blob/main/after/Level_7/output_2.dat
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230810/cb00b051/attachment.html>
