[petsc-users] Python PETSc performance vs scipy ZVODE
Niclas Götting ngoetting at itp.uni-bremen.de
Thu Aug 10 05:31:31 CDT 2023
Alright. Again, thank you very much for taking the time to answer my
beginner questions! Still a lot to learn..
Have a good day!
On 10.08.23 12:27, Stefano Zampini wrote:
> Then just do the multiplications you need. My proposal was for the
> example function you were showing.
> On Thu, Aug 10, 2023, 12:25 Niclas Götting
> <ngoetting at itp.uni-bremen.de> wrote:
>     You are absolutely right for this specific case (I get about
>     2400it/s instead of 2100it/s). However, the single square function
>     will be replaced by a series of gaussian pulses in the future,
>     which will never be zero. Maybe one could do an approximation and
>     skip the second mult, if the gaussians are close to zero.
>     On 10.08.23 12:16, Stefano Zampini wrote:
>>     If you do the mult of "pump" inside an if it should be faster
>>     On Thu, Aug 10, 2023, 12:12 Niclas Götting
>>         If I understood you right, this should be the resulting RHS:
>>         def rhsfunc5(ts, t, u, F):
>>             l.mult(u, F)
>>             pump.mult(u, tmp_vec)
>>             scale = 0.5 * (5 < t < 10)
>>             F.axpy(scale, tmp_vec)
>>         It is a little bit slower than option 3, but with about
>>         2100it/s consistently ~10% faster than option 4.
>>         Thank you very much for the suggestion!
>>         On 10.08.23 11:47, Stefano Zampini wrote:
>>>         I would use option 3. Keep a work vector and do a vector
>>>         summation instead of the multiple multiplication by scale
>>>         and 1/scale.
>>>         I agree with you the docs are a little misleading here.
>>>         On Thu, Aug 10, 2023, 11:40 Niclas Götting
>>>             Thank you both for the very quick answer!
>>>             So far, I compiled PETSc with debugging turned on, but I
>>>             think it should still be faster than standard scipy in
>>>             both cases. Actually, Stefano's answer has got me very
>>>             far already; now I only define the RHS of the ODE and no
>>>             Jacobian (I wonder, why the documentation suggests
>>>             otherwise, though). I had the following four tries at
>>>             implementing the RHS:
>>>              1. def rhsfunc1(ts, t, u, F):
>>>                     (l + scale * pump).mult(u, F)
>>>              2. def rhsfunc2(ts, t, u, F):
>>>                     l.mult(u, F)
>>>                     (scale * pump).multAdd(u, F, F)
>>>              3. def rhsfunc3(ts, t, u, F):
>>>                     l.mult(u, F)
>>>                     if scale != 0:
>>>                         pump.scale(scale)
>>>                         pump.multAdd(u, F, F)
>>>                         pump.scale(1/scale)
>>>              4. def rhsfunc4(ts, t, u, F):
>>>                     tmp_pump.zeroEntries() # tmp_pump is
>>>                 pump.duplicate()
>>>                     l.mult(u, F)
>>>                     tmp_pump.axpy(scale, pump,
>>>                 structure=PETSc.Mat.Structure.SAME_NONZERO_PATTERN)
>>>                     tmp_pump.multAdd(u, F, F)
>>>             They all yield the same results, but with 50it/s,
>>>             800it/, 2300it/s and 1900it/s, respectively, which is a
>>>             huge performance boost (almost 7 times as fast as scipy,
>>>             with PETSc debugging still turned on). As the scale
>>>             function will most likely be a gaussian in the future, I
>>>             think that option 3 will be become numerically unstable
>>>             and I'll have to go with option 4, which is already
>>>             faster than I expected. If you think it is possible to
>>>             speed up the RHS calculation even more, I'd be happy to
>>>             hear your suggestions; the -log_view is attached to this
>>>             message.
>>>             One last point: If I didn't misunderstand the
>>>             documentation at
>>>             https://petsc.org/release/manual/ts/#special-cases,
>>>             should this maybe be changed?
>>>             Best regards
>>>             Niclas
>>>             On 09.08.23 17:51, Stefano Zampini wrote:
>>>>             TSRK is an explicit solver. Unless you are changing the
>>>>             ts type from command line,  the explicit  jacobian
>>>>             should not be needed. On top of Barry's suggestion, I
>>>>             would suggest you to write the explicit RHS instead of
>>>>             assembly a throw away matrix every time that function
>>>>             needs to be sampled.
>>>>             On Wed, Aug 9, 2023, 17:09 Niclas Götting
>>>>                 Hi all,
>>>>                 I'm currently trying to convert a quantum
>>>>                 simulation from scipy to
>>>>                 PETSc. The problem itself is extremely simple and
>>>>                 of the form \dot{u}(t)
>>>>                 = (A_const + f(t)*B_const)*u(t), where f(t) in this
>>>>                 simple test case is
>>>>                 a square function. The matrices A_const and B_const
>>>>                 are extremely sparse
>>>>                 and therefore I thought, the problem will be well
>>>>                 suited for PETSc.
>>>>                 Currently, I solve the ODE with the following
>>>>                 procedure in scipy (I can
>>>>                 provide the necessary data files, if needed, but
>>>>                 they are just some
>>>>                 trace-preserving, very sparse matrices):
>>>>                 import numpy as np
>>>>                 import scipy.sparse
>>>>                 import scipy.integrate
>>>>                 from tqdm import tqdm
>>>>                 l = np.load("../liouvillian.npy")
>>>>                 pump = np.load("../pump_operator.npy")
>>>>                 state = np.load("../initial_state.npy")
>>>>                 l = scipy.sparse.csr_array(l)
>>>>                 pump = scipy.sparse.csr_array(pump)
>>>>                 def f(t, y, *args):
>>>>                      return (l + 0.5 * (5 < t < 10) * pump) @ y
>>>>                      #return l @ y # Uncomment for f(t) = 0
>>>>                 dt = 0.1
>>>>                 NUM_STEPS = 200
>>>>                 res = np.empty((NUM_STEPS, 4096), dtype=np.complex128)
>>>>                 solver =
>>>>                 scipy.integrate.ode(f).set_integrator("zvode").set_initial_value(state)
>>>>                 times = []
>>>>                 for i in tqdm(range(NUM_STEPS)):
>>>>                      res[i, :] = solver.integrate(solver.t + dt)
>>>>                      times.append(solver.t)
>>>>                 Here, A_const = l, B_const = pump and f(t) = 5 < t
>>>>                 < 10. tqdm reports
>>>>                 about 330it/s on my machine. When converting the
>>>>                 code to PETSc, I came
>>>>                 to the following result (according to the chapter
>>>>                 https://petsc.org/main/manual/ts/#special-cases)
>>>>                 import sys
>>>>                 import petsc4py
>>>>                 petsc4py.init(args=sys.argv)
>>>>                 import numpy as np
>>>>                 import scipy.sparse
>>>>                 from petsc4py import PETSc
>>>>                 comm = PETSc.COMM_WORLD
>>>>                 def mat_to_real(arr):
>>>>                      return np.block([[arr.real, -arr.imag],
>>>>                 [arr.imag,
>>>>                 arr.real]]).astype(np.float64)
>>>>                 def mat_to_petsc_aij(arr):
>>>>                      arr_sc_sp = scipy.sparse.csr_array(arr)
>>>>                      mat = PETSc.Mat().createAIJ(arr.shape[0],
>>>>                 comm=comm)
>>>>                      rstart, rend = mat.getOwnershipRange()
>>>>                      print(rstart, rend)
>>>>                      print(arr.shape[0])
>>>>                      print(mat.sizes)
>>>>                      I = arr_sc_sp.indptr[rstart : rend + 1] -
>>>>                 arr_sc_sp.indptr[rstart]
>>>>                      J = arr_sc_sp.indices[arr_sc_sp.indptr[rstart] :
>>>>                 arr_sc_sp.indptr[rend]]
>>>>                      V = arr_sc_sp.data[arr_sc_sp.indptr[rstart] :
>>>>                      print(I.shape, J.shape, V.shape)
>>>>                      mat.setValuesCSR(I, J, V)
>>>>                      mat.assemble()
>>>>                      return mat
>>>>                 l = mat_to_real(l)
>>>>                 pump = mat_to_real(pump)
>>>>                 state = np.hstack([state.real,
>>>>                 state.imag]).astype(np.float64)
>>>>                 l = mat_to_petsc_aij(l)
>>>>                 pump = mat_to_petsc_aij(pump)
>>>>                 jac = l.duplicate()
>>>>                 for i in range(8192):
>>>>                      jac.setValue(i, i, 0)
>>>>                 jac.assemble()
>>>>                 jac += l
>>>>                 vec = l.createVecRight()
>>>>                 vec.setValues(np.arange(state.shape[0],
>>>>                 dtype=np.int32), state)
>>>>                 vec.assemble()
>>>>                 dt = 0.1
>>>>                 ts = PETSc.TS().create(comm=comm)
>>>>                 ts.setFromOptions()
>>>>                 ts.setProblemType(ts.ProblemType.LINEAR)
>>>>                 ts.setEquationType(ts.EquationType.ODE_EXPLICIT)
>>>>                 ts.setType(ts.Type.RK)
>>>>                 ts.setRKType(ts.RKType.RK3BS)
>>>>                 ts.setTime(0)
>>>>                 print("KSP:", ts.getKSP().getType())
>>>>                 print("KSP PC:",ts.getKSP().getPC().getType())
>>>>                 print("SNES :", ts.getSNES().getType())
>>>>                 def jacobian(ts, t, u, Amat, Pmat):
>>>>                      Amat.zeroEntries()
>>>>                      Amat.aypx(1, l,
>>>>                 structure=PETSc.Mat.Structure.SUBSET_NONZERO_PATTERN)
>>>>                      Amat.axpy(0.5 * (5 < t < 10), pump,
>>>>                 ts.setRHSFunction(PETSc.TS.computeRHSFunctionLinear)
>>>>                 #ts.setRHSJacobian(PETSc.TS.computeRHSJacobianConstant,
>>>>                 l, l) #
>>>>                 ts.setRHSJacobian(jacobian, jac)
>>>>                 NUM_STEPS = 200
>>>>                 res = np.empty((NUM_STEPS, 8192), dtype=np.float64)
>>>>                 times = []
>>>>                 rstart, rend = vec.getOwnershipRange()
>>>>                      time = ts.getTime()
>>>>                      ts.setMaxTime(time + dt)
>>>>                      ts.solve(vec)
>>>>                      res[i, rstart:rend] = vec.getArray()[:]
>>>>                      times.append(time)
>>>>                 I decomposed the complex ODE into a larger real
>>>>                 ODE, so that I can
>>>>                 easily switch maybe to GPU computation later on.
>>>>                 Now, the solutions of
>>>>                 both scripts are very much identical, but PETSc
>>>>                 runs about 3 times
>>>>                 slower at 120it/s on my machine. I don't use MPI
>>>>                 for PETSc yet.
>>>>                 I strongly suppose that the problem lies within the
>>>>                 jacobian definition,
>>>>                 as PETSc is about 3 times *faster* than scipy with
>>>>                 f(t) = 0 and
>>>>                 therefore a constant jacobian.
>>>>                 Thank you in advance.
>>>>                 All the best,
>>>>                 Niclas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230810/db2d19bc/attachment-0001.html>
