[petsc-users] Something went wrong with PETSc after installing ParaView
Sat Aug 5 09:18:53 CDT 2023
On Sat, Aug 5, 2023 at 10:10 AM K. Wu <wuktsinghua at gmail.com> wrote:
> Dear Matthew,
> Thanks for your reply!
> Is there any way that I can choose to use the previous MPI installation
> used to build PETSc?
First we would need to know what that was. You can send configure.log,
which will have that information in it.
     Matt
> Regards,
> Kai
> Matthew Knepley <knepley at gmail.com> 于2023年8月5日周六 14:23写道:
>> On Sat, Aug 5, 2023 at 3:22 AM K. Wu <wuktsinghua at gmail.com> wrote:
>>> Hi all,
>>> Good day!
>>> After installing ParaView on my desktop, PETSc starts to work
>>> anomalously even after reconfiguration:
>>> 1. If I use mpirun (frequently used before), it seems that now all the
>>> processors will run the program independently without communication. While
>>> mpiexec seems to work properly.
>> Yes, this indicates that the "mpirun" is from a different installation of
>> MPI than "mpiexec", which seems to be from the MPI installation used to
>> build PETSc. Probably the Paraview package installed its own MPI package.
>>> 2. The Makefile (as attached) which works fine before starts to complain:
>>> make: *** No rule to make target 'chkopts', needed by 'test'.  Stop.
>> The 'chkopts' target is defined in the toplevel PETSc makefile, but it is
>> deprecated. You can take it out.
>>   Thanks,
>>      Matt
>>> Thanks for your kind help!
>>> Best regards,
>>> Kai
>>> PETSC_DIR=~/petsc
>>> PETSC_ARCH=arch-linux-c-debug
>>> CFLAGS = -I.
>>> FFLAGS=
>>> CPPFLAGS=-I.
>>> FPPFLAGS=
>>> LOCDIR=
>>> EXAMPLESC=
>>> EXAMPLESF=
>>> MANSEC=
>>> CLEANFILES=
>>> NP=
>>> include ${PETSC_DIR}/lib/petsc/conf/variables
>>> include ${PETSC_DIR}/lib/petsc/conf/rules
>>> include ${PETSC_DIR}/lib/petsc/conf/test
>>> test: ex2-2.o chkopts
>>> rm -rf topopt
>>> -${CLINKER} -o test ex2-2.o ${PETSC_SYS_LIB}
>>> ${RM} ex2-2.o
>>> rm -rf *.o
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230805/cd7e0f0b/attachment.html>
