[petsc-users] IMPI with Hypre
Barry Smith bsmith at petsc.dev
Tue Aug 8 10:38:17 CDT 2023
   We get these reports regularly.
   Intel is selecting [GCC 4.8.2 20140120 (Red Hat 4.8.2-15)] as the base compiler, this ancient version does not provide the language support needed by hypre. You need a more recent GNU compiler available for the Intel compilers to base themselves on.
  Barry
> On Aug 8, 2023, at 11:24 AM, Khaled Nabil Shar Abdelaziz <kabdelaz at purdue.edu> wrote:
> Hello,
> I am running into trouble configuring petsc with hypre and intel mpi
> Configure command:
> ./configure PETSC_ARCH=linux-intel-dbg --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-blaslapack-dir=$MKL_HOME --download-metis --download-parmetis --download-hypre --with-make-np=10
> Terminal output:
>            UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>   Using C++ dialect C++11 as lower bound due to package(s):
>   - hypre
>   But C++ compiler (mpiicpc) appears non-compliant with C++11 or didn't accept:
>   - -std=c++20
>   - -std=c++17
>   - -std=c++14
>   - -std=c++11
> I also attached the configure.log
> Thank you in advance.
> Best,
> Khaled
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230808/db2f27e3/attachment.html>
