[petsc-users] question about MatSetLocalToGlobalMapping
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Thu Apr 20 05:12:45 CDT 2023
Hello,
I created a new thread, thought would it be more appropriate (and is a continuation of my previous post). I want to construct the below K matrix (which is composed of submatrices)
K = [A P^T
       P   0]
Where K is of type MatMPIAIJ. I first constructed the top left [A] using MatSetValues().
Now, I would like to construct the bottom left [p] and top right [p^T] using MatSetValuesLocal().
To use  MatSetValuesLocal(),  I first have to create a local-to-global mapping using ISLocalToGlobalMappingCreate. I have created two mapping row_mapping and column_mapping.
Q1) At what point should I declare MatSetLocalToGlobalMapping – is it just before I use MatSetValuesLocal()?
I will use MatSetLocalToGlobalMapping(K, row_mapping, column_mapping) to build the bottom left [P].
Q2) Can now I reset the mapping as MatSetLocalToGlobalMapping(K, column_mapping, row_mapping) to build the top right [P^T]?
Many thanks!
Kind regards,
Karthik.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230420/4f7d4dea/attachment-0001.html>
