[petsc-users] issues with VecSetValues in petsc 3.19
Mon Apr 17 05:03:07 CDT 2023
On Mon, Apr 17, 2023 at 6:00 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Hey Matt,
> Thanks for the help. Here is the error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Not for unassembled vector, did you call
> VecAssemblyBegin()/VecAssemblyEnd()?
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_ksp_rtol value:
> 0.10000000000000000E-0001 source: code
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value:
> hypre source: code
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_ksp_rtol value:
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value:
> bjacobi source: code
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.19.0, unknown
> [0]PETSC ERROR: flubio_coupled on a arch-gnu named betelgeuse by edo Mon
> Apr 17 12:05:28 2023
> [0]PETSC ERROR: Configure options PETSC_ARCH=arch-gnu FOPTFLAGS=-O3
> COPTFLAGS=-O3 CXXOPTFLAGS=-O3 -with-debugging=no
> -with-mpi-dir=/home/edo/user_software_repository/openmpi-4.1.2/build
> -download-fblaslapack=1 -download-superlu_dist -download-mumps
> -download-hypre -download-metis -download-parmetis -download-scalapack
> --download-ml -download-slepc -download-spai -download-fftw
> [0]PETSC ERROR: #1 MatMult() at
> /home/edo/user_software_repository/petsc/src/mat/interface/matrix.c:2557
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Object is in wrong state
> [1]PETSC ERROR: Not for unassembled vector, did you call
> [1]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> [1]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_ksp_rtol value:
> [1]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value:
> hypre source: code
> [1]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_ksp_rtol value:
> [1]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value:
> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.19.0, unknown
> [1]PETSC ERROR: flubio_coupled on a arch-gnu named betelgeuse by edo Mon
> [1]PETSC ERROR: Configure options PETSC_ARCH=arch-gnu FOPTFLAGS=-O3
> [1]PETSC ERROR: #1 MatMult() at
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Object is in wrong state
> [2]PETSC ERROR: Not for unassembled vector, did you call
> [2]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> [2]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_ksp_rtol value:
> [2]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value:
> hypre source: code
> [2]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_ksp_rtol value:
> [2]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value:
> [2]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Object is in wrong state
> [3]PETSC ERROR: Not for unassembled vector, did you call
> [3]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> [3]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_ksp_rtol value:
> [3]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value:
> hypre source: code
> [3]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_ksp_rtol value:
> [3]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value:
> [2]PETSC ERROR: Petsc Release Version 3.19.0, unknown
> [2]PETSC ERROR: flubio_coupled on a arch-gnu named betelgeuse by edo Mon
> [2]PETSC ERROR: Configure options PETSC_ARCH=arch-gnu FOPTFLAGS=-O3
> [3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [3]PETSC ERROR: Petsc Release Version 3.19.0, unknown
> [3]PETSC ERROR: flubio_coupled on a arch-gnu named betelgeuse by edo Mon
> [3]PETSC ERROR: Configure options PETSC_ARCH=arch-gnu FOPTFLAGS=-O3
> [2]PETSC ERROR: #1 MatMult() at
> [3]PETSC ERROR: #1 MatMult() at
> Here the way I am doing:
>         ! Duplicate vector
>         call VecDuplicate(this%rhs, x, ierr)
>         call VecZeroEntries(x, ierr)
>         call VecDuplicate(this%rhs, vres, ierr)
>         ! Set the current solution
>         call VecSetValues(x, numberOfElements, mesh%cellGlobalAddr-1,
> field%phi(1:numberOfElements,iComp), INSERT_VALUES, ierr)
After VecSetValues(), you must call VecAssemblyBegin/End().
    Matt
>         call flubioStopMsg('HELLO')
> cheers
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/8ae0361f/attachment-0001.html>
