[petsc-users] dmplex normal vector incorrect for periodic gmsh grids
Tue Dec 13 13:21:49 CST 2022
On Tue, Dec 13, 2022 at 10:57 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 13, 2022 at 6:11 AM Praveen C <praveen at gmx.net> wrote:
>> Hello
>> In the attached test, I read a small grid made in gmsh with periodic bc.
>> This is a 2d mesh.
>> The cell numbers are shown in the figure.
>> All faces have length = 2.5
>> But using PetscFVFaceGeom I am getting length of 7.5 for some faces.
>> E.g.,
>> face: 59, centroid = 3.750000, 2.500000, normal = 0.000000, -7.500000
>> ===> Face length incorrect = 7.500000, should be 2.5
>> support[0] = 11, cent = 8.750000, 3.750000, area = 6.250000
>> support[1] = 15, cent = 8.750000, 1.250000, area = 6.250000
>> There are also errors in the orientation of normal.
>> If we disable periodicity in geo file, this error goes away.
> Yes, by default we only localize coordinates for cells. I can put in code
> to localize faces.
Okay, I now have a MR for this:
https://gitlab.com/petsc/petsc/-/merge_requests/5917
I am attaching your code, slightly modified. You can run
  ./dmplex -malloc_debug 0 -dm_plex_box_upper 10,10 -dm_plex_box_faces 4,4
-dm_plex_simplex 0 -dm_view ::ascii_info_detail -draw_pause 3
-dm_plex_box_bd periodic,periodic -dm_localize_height 0
which shows incorrect edges and
-dm_plex_box_bd periodic,periodic -dm_localize_height 1
which is correct. If you want to control things yourself, instead of using
the option you can call DMPlexSetMaxProjectionHeight() on the coordinate DM
yourself.
     Matt
>   Thanks,
>     Matt
>> Thanks
>> praveen
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/b9e6c4c3/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/b9e6c4c3/attachment-0001.obj>
