[petsc-users] Question about linking LAPACK library
Tue Apr 25 05:59:52 CDT 2023
On Tue, Apr 25, 2023 at 6:03 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
wrote:
> Thank you for your reply.
> I think I gave an example of an unrealistic problem.
> I just wanted to know how to compute the inverse matrix, so I was
> wondering if there is an example of computing the inverse matrix in PETSc.
You just use
  KSPCreate(PETSC_COMM_WORLD, &ksp);
  KSPSetOperator(ksp, A, A);
  KSPSetFromOptions(ksp);
  KSPSolve(ksp, b, x);
This solves the system. If you want an exact solution use
  -pc_type lu
There is a manual chapter on linear solves such as there.
     Matt
> Alternatively, I want to know how to link the LAPACK library.
> best,
> Seung Lee Kwon
> 2023년 4월 25일 (화) 오후 6:44, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Mon, Apr 24, 2023 at 11:47 PM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>> wrote:
>>> Dear all
>>> It depends on the problem. It can have hundreds of thousands of degrees
>>> of freedom.
>> Suppose your matrix was dense and had 1e6 dofs. The work to invert a
>> matrix is O(N^3) with a small
>> constant, so it would take 1e18 = 1 exaflop to invert this matrix and
>> about 10 Terabytes of RAM to store
>> it. Is this available to you? PETSc's supports Elemental and SCALAPACK
>> for this kind of calculation.
>> If the system is sparse, you could invert it using MUMPS, SuperLU_dist,
>> or Pardiso. Then the work and
>> storage depend on the density. There are good estimates for connectivity
>> based on regular grids of given
>> dimension. The limiting resource here is usually memory, which motivates
>> people to try iterative methods.
>> The convergence of iterative methods depend on detailed properties of
>> your system, like the operator spectrum.
>>   Thanks,
>>      Matt
>>> best,
>>> Seung Lee Kwon
>>> 2023년 4월 25일 (화) 오후 12:32, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>>   How large are the dense matrices you would like to invert?
>>>> On Apr 24, 2023, at 11:27 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>> wrote:
>>>> Dear all
>>>> Hello.
>>>> I want to make an inverse matrix like inv(A) in MATLAB.
>>>> Are there some methods to inverse matrix in petsc?
>>>> If not, I want to use the inverse function in the LAPACK library.
>>>> Then, how to use the LAPACK library in petsc? I use the C language.
>>>> Best,
>>>> Seung Lee Kwon
>>>> Seung Lee Kwon, Ph.D.Candidate
>>>> Aerospace Structures and Materials Laboratory
>>>> Department of Mechanical and Aerospace Engineering
>>>> Seoul National University
>>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>>>> E-mail : ksl7912 at snu.ac.kr
>>>> Office : +82-2-880-7389
>>>> C. P : +82-10-4695-1062
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230425/ec5626b7/attachment-0001.html>
