[petsc-users] Python PETSc performance vs scipy ZVODE
Stefano Zampini stefano.zampini at gmail.com
Thu Aug 10 05:16:08 CDT 2023
If you do the mult of "pump" inside an if it should be faster
On Thu, Aug 10, 2023, 12:12 Niclas Götting <ngoetting at itp.uni-bremen.de>
wrote:
> If I understood you right, this should be the resulting RHS:
> def rhsfunc5(ts, t, u, F):
>     l.mult(u, F)
>     pump.mult(u, tmp_vec)
>     scale = 0.5 * (5 < t < 10)
>     F.axpy(scale, tmp_vec)
> It is a little bit slower than option 3, but with about 2100it/s
> consistently ~10% faster than option 4.
> Thank you very much for the suggestion!
> On 10.08.23 11:47, Stefano Zampini wrote:
> I would use option 3. Keep a work vector and do a vector summation instead
> of the multiple multiplication by scale and 1/scale.
> I agree with you the docs are a little misleading here.
> On Thu, Aug 10, 2023, 11:40 Niclas Götting <ngoetting at itp.uni-bremen.de>
> wrote:
>> Thank you both for the very quick answer!
>> So far, I compiled PETSc with debugging turned on, but I think it should
>> still be faster than standard scipy in both cases. Actually, Stefano's
>> answer has got me very far already; now I only define the RHS of the ODE
>> and no Jacobian (I wonder, why the documentation suggests otherwise,
>> though). I had the following four tries at implementing the RHS:
>>    1. def rhsfunc1(ts, t, u, F):
>>        (l + scale * pump).mult(u, F)
>>    2. def rhsfunc2(ts, t, u, F):
>>        l.mult(u, F)
>>        (scale * pump).multAdd(u, F, F)
>>    3. def rhsfunc3(ts, t, u, F):
>>        l.mult(u, F)
>>        if scale != 0:
>>            pump.scale(scale)
>>            pump.multAdd(u, F, F)
>>            pump.scale(1/scale)
>>    4. def rhsfunc4(ts, t, u, F):
>>        tmp_pump.zeroEntries() # tmp_pump is pump.duplicate()
>>        l.mult(u, F)
>>        tmp_pump.axpy(scale, pump,
>>    structure=PETSc.Mat.Structure.SAME_NONZERO_PATTERN)
>>        tmp_pump.multAdd(u, F, F)
>> They all yield the same results, but with 50it/s, 800it/, 2300it/s and
>> 1900it/s, respectively, which is a huge performance boost (almost 7 times
>> as fast as scipy, with PETSc debugging still turned on). As the scale
>> function will most likely be a gaussian in the future, I think that option
>> 3 will be become numerically unstable and I'll have to go with option 4,
>> which is already faster than I expected. If you think it is possible to
>> speed up the RHS calculation even more, I'd be happy to hear your
>> suggestions; the -log_view is attached to this message.
>> One last point: If I didn't misunderstand the documentation at
>> https://petsc.org/release/manual/ts/#special-cases, should this maybe be
>> changed?
>> Best regards
>> Niclas
>> On 09.08.23 17:51, Stefano Zampini wrote:
>> TSRK is an explicit solver. Unless you are changing the ts type from
>> command line,  the explicit  jacobian should not be needed. On top of
>> Barry's suggestion, I would suggest you to write the explicit RHS instead
>> of assembly a throw away matrix every time that function needs to be
>> sampled.
>> On Wed, Aug 9, 2023, 17:09 Niclas Götting <ngoetting at itp.uni-bremen.de>
>> wrote:
>>> Hi all,
>>> I'm currently trying to convert a quantum simulation from scipy to
>>> PETSc. The problem itself is extremely simple and of the form \dot{u}(t)
>>> = (A_const + f(t)*B_const)*u(t), where f(t) in this simple test case is
>>> a square function. The matrices A_const and B_const are extremely sparse
>>> and therefore I thought, the problem will be well suited for PETSc.
>>> Currently, I solve the ODE with the following procedure in scipy (I can
>>> provide the necessary data files, if needed, but they are just some
>>> trace-preserving, very sparse matrices):
>>> import numpy as np
>>> import scipy.sparse
>>> import scipy.integrate
>>> from tqdm import tqdm
>>> l = np.load("../liouvillian.npy")
>>> pump = np.load("../pump_operator.npy")
>>> state = np.load("../initial_state.npy")
>>> l = scipy.sparse.csr_array(l)
>>> pump = scipy.sparse.csr_array(pump)
>>> def f(t, y, *args):
>>>      return (l + 0.5 * (5 < t < 10) * pump) @ y
>>>      #return l @ y # Uncomment for f(t) = 0
>>> dt = 0.1
>>> NUM_STEPS = 200
>>> res = np.empty((NUM_STEPS, 4096), dtype=np.complex128)
>>> solver =
>>> scipy.integrate.ode(f).set_integrator("zvode").set_initial_value(state)
>>> times = []
>>> for i in tqdm(range(NUM_STEPS)):
>>>      res[i, :] = solver.integrate(solver.t + dt)
>>>      times.append(solver.t)
>>> Here, A_const = l, B_const = pump and f(t) = 5 < t < 10. tqdm reports
>>> about 330it/s on my machine. When converting the code to PETSc, I came
>>> to the following result (according to the chapter
>>> https://petsc.org/main/manual/ts/#special-cases)
>>> import sys
>>> import petsc4py
>>> petsc4py.init(args=sys.argv)
>>> import numpy as np
>>> import scipy.sparse
>>> from petsc4py import PETSc
>>> comm = PETSc.COMM_WORLD
>>> def mat_to_real(arr):
>>>      return np.block([[arr.real, -arr.imag], [arr.imag,
>>> arr.real]]).astype(np.float64)
>>> def mat_to_petsc_aij(arr):
>>>      arr_sc_sp = scipy.sparse.csr_array(arr)
>>>      mat = PETSc.Mat().createAIJ(arr.shape[0], comm=comm)
>>>      rstart, rend = mat.getOwnershipRange()
>>>      print(rstart, rend)
>>>      print(arr.shape[0])
>>>      print(mat.sizes)
>>>      I = arr_sc_sp.indptr[rstart : rend + 1] - arr_sc_sp.indptr[rstart]
>>>      J = arr_sc_sp.indices[arr_sc_sp.indptr[rstart] :
>>> arr_sc_sp.indptr[rend]]
>>>      V = arr_sc_sp.data[arr_sc_sp.indptr[rstart] :
>>>      print(I.shape, J.shape, V.shape)
>>>      mat.setValuesCSR(I, J, V)
>>>      mat.assemble()
>>>      return mat
>>> l = mat_to_real(l)
>>> pump = mat_to_real(pump)
>>> state = np.hstack([state.real, state.imag]).astype(np.float64)
>>> l = mat_to_petsc_aij(l)
>>> pump = mat_to_petsc_aij(pump)
>>> jac = l.duplicate()
>>> for i in range(8192):
>>>      jac.setValue(i, i, 0)
>>> jac.assemble()
>>> jac += l
>>> vec = l.createVecRight()
>>> vec.setValues(np.arange(state.shape[0], dtype=np.int32), state)
>>> vec.assemble()
>>> dt = 0.1
>>> ts = PETSc.TS().create(comm=comm)
>>> ts.setFromOptions()
>>> ts.setProblemType(ts.ProblemType.LINEAR)
>>> ts.setEquationType(ts.EquationType.ODE_EXPLICIT)
>>> ts.setType(ts.Type.RK)
>>> ts.setRKType(ts.RKType.RK3BS)
>>> ts.setTime(0)
>>> print("KSP:", ts.getKSP().getType())
>>> print("KSP PC:",ts.getKSP().getPC().getType())
>>> print("SNES :", ts.getSNES().getType())
>>> def jacobian(ts, t, u, Amat, Pmat):
>>>      Amat.zeroEntries()
>>>      Amat.aypx(1, l,
>>> structure=PETSc.Mat.Structure.SUBSET_NONZERO_PATTERN)
>>>      Amat.axpy(0.5 * (5 < t < 10), pump,
>>> ts.setRHSFunction(PETSc.TS.computeRHSFunctionLinear)
>>> #ts.setRHSJacobian(PETSc.TS.computeRHSJacobianConstant, l, l) #
>>> ts.setRHSJacobian(jacobian, jac)
>>> NUM_STEPS = 200
>>> res = np.empty((NUM_STEPS, 8192), dtype=np.float64)
>>> times = []
>>> rstart, rend = vec.getOwnershipRange()
>>>      time = ts.getTime()
>>>      ts.setMaxTime(time + dt)
>>>      ts.solve(vec)
>>>      res[i, rstart:rend] = vec.getArray()[:]
>>>      times.append(time)
>>> I decomposed the complex ODE into a larger real ODE, so that I can
>>> easily switch maybe to GPU computation later on. Now, the solutions of
>>> both scripts are very much identical, but PETSc runs about 3 times
>>> slower at 120it/s on my machine. I don't use MPI for PETSc yet.
>>> I strongly suppose that the problem lies within the jacobian definition,
>>> as PETSc is about 3 times *faster* than scipy with f(t) = 0 and
>>> therefore a constant jacobian.
>>> Thank you in advance.
>>> All the best,
>>> Niclas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230810/748f6e80/attachment.html>
