[petsc-users] KSP on GPU
Sun Oct 30 15:59:42 CDT 2022
On Sun, Oct 30, 2022 at 3:52 PM Barry Smith <bsmith at petsc.dev> wrote:
>    In general you should expect similar but not identical conference
> behavior.
>     I suggest running with all the monitoring you can.
> -ksp_monitor_true_residual
> -fieldsplit_0_monitor_true_residual -fieldsplit_1_monitor_true_residual and
> compare the various convergence between the CPU and GPU. Also run with
> -ksp_view and check that the various solver options are the same (they
> should be).
Is the GPU using float or double?
   Matt
>   Barry
> On Oct 30, 2022, at 11:02 AM, Carl-Johan Thore via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi,
> I'm solving a topology optimization problem with Stokes flow discretized
> by a stabilized Q1-Q0 finite element method
> and using BiCGStab with the fieldsplit preconditioner to solve the linear
> systems. The implementation
> is based on DMStag, runs on Ubuntu via WSL2, and works fine with
> PETSc-3.18.1 on multiple CPU cores and the following
> options for the preconditioner:
> -fieldsplit_0_ksp_type preonly \
> -fieldsplit_0_pc_type gamg \
> -fieldsplit_0_pc_gamg_reuse_interpolation 0 \
> -fieldsplit_1_ksp_type preonly \
> -fieldsplit_1_pc_type jacobi
> However, when I enable GPU computations by adding two options -
> -dm_vec_type cuda \
> -dm_mat_type aijcusparse \
> - KSP still works fine the first couple of topology optimization
> iterations but then
> stops with "Linear solve did not converge due to DIVERGED_DTOL ..".
> My question is whether I should expect the GPU versions of the linear
> solvers and pre-conditioners
> to function exactly as their CPU counterparts (I got this impression from
> the documentation),
> in which case I've probably made some mistake in my own code, or whether
> there are other/additional
> settings or modifications I should use to run on the GPU (an NVIDIA Quadro
> T2000)?
> Kind regards,
> Carl-Johan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221030/fe393be2/attachment.html>
