[petsc-users] issues with VecSetValues in petsc 3.19
Edoardo alinovi edoardo.alinovi at gmail.com
Thu Apr 20 10:06:48 CDT 2023
Hi Matt,
thanks for sharing the literature.
Would you suggest any monolitic approach for the mpiaij/mpibaij matrix
instead of fieldsplit?
I did some blind search using gamg/hypre and they look terribile. I guess i
am missing a trick, probaly they are not the way to go?
Thanks!
Il Lun 17 Apr 2023, 13:50 Matthew Knepley <knepley at gmail.com> ha scritto:
> On Mon, Apr 17, 2023 at 6:37 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
> wrote:
>> Sure thing, the solver I am working on is this one:
>> https://gitlab.com/alie89/flubio-code-fvm.
>> It is a 3D, collocated, unstructured, finite volume solver for
>> incompressibility NS. I can run steady, unsteady and I can use SIMPLE, PISO
>> and Factional step method (both explicit and fully implicit momentum). I
>> can also solve for turbulence (k-omega, BSL, SST, Spalart-Allmars, LES). I
>> have also implemented some kind of Immersed boundary (2D/3D) that I need to
>> resume at some point.
>> Hot topic of the moment, I am developing a fully coupled pressure based
>> solver using field-split. What I have now is working ok, I have validated
>> it on a lot of 2D problems and going on with 3D right now.  If all the
>> tests are passed, I'll focus on tuning the field splitting which looks to
>> be a quite interesting topic!
> I think a very good discussion of the issues from the point of view of FEM
> is
>    https://arxiv.org/abs/1810.03315
> There should be a similar analysis from the FVM side, although it might
> not be possible to
> find a pressure discretization compatible with the FVM velocity for this
> purpose.
>   Thanks,
>      Matt
>> Flubio is a project I have been carrying on since PhD days. The
>> implementation is 99% on my shoulders, despite the fact I am
>> collaborating with some people around. I am coding evenings and
>> weekends/free time, it gives me a lot of satisfaction and also a lot of
>> insights!
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230420/033dd419/attachment.html>
