[petsc-users] PETSc error only in debug build
Matteo Semplice matteo.semplice at uninsubria.it
Mon Apr 17 11:35:10 CDT 2023
Adding PetscFunctionBeginUser indeed seems to fix this and moves the
error to the next function without PetscFunctionBeginUser...
Thanks!
Matteo
Il 17/04/23 18:27, Pierre Jolivet ha scritto:
> Non si ricevono spesso messaggi di posta elettronica da
> pierre.jolivet at lip6.fr. Informazioni sul perché è importante
> <https://aka.ms/LearnAboutSenderIdentification>
>> On 17 Apr 2023, at 6:22 PM, Matteo Semplice
>> <matteo.semplice at uninsubria.it> wrote:
>> Dear PETSc users,
>>     I am investigating a strange error occurring when using my code
>> on a cluster; I managed to reproduce it on my machine as well and
>> it's weird:
>> - on petsc3.19, optimized build, the code runs fine, serial and parallel
>> - on petsc 3,19, --with=debugging=1, the code crashes without giving
>> me a meaningful message. The output is
>> $ ../levelSet -options_file ../test.opts
>> Converting from ../pointClouds/2d/ptCloud_cerchio.txt in binary
>> format: this is slow!
>> Pass in the .info file instead!
>> Read 50 particles from ../pointClouds/2d/ptCloud_cerchio.txt
>> Bounding box: [-0.665297, 0.666667] x [-0.666324, 0.666324]
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Invalid stack size 0, pop convertCloudTxt
>> clouds.cpp:139.
>> [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
>> Could be the program crashed before they were used or a spell
>> ing mistake, etc!
>> [0]PETSC ERROR:   Option left: name:-delta value: 1.0 source: file
>> [0]PETSC ERROR:   Option left: name:-dx value: 0.1 source: file
>> [0]PETSC ERROR:   Option left: name:-extraCells value: 5 source: file
>> [0]PETSC ERROR:   Option left: name:-maxIter value: 200 source: file
>> [0]PETSC ERROR:   Option left: name:-p value: 1.0 source: file
>> [0]PETSC ERROR:   Option left: name:-tau value: 0.1 source: file
>> [0]PETSC ERROR:   Option left: name:-u0tresh value: 0.3 source: file
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.19.0, unknown
>> [0]PETSC ERROR: ../levelSet on a  named signalkuppe by matteo Mon Apr
>> 17 18:04:03 2023
>> [0]PETSC ERROR: Configure options --download-ml \ --with-metis
>> --with-parmetis \ --download-hdf5 \ --with-triangle --with-gmsh \ P
>> ETSC_DIR=/home/matteo/software/petsc --PETSC_ARCH=dbg
>> --with-debugging=1 --COPTFLAGS=-O --CXXOPTFLAGS=-O --FOPTFLAGS=-O
>> --prefix=/
>> home/matteo/software/petsc/3.19-dbg/
>> [0]PETSC ERROR: #1 convertCloudTxt() at clouds.cpp:139
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>> with errorcode 77.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Now, line 139 of clouds.cpp is PetscFunctionReturn(PETSC_SUCCESS), so
>> I cannot understand what is the offending operation in that routine.
>> (Note: this is a convertion routine and, skipping it, just make the
>> next routine fail in a similar way...)
>> My student has also tried to compile PETSc with
>> |--with-strict-petscerrorcode| and fixing all the compilation errors
>> that were raised, but it didn't help.
>> Do you have any guess on what to look for?
> There may be a PetscFunctionBeginUser; missing at the beginning of the
> convertCloudTxt() function.
> Could you double-check this?
> Thanks,
> Pierre
>> Bonus question to assess the cluster output what is the default value
>> for --with-debugging? I that option is not specified during PETSc
>> configure, does one get optimized or debug build?
>> Thanks
>>     Matteo
>> Professore Associato in Analisi Numerica
>> Dipartimento di Scienza e Alta Tecnologia
>> Università degli Studi dell'Insubria
>> Via Valleggio, 11 - Como
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/51735a9b/attachment-0001.html>
