[petsc-users] issues with VecSetValues in petsc 3.19
Mon Apr 17 04:40:35 CDT 2023
On Mon, Apr 17, 2023 at 5:36 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Hello Barry, Matt, Jed,
> I have just installed the latest and greatest version of petsc and I am
> hitting a problem I did not have in previous releases.
> Here is the error:
> *[1]PETSC ERROR: --------------------- Error Message
> --------------------------------------------------------------[1]PETSC
> ERROR: Object is in wrong state[1]PETSC ERROR: Not for unassembled vector,
> did you call VecAssemblyBegin()/VecAssemblyEnd()?[1]PETSC ERROR: WARNING!
> There are option(s) set that were not used! Could be the program crashed
> before they were used or a spelling mistake, etc!*
> the vector x I am filling is created with:
>    - call VecDuplicate(this%rhs, x, ierr)
> rhs is allocated and I called VecAssemblyBegin()/VecAssemblyEnd() on, do I
> need to call it on duplicated vectors as well now on?
Only if you change the values. Can you show the entire stack from the error
message?
     Matt
> Thank you!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230417/866569b6/attachment-0001.html>
