[petsc-users] About MatMumpsSetIcntl function
김성익 ksi2443 at gmail.com
Wed Nov 30 09:01:30 CST 2022
Following your comments my options are as below.
mpirun -np 3 ./app -mpi_linear_solver_server -mpi_linear_solver_server_view
-pc_type mpi -ksp_type preonly -mpi_ksp_monitor -mpi_ksp_converged_reason
-mpi_pc_type lu -pc_mpi_always_use_server -ksp_monitor_true_residual
-ksp_converged_reason -ksp_view -mat_mumps_icntl_7 5
and the outputs are as below.
  Residual norms for mpi_ solve.
  0 KSP Residual norm 3.941360585078e-05
  1 KSP Residual norm 3.325311951792e-20
Linear mpi_ solve converged due to CONVERGED_RTOL iterations 1
  0 KSP none resid norm 2.000000000000e+00 true resid norm
5.241047207555e-16 ||r(i)||/||b|| 2.620523603778e-16
  1 KSP none resid norm 5.241047207555e-16 true resid norm
KSP Object: 1 MPI process
  type: preonly
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  left preconditioning
  using NONE norm type for convergence test
PC Object: 1 MPI process
  type: mpi
  Size of MPI communicator used for MPI parallel KSP solve 1
  Desired minimum number of nonzeros per rank for MPI parallel solve 10000
  *** Use -mpi_ksp_view to see the MPI KSP parameters ***
  *** Use -mpi_linear_solver_server_view to statistics on all the solves ***
  linear system matrix = precond matrix:
  Mat Object: 1 MPI process
    type: seqaij
    rows=24, cols=24
    total: nonzeros=576, allocated nonzeros=840
    total number of mallocs used during MatSetValues calls=48
      using I-node routines: found 5 nodes, limit used is 5
Solving Time : 0.003143sec
Assemble Time : 0.000994sec
  TIME : 1.000000,     TIME_STEP : 1.000000,      ITER : 2,     RESIDUAL :
5.889432e-09
 TIME0 : 1.000000
MPI linear solver server statistics:
    Ranks        KSPSolve()s     Mats        KSPs       Avg. Size      Avg.
Its
     1               1            1           1            24            1
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There is one unused database option. It is:
Option left: name:-mat_mumps_icntl_7 value: 5
2022년 11월 30일 (수) 오후 11:54, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Nov 30, 2022 at 9:31 AM 김성익 <ksi2443 at gmail.com> wrote:
>> After folloing the comment,  ./app -pc_type lu -ksp_type preonly
>> -ksp_monitor_true_residual -ksp_converged_reason -ksp_view
> Okay, you can see that it is using METIS:
>               INFOG(7) (ordering option effectively used after analysis): 5
> It looks like the server stuff was not seeing the option. Put it back in
> and send the output.
>   Thanks,
>      Matt
> The outputs are as below.
>> 4.241815708566e-16 ||r(i)||/||b|| 2.120907854283e-16
>>   1 KSP none resid norm 4.241815708566e-16 true resid norm
>> Linear solve converged due to CONVERGED_ITS iterations 1
>>   type: preonly
>>   type: lu
>>     out-of-place factorization
>>     tolerance for zero pivot 2.22045e-14
>>     matrix ordering: external
>>     factor fill ratio given 0., needed 0.
>>       Factored matrix follows:
>>           type: mumps
>>           rows=24, cols=24
>>           package used to perform factorization: mumps
>>           total: nonzeros=576, allocated nonzeros=576
>>             MUMPS run parameters:
>>               Use -ksp_view ::ascii_info_detail to display information
>> for all processes
>>               RINFOG(1) (global estimated flops for the elimination after
>> analysis): 8924.
>>               RINFOG(2) (global estimated flops for the assembly after
>> factorization): 0.
>>               RINFOG(3) (global estimated flops for the elimination after
>> factorization): 8924.
>>               (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>> (0.,0.)*(2^0)
>>               INFOG(3) (estimated real workspace for factors on all
>> processors after analysis): 576
>>               INFOG(4) (estimated integer workspace for factors on all
>> processors after analysis): 68
>>               INFOG(5) (estimated maximum front size in the complete
>> tree): 24
>>               INFOG(6) (number of nodes in the complete tree): 1
>> 5
>>               INFOG(8) (structural symmetry in percent of the permuted
>> matrix after analysis): 100
>>               INFOG(9) (total real/complex workspace to store the matrix
>> factors after factorization): 576
>>               INFOG(10) (total integer space store the matrix factors
>> after factorization): 68
>>               INFOG(11) (order of largest frontal matrix after
>> factorization): 24
>>               INFOG(12) (number of off-diagonal pivots): 0
>>               INFOG(13) (number of delayed pivots after factorization): 0
>>               INFOG(14) (number of memory compress after factorization): 0
>>               INFOG(15) (number of steps of iterative refinement after
>> solution): 0
>>               INFOG(16) (estimated size (in MB) of all MUMPS internal
>> data for factorization after analysis: value on the most memory consuming
>> processor): 0
>>               INFOG(17) (estimated size of all MUMPS internal data for
>> factorization after analysis: sum over all processors): 0
>>               INFOG(18) (size of all MUMPS internal data allocated during
>> factorization: value on the most memory consuming processor): 0
>>               INFOG(19) (size of all MUMPS internal data allocated during
>> factorization: sum over all processors): 0
>>               INFOG(20) (estimated number of entries in the factors): 576
>>               INFOG(21) (size in MB of memory effectively used during
>> factorization - value on the most memory consuming processor): 0
>>               INFOG(22) (size in MB of memory effectively used during
>> factorization - sum over all processors): 0
>>               INFOG(23) (after analysis: value of ICNTL(6) effectively
>> used): 0
>>               INFOG(24) (after analysis: value of ICNTL(12) effectively
>> used): 1
>>               INFOG(25) (after factorization: number of pivots modified
>> by static pivoting): 0
>>               INFOG(28) (after factorization: number of null pivots
>> encountered): 0
>>               INFOG(29) (after factorization: effective number of entries
>> in the factors (sum over all processors)): 576
>>               INFOG(30, 31) (after solution: size in Mbytes of memory
>> used during solution phase): 0, 0
>>               INFOG(32) (after analysis: type of analysis done): 1
>>               INFOG(33) (value used for ICNTL(8)): 7
>>               INFOG(34) (exponent of the determinant if determinant is
>> requested): 0
>>               INFOG(35) (after factorization: number of entries taking
>> into account BLR factor compression - sum over all processors): 576
>>               INFOG(36) (after analysis: estimated size of all MUMPS
>> internal data for running BLR in-core - value on the most memory consuming
>> processor): 0
>>               INFOG(37) (after analysis: estimated size of all MUMPS
>> internal data for running BLR in-core - sum over all processors): 0
>>               INFOG(38) (after analysis: estimated size of all MUMPS
>> internal data for running BLR out-of-core - value on the most memory
>>               INFOG(39) (after analysis: estimated size of all MUMPS
>> internal data for running BLR out-of-core - sum over all processors): 0
>>     type: seqaij
>>     rows=24, cols=24
>> 2022년 11월 30일 (수) 오후 11:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Wed, Nov 30, 2022 at 9:20 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> In my code there are below.
>>>> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
>>>> PetscCall(KSPSetOperators(ksp, xGK, xGK));
>>>> PetscCall(KSPGetPC(ksp, &pc));
>>>> PetscCall(PCSetType(pc, PCLU));
>>>> PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
>>>> PetscCall(KSPSetFromOptions(ksp));
>>>> and my runtime options are as below.
>>>> -mpi_linear_solver_server_view -pc_type mpi -ksp_type preonly
>>>> -mpi_ksp_monitor -mpi_ksp_converged_reason -mpi_pc_type lu
>>>> -pc_mpi_always_use_server -mat_mumps_icntl_7 5
>>> 1) Get rid of the all server stuff until we see what is wrong with your
>>> code
>>> 2) Always run in serial until it works
>>>   ./app -pc_type lu -ksp_type preonly -ksp_monitor_true_residual
>>> Send the output so we can see what the solver is.
>>>   Thanks,
>>>      Matt
>>> 2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>> When I adopt icntl by using option, the outputs are as below.
>>>>>> Is it work??
>>>>> Are you calling KSPSetFromOptions() after the PC is created?
>>>>>   -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Hyung Kim
>>>>>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>> I'm working on FEM.
>>>>>>>>   When I used mumps alone, I fount it efficient to use mumps with
>>>>>>>> metis.
>>>>>>>> So my purpose is using MUMPSsolver with METIS.
>>>>>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly
>>>>>>>> and just before kspsolve.
>>>>>>>> However there is error because of 'pcfactorgetmatrix' and
>>>>>>>> 'matmumpsseticntl'.
>>>>>>>> How can I fix this?
>>>>>>> Give the Icntrl as an option.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thanks,
>>>>>>>> Hyung Kim
>>>>>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com>님이
>>>>>>>> 작성:
>>>>>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>>>>>> Following your comments,
>>>>>>>>>> After matrix assembly end,
>>>>>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>>>>>> However there is another error as below.
>>>>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>>>>>> The error message is telling you that you cannot alter values in
>>>>>>>>> the factored matrix. This is because
>>>>>>>>> the direct solvers use their own internal storage formats which we
>>>>>>>>> cannot alter, and you should probably
>>>>>>>>> not alter either.
>>>>>>>>> What are you trying to do?
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>>>>> shooting.
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by
>>>>>>>>>> ksi2443 Wed Nov 30 05:37:52 2022
>>>>>>>>>> [0]PETSC ERROR: Configure options -download-mumps
>>>>>>>>>> -download-scalapack -download-parmetis -download-metis
>>>>>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at
>>>>>>>>>> /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>>>>>> [0]PETSC ERROR: #2 main() at
>>>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:339
>>>>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>>>>> How can I fix this?
>>>>>>>>>> Thanks,
>>>>>>>>>> Hyung Kim
>>>>>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es>님이
>>>>>>>>>> 작성:
>>>>>>>>>>> You have to call PCFactorGetMatrix() first. See any of the
>>>>>>>>>>> examples that use MatMumpsSetIcntl(), for instance
>>>>>>>>>>> https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>>>>>> Jose
>>>>>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com> escribió:
>>>>>>>>>>> > Hello,
>>>>>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>>>>>> > However, there is an error as follows
>>>>>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>>>>>> trouble shooting.
>>>>>>>>>>> ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at
>>>>>>>>>>> /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>>>>>> /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>>>>>> > How can I fix this error?
>>>>>>>>>>> > Thank you for your help.
>>>>>>>>>>> > Hyung Kim
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221201/2a066dc9/attachment-0001.html>
