[petsc-users] MatSetNullSpace results in nan with MUMPS
Bhargav Subramanya bhargav.subramanya at kaust.edu.sa
Sat Apr 2 19:59:23 CDT 2022
Dear All,
I am trying to solve Ax = b in parallel using MUMPS, where x is composed of
velocity, pressure, and temperature. There is a null space due to the
homogeneous Neumann pressure boundary conditions.
1. Without explicitly removing the null space, the solution is bounded and
robust, and I am able to iterate in time, although I need to check if the
solution is physically correct. I am not sure if MUMPS is able to
detect the null space in this case.
2. However, when I explicitly use MatSetNullSpace as shown below, the
solution blows up in 2-3 temporal iterations, resulting in nan. Could you
please share your thoughts regarding this problem?
Bhargav
Output for -pc_type svd -pc_svd_monitor
SVD: condition number 3.159257564649e+16, 1 of 1080 singular values are
(nearly) zero
    SVD: smallest singular values: 3.693890048955e-17 2.902795363876e-10
2.902795486255e-10 2.902796682780e-10 7.614221123356e-10
    SVD: largest singular values : 1.166981958972e+00 1.166981958972e+00
1.166995008014e+00 1.166995008014e+00 1.166995008014e+00
PetscErrorCode *SetNullVector*(Mat MatGlobalLinear,Mesh mesh,Equations eq){
Vec NullVector;
PetscInt numNullVectors,disp,i,j;
PetscScalar constantValue = 1.0,nrm;
MatNullSpace NullSp = NULL;
PetscErrorCode ierr;
PetscFunctionBeginUser;
numNullVectors = 1;
disp = mesh.numLayers*mesh.numEdges + (eq.pressure-1)*mesh.numCells;
ierr = *MatCreateVecs*(MatGlobalLinear,&NullVector,NULL);CHKERRQ(ierr);
*for*(i=0; i<mesh.numLayers; i++){
*for*(j=0; j<mesh.numCells; j++){
ierr = VecSetValue(NullVector,j + i*mesh.numCells + disp,constantValue,
*INSERT_VALUES*);CHKERRQ(ierr);
ierr = *VecAssemblyBegin*(NullVector);CHKERRQ(ierr);
ierr = *VecAssemblyEnd*(NullVector);CHKERRQ(ierr);
ierr = *VecNorm*(NullVector,*NORM_2*,&nrm);CHKERRQ(ierr);
ierr = *VecScale*(NullVector,1.0/nrm);CHKERRQ(ierr);
/* set null space */
ierr = *MatNullSpaceCreate*(MPI_COMM_WORLD,*PETSC_FALSE*
,numNullVectors,&NullVector,&NullSp);CHKERRQ(ierr);
ierr = *MatSetNullSpace*(MatGlobalLinear,NullSp);CHKERRQ(ierr);
/* clean up */
ierr = *MatNullSpaceDestroy*(&NullSp);CHKERRQ(ierr);
ierr = *VecDestroy*(&NullVector);CHKERRQ(ierr);
PetscFunctionReturn(0);
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220403/8cd40cfb/attachment.html>
