[petsc-users] Setting up a matrix for Lagrange multiplier
Mon Apr 24 11:56:39 CDT 2023
On Mon, Apr 24, 2023 at 10:22 AM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello,
> I was able to construct the below K matrix (using submatrices P and P^T),
> which is of type MATAIJ
> K = [A P^T
>        P   0]
> and solved them using a direct solver.
I modified your example to create either AIJ or Nest matrices, but use the
same assembly code:
  https://gitlab.com/petsc/petsc/-/merge_requests/6368
> However, I was reading online that this is a saddle point problem and I
> should be employing PCFIELDSPLIT.
> Since I have one monolithic matrix K, I was not sure how to split the
> fields.
With this particular matrix, you can use
  -pc_fieldsplit_detect_saddle_point
and it will split it automatically.
     Matt
> Best regards,
> Karthik.
> *From: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Date: *Wednesday, 19 April 2023 at 17:52
> *To: *Matthew Knepley <knepley at gmail.com>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Setting up a matrix for Lagrange multiplier
>  I have declared the mapping
>   ISLocalToGlobalMapping mapping;
>     ISLocalToGlobalMappingCreate(PETSC_COMM_WORLD, 1, n, nindices,
> PETSC_COPY_VALUES, &mapping);
> But when I use MatSetValuesLocal(), how do I know the above mapping is
> employed because it is not one of the parameters passed to the function?
> Thank you.
> Kind regards,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Tuesday, 18 April 2023 at 16:21
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> On Tue, Apr 18, 2023 at 11:16 AM Karthikeyan Chockalingam - STFC UKRI <
> Thank you for your response. I spend some time understanding how
> MatSetValuesLocal and ISLocalToGlobalMappingCreate work.
> You can look at SNES ex28 where we do this with DMCOMPOSITE.
> Q1) Will the matrix K be of type MATMPIAIJ or MATIS?
> K = [A P^T
>        P   0]
> I assume MPIAIJ since IS is only used for Neumann-Neumann decompositions.
> Q2) Can I use both MatSetValues() to MatSetValuesLocal() to populate K?
> Since I have already used MatSetValues() to construct A.
> You can, and there would be no changes in serial if K is exactly the upper
> left block, but in parallel global indices would change.
> Q3) What are the advantages of using MatSetValuesLocal()? Is it that I can
> construct P directly using local indies and map the entrees to the global
> index in K?
> You have a monolithic K, so that you can use sparse direct solvers to
> check things. THis is impossible with separate storage.
> Q4) I probably don’t have to construct an independent P matrix
> You wouldn't in this case.
>   Thanks,
>      Matt
> Best regards,
> Karthik.
> *Date: *Tuesday, 18 April 2023 at 11:08
> On Tue, Apr 18, 2023 at 5:24 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I'm solving a problem using the Lagrange multiplier, the matrix has the
> form
> K = [A P^T
>        P   0]
> I am familiar with constructing K using MATMPIAIJ. However, I would like
> to know if had [A], can I augment it with [P], [P^T] and [0] of type
> MATMPIAIJ? Likewise for vectors as well.
> Can you please point me to the right resource, if it is a common operation
> in PETSc?
> You can do this at least 2 ways:
>   1) Assemble you submatrices directly into the larger matrix by
> constructing local-to-global maps for the emplacement. so that you do
>       not change your assembly code, except to change MatSetValues() to
> MatSetValuesLocal(). This is usually preferable.
>   2) Use MATNEST and VecNEST to put pointers to submatrices and subvectors
> directly in.
>   Thanks,
>      Matt
> Many thanks.
> Kind regards,
> Karthik.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230424/912c0f92/attachment.html>
