[petsc-users] obtaining estimated Hessian in BQNLS
Tue Apr 25 17:18:10 CDT 2023
On Tue, Apr 25, 2023 at 2:21 PM Suh, Hansol via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Actually, let me take that back , about inability to access LMVM.
> You can access LMVM Hessian mat after you are done with TaoSolve, but not
> within the iteration.
Good catch. You could do this in the iteration with a monitor.
     Matt
> See:
>     PetscCall(TaoGetKSP(tao, &ksp));
>     PetscCall(KSPGetPC(ksp, &pc));
>     PetscCall(PCLMVMGetMatLMVM(pc, &M));
>     PetscCall(VecDuplicate(x, &in));
>     PetscCall(VecDuplicate(x, &out));
>     PetscCall(VecDuplicate(x, &out2));
>     PetscCall(VecSet(in, 1.0));
>     PetscCall(MatMult(M, in, out));
>     PetscCall(MatSolve(M, out, out2));
>     PetscCall(VecAXPY(out2, -1.0, in));
>     PetscCall(VecNorm(out2, NORM_2, &mult_solve_dist));
> (tao/unconstrained/tutorials/rosenbrock1.c)
> Hope this helps.
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Suh,
> Hansol via petsc-users <petsc-users at mcs.anl.gov>
> *Sent:* Tuesday, April 25, 2023 12:56 PM
> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Cc:* Isaac, Toby <tisaac at anl.gov>; stefano.carli at kuleuven.be <
> stefano.carli at kuleuven.be>
> *Subject:* Re: [petsc-users] obtaining estimated Hessian in BQNLS
> petsc's QN routines uses limited-memory variable metric format, which
> means explicit hessian is not constructed.
> Instead of creating explicit hessian, TAO uses MatSolve, and MatMult, to
> "access" the hessian. So you can have access to Hx, and H^{-1}x, but not H
> matrix by itself.
> And as of right now, there isn't a way to access such Hx, and H^{-1}x.
> (which also means that even if the routines to access Hx, H^{-1}x were
> there, getting those at each iteration doesn't really show much
> information, I think.)
> (Sorry for email reply-chain screw up..)
> *From: *Stefano Carli <stefano.carli at kuleuven.be>
> *Subject: **[petsc-users] obtaining estimated Hessian in BQNLS*
> *Date: *April 25, 2023 at 4:15:35 AM EDT
> *To: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Message-Id: *<
> 05357d86ee454f49a8499739c3654b3a at ICTS-S-EXMBX23.luna.kuleuven.be>
> Dear PETSc developers,
> I’m using PETSc version 3.14.1 coupled to a Fortran code, and I was
> wondering if there is a way of obtaining in output, possibly at each
> iteration, the estimated Hessian matrix for the BQNLS method.
> Thank you in advance and best regards,
> Stefano Carli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230425/08573820/attachment.html>
