[petsc-users] IMPI with Hypre
Tue Aug 8 11:31:14 CDT 2023
If using modules - using 'module load gcc icc' [or equivalent] should normally work - but if the modules are setup such that loading icc unloads gcc - then I think that's a bug in this module setup..
[as icc has an (internal) dependency on gcc - so ignoring this dependency to remove a gcc module doesn't look correct to me]
Satish
On Tue, 8 Aug 2023, Victor Eijkhout wrote:
>   *   Its easier to just add the newer version of gcc/g++ compilers to PATH
> Except that I do my path loading through environment modules (lmod version) and they do not allow multiple compilers to be loaded at the same time.
> But yes, that would work.
> V.
> From: Satish Balay <balay at mcs.anl.gov>
> Date: Tuesday, August 8, 2023 at 11:20
> To: Victor Eijkhout <eijkhout at tacc.utexas.edu>
> Cc: Barry Smith <bsmith at petsc.dev>, Khaled Nabil Shar Abdelaziz <kabdelaz at purdue.edu>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] IMPI with Hypre
> Its easier to just add the newer version of gcc/g++ compilers to PATH - and icc will pick it up [without requiring -gcc-toolchain option]
> export PATH=/location/of/newer/g++/bin:$PATH
> ./configure ...
> make ...
> Satish
> > Maybe an option for specifying the explicit location of gcc version? The intel compiler has a “-gcc-toolchain” option for that.
> > https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2023-0/gcc-toolchain.html<https://www.intel.com/content/www/us/en/docs/dpcpp-cpp-compiler/developer-guide-reference/2023-0/gcc-toolchain.html>
> > Victor.
> >> This message is from an external sender. Learn more about why this <<
> >> matters at https://links.utexas.edu/rtyclf.                        <<
