[petsc-users] PETSc error only in debug build
Matteo Semplice matteo.semplice at uninsubria.it
Mon Apr 17 11:22:26 CDT 2023
Dear PETSc users,
     I am investigating a strange error occurring when using my code on
a cluster; I managed to reproduce it on my machine as well and it's weird:
- on petsc3.19, optimized build, the code runs fine, serial and parallel
- on petsc 3,19, --with=debugging=1, the code crashes without giving me
a meaningful message. The output is
$ ../levelSet -options_file ../test.opts
Converting from ../pointClouds/2d/ptCloud_cerchio.txt in binary format:
this is slow!
Pass in the .info file instead!
Read 50 particles from ../pointClouds/2d/ptCloud_cerchio.txt
Bounding box: [-0.665297, 0.666667] x [-0.666324, 0.666324]
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Invalid stack size 0, pop convertCloudTxt clouds.cpp:139.
[0]PETSC ERROR: WARNING! There are option(s) set that were not used!
Could be the program crashed before they were used or a spell
ing mistake, etc!
[0]PETSC ERROR:   Option left: name:-delta value: 1.0 source: file
[0]PETSC ERROR:   Option left: name:-dx value: 0.1 source: file
[0]PETSC ERROR:   Option left: name:-extraCells value: 5 source: file
[0]PETSC ERROR:   Option left: name:-maxIter value: 200 source: file
[0]PETSC ERROR:   Option left: name:-p value: 1.0 source: file
[0]PETSC ERROR:   Option left: name:-tau value: 0.1 source: file
[0]PETSC ERROR:   Option left: name:-u0tresh value: 0.3 source: file
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.19.0, unknown
[0]PETSC ERROR: ../levelSet on a  named signalkuppe by matteo Mon Apr 17
18:04:03 2023
[0]PETSC ERROR: Configure options --download-ml \ --with-metis
--with-parmetis \ --download-hdf5 \ --with-triangle --with-gmsh \ P
ETSC_DIR=/home/matteo/software/petsc --PETSC_ARCH=dbg --with-debugging=1
--COPTFLAGS=-O --CXXOPTFLAGS=-O --FOPTFLAGS=-O --prefix=/
home/matteo/software/petsc/3.19-dbg/
[0]PETSC ERROR: #1 convertCloudTxt() at clouds.cpp:139
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
with errorcode 77.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Now, line 139 of clouds.cpp is PetscFunctionReturn(PETSC_SUCCESS), so I
cannot understand what is the offending operation in that routine.
(Note: this is a convertion routine and, skipping it, just make the next
routine fail in a similar way...)
My student has also tried to compile PETSc with
|--with-strict-petscerrorcode| and fixing all the compilation errors
that were raised, but it didn't help.
Do you have any guess on what to look for?
Bonus question to assess the cluster output what is the default value
for --with-debugging? I that option is not specified during PETSc
configure, does one get optimized or debug build?
Thanks
     Matteo
Professore Associato in Analisi Numerica
Dipartimento di Scienza e Alta Tecnologia
Università degli Studi dell'Insubria
Via Valleggio, 11 - Como
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/632f7bac/attachment-0001.html>
