[petsc-users] Strange mpi timing and CPU load when -np > 2
Duan Junming junming.duan at epfl.ch
Mon Sep 26 11:39:52 CDT 2022
Dear all,
I am using PETSc 3.17.4 on a Linux server, compiling with --download-exodus --download-hdf5 --download-openmpi --download-triangle --with-fc=0 --with-debugging=0 PETSC_ARCH=arch-linux-c-opt COPTFLAGS="-g -O3" CXXOPTFLAGS="-g -O3".
The strange thing is when I run my code with mpirun -np 1 ./main, the CPU time is 30s.
When I use mpirun -np 2 ./main, the CPU time is 16s. It's OK.
But when I use more than 2 CPUs, like mpirun -np 3 ./main, the CPU time is 30s.
The output of command time is: real 0m30.189s, user 9m3.133s, sys 10m55.715s.
I can also see that the CPU load is about 100% for each process when np = 2, but the CPU load goes to 2000%, 1000%, 1000% for each process (the server has 40 CPUs).
Do you have any idea about this?
Thanks in advance!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220926/eb3b2f71/attachment.html>
