[petsc-users] Installation issue of 3.18.* and 3.19.0 on Apple systems
Kaus, Boris kaus at uni-mainz.de
Wed Apr 5 15:44:55 CDT 2023
That gives this:
sandbox:${WORKSPACE}/srcdir/petsc-3.18.0 # ./configure --prefix=/workspace/destdir/lib/petsc/double_real_Int32/
['--prefix=/workspace/destdir/lib/petsc/double_real_Int32/']
    TypeError or ValueError possibly related to ERROR in COMMAND LINE ARGUMENT while running ./configure
invalid literal for int() with base 10: ''
> On 5. Apr 2023, at 22:38, Satish Balay <balay at mcs.anl.gov> wrote:
> Is it possible some unicode chars are in configure options?
> Perhaps debug with:
> diff --git a/config/configure.py b/config/configure.py
> index e00a7a9617c..a95483b61a5 100755
> --- a/config/configure.py
> +++ b/config/configure.py
> @@ -455,6 +455,7 @@ def petsc_configure(configure_options):
>   tbo = None
>   framework = None
>   try:
> +    print(sys.argv[1:])
>     framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:], loadArgDB = 0)
>     framework.setup()
>     framework.logPrintBox('Configuring PETSc to compile on your system')
> [Note the error message is printed further below]
> Satish
> On Wed, 5 Apr 2023, Stefano Zampini wrote:
>> It seems there's some typo/error in the configure command that is being
>> executed. Can you post it here?
>> Il giorno mer 5 apr 2023 alle ore 23:18 Kaus, Boris <kaus at uni-mainz.de> ha
>> scritto:
>>> Hi everyone,
>>> I’m trying to install precompiled binaries for PETSc 3.18.5 & 3.19.0 using
>>> the BinaryBuilder cross-compilation:
>>> https://github.com/JuliaPackaging/Yggdrasil/pull/6533, which mostly works
>>> fine: https://buildkite.com/julialang/yggdrasil/builds/2093).
>>> Yet, on apple systems I receive a somewhat weird bug during the configure
>>> step:
>>> [22:08:49]
>>> [22:08:49]     TypeError or ValueError possibly related to ERROR in
>>> [22:08:49]
>>> [22:08:49] invalid literal for int() with base 10: ''
>>> [22:08:49]
>>> [22:08:49]
>>> [22:08:49]
>>> [22:08:49] /workspace/srcdir/petsc-3.18.0/lib/petsc/conf/rules:860:
>>> /workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscrules: No such file or
>>> directory
>>> [22:08:49] make[1]: *** No rule to make target
>>> '/workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscrules'.  Stop.
>>> directory
>>> [22:08:49] make: *** [GNUmakefile:17:
>>> /workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscvariables] Error 2
>>> [22:08:49] make: *** Waiting for unfinished jobs....
>>> [22:08:49] make: *** [GNUmakefile:17: lib/petsc/conf/petscvariables] Error
>>> 2
>>> The log file is rather brief:
>>> sandbox:${WORKSPACE}/srcdir/petsc-3.18.0 # more configure.log
>>> Executing: uname -s
>>> stdout: Darwin
>>> It works fine for PETSc 3.16.5/3.17.5, and this first occurs in 3.18.0.
>>> Is there something that changed between 3.17 & 3.18 that could cause this?
>>> The build system seems to use python3.9 (3.4+ as required)
>>> Thanks!
>>> Boris
