[petsc-users] (no subject)
Mark Adams mfadams at lbl.gov
Thu Feb 17 11:59:22 CST 2022
Please keep on list,
On Thu, Feb 17, 2022 at 12:36 PM Bojan Niceno <
bojan.niceno.scientist at gmail.com> wrote:
> Dear Mark,
> Sorry for mistakenly calling you Adam before.
> I was thinking about the o_nnz as you suggested, but then something else
> occurred to me.  So, I determine the d_nnz and o_nnz based on METIS domain
> decomposition which I perform outside of PETSc, before I even call PETSc
> initialize.  Hence, if PETSc works out its own domain decomposition
PETSc does not work out its own decomposition. You specify the
decomposition completely with
https://petsc.org/main/docs/manualpages/Mat/MatCreateAIJ.html#MatCreateAIJ
> and communication patterns, they might be different from mine, and
> therefore MatSetValue misses some entries.  Will PETSc follow the same
> domain decomposition which it works from calls to MatSetValue from
> different processors, or will it re-shuffle the matrix entries?
>     Cheers,
>     Bojan
> On Thu, Feb 17, 2022 at 6:14 PM Bojan Niceno <
>> Thanks a lot for the hints Adam :-)
>>     Cheers,
>>     Bojan
>> On Thu, Feb 17, 2022 at 6:05 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Thu, Feb 17, 2022 at 11:46 AM Bojan Niceno <
>>>> Dear all,
>>>> I am experiencing difficulties when using PETSc in parallel in an
>>>> unstructured CFD code.  It uses CRS format to store its matrices.  I use
>>>> the following sequence of PETSc call in the hope to get PETSc solving my
>>>> linear systems in parallel.  Before I continue, I would just like to say
>>>> that the code is MPI parallel since long time ago, and performs its own
>>>> domain decomposition through METIS, and it works out its communication
>>>> patterns which work with its home-grown (non-PETSc) linear solvers.
>>>> Anyhow, I issue the following calls:
>>>> err = PetscInitialize(0, NULL, (char*)0, help);
>>>> err = MatCreate(MPI_COMM_WORLD, A);
>>>> In the above, I use MPI_COMM_WORLD instead of PETSC_COMM_SELF because
>>>> the call to MPI_Init is invoked outside of PETSc, from the main program.
>>>> err = MatSetSizes(A, m, m, M, M);
>>>> Since my matrices are exclusively square, M is set to the total number
>>>> of computational cells, while m is equal to the number of computational
>>>> cells within each subdomain/processor.  (Not all processors necessarily
>>>> have the same m, it depends on domain decomposition.)  I do not distinguish
>>>> between m (M) and n (N) since matrices are all square.  Am I wrong to
>>>> assume that?
>>>> err = MatSetType(A, MATAIJ);
>>>> I set the matrix to be of type MATAIJ, to cover runs on one and on more
>>>> processors.  By the way, on one processors everything works fine
>>>> err = MatMPIAIJSetPreallocation(A, 0, d_nnz, 0, o_nnz);
>>>> err = MatSeqAIJSetPreallocation(A, 0, d_nnz);
>>>> The two lines above specify matrix preallocation.  Since d_nz and o_nz
>>>> vary from cell to cell (row to row), I set them to zero and provide arrays
>>>> with number of diagonal and off diagonal zeroes instead.  To my
>>>> understanding, that is legit since d_nz and o_nz are neglected if d_nnz and
>>>> o_nnz are provided.  Am I wrong?
>>>> Finally, inside a loop through rows and columns I call:
>>>> err = MatSetValue(A, row, col, value, INSERT_VALUES);
>>>> Here I make sure that row and col point to global cell (unknown)
>>>> numbers.
>>>> Yet, when I run the code on more than one processor, I get the error:
>>>> [3]PETSC ERROR: --------------------- Error Message
>>>> [3]PETSC ERROR: Argument out of range
>>>> [3]PETSC ERROR: New nonzero at (21,356) caused a malloc
>>>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
>>>> turn off this check
>>>> [3]PETSC ERROR: #1 MatSetValues_MPIAIJ() at
>>>> /home/niceno/Development/petsc-debug/src/mat/impls/aij/mpi/mpiaij.c:517
>>>> [3]PETSC ERROR: #2 MatSetValues() at
>>>> /home/niceno/Development/petsc-debug/src/mat/interface/matrix.c:1398
>>>> [3]PETSC ERROR: #3 MatSetValues_MPIAIJ() at
>>>> [3]PETSC ERROR: #4 MatSetValues() at
>>>> and so forth, for roughly 10% of all matrix entries.  I checked if
>>>> these errors occur only for off-diagonal parts of the matrix entries, but
>>>> that is not the case.
>>>> Error code is 63; PETSC_ERR_ARG_OUTOFRANGE
>>>> Does anyone have an idea what am I doing wrong?  Is any of my
>>>> assumptions above (like thinking n(N) is always m(M) for square matrices,
>>>> that I can send zeros as d_nz and o_nz if I provide arrays d_nnz[] and
>>>> o_nnz[] wrong?
>>> That is correct.
>>>> Any idea how to debug it, where to look for an error?
>>> I would guess that you are counting your o_nnz  incorrectly. It looks
>>> like a small number of equations per process because the 4th process has
>>> row 21, apparently. Does that sound right?
>>> And column 356 is going to be in the off-diagonal block (ie, "o").  I
>>> would start with a serial matrix and run with -info. This will be noisy but
>>> you will see things like"number of unneeded..." that you can verify that
>>> you have set d_nnz perfectly (there should be 0 unneeded).
>>> Then try two processors. If it fails you could a print statement in
>>> everytime the row (eg, 21) is added to and check what your code for
>>> computing o_nnz is doing.
>>> I am carefully checking all the data I send to PETSc functions and looks
>>>> correct to me, but maybe I lack some fundamental understanding of what
>>>> should be provided to PETSc, as I write above?
>>> It is a bit confusing at first. The man page gives a concrete example
>>>>     Best regards,
>>>>     Bojan Niceno
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220217/91fcd711/attachment.html>
