[petsc-users] DMPlex in Firedrake: scaling of mesh distribution
Mark Adams mfadams at lbl.gov
Sun Mar 7 07:27:58 CST 2021
FWIW, Here is the output from ex13 on 32K processes (8K Fugaku
nodes/sockets, 4 MPI/node, which seems recommended) with 128^3 vertex mesh
(64^3 Q2 3D Laplacian).
Almost an hour.
Attached is solver scaling.
  0 SNES Function norm 3.658334849208e+00
  Linear solve converged due to CONVERGED_RTOL iterations 22
  1 SNES Function norm 1.609000373074e-12
Nonlinear solve converged due to CONVERGED_ITS iterations 1
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
-fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary:
../ex13 on a  named i07-4008c with 32768 processors, by a04199 Fri Feb 12
23:27:13 2021
Using Petsc Development GIT revision: v3.14.4-579-g4cb72fa  GIT Date:
2021-02-05 15:19:40 +0000
                         Max       Max/Min     Avg       Total
Time (sec):           3.373e+03     1.000   3.373e+03
Objects:              1.055e+05    14.797   7.144e+03
Flop:                 5.376e+10     1.176   4.885e+10  1.601e+15
Flop/sec:             1.594e+07     1.176   1.448e+07  4.745e+11
MPI Messages:         6.048e+05    30.010   8.833e+04  2.894e+09
MPI Message Lengths:  1.127e+09     4.132   6.660e+03  1.928e+13
MPI Reductions:       1.824e+03     1.000
Flop counting convention: 1 flop = 1 real number operation of type
(multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N
--> 2N flop
                            and VecAXPY() for complex vectors of length N
--> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---
 -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total
 0:      Main Stage: 3.2903e+03  97.5%  2.4753e+14  15.5%  3.538e+08  12.2%
 1.779e+04       32.7%  9.870e+02  54.1%
 1:         PCSetUp: 4.3062e+01   1.3%  1.8160e+13   1.1%  1.902e+07   0.7%
 3.714e+04        3.7%  1.590e+02   8.7%
 2:  KSP Solve only: 3.9685e+01   1.2%  1.3349e+15  83.4%  2.522e+09  87.1%
 4.868e+03       63.7%  6.700e+02  36.7%
See the 'Profiling' chapter of the users' manual for details on
interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and
PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this
phase
      %M - percent messages in this phase     %L - percent message lengths
in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
all processors)
Event                Count      Time (sec)     Flop
     --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
 Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
PetscBarrier           5 1.0 1.9907e+00 2.2 0.00e+00 0.0 3.8e+06 7.7e+01
2.0e+01  0  0  0  0  1   0  0  1  0  2     0
BuildTwoSided         62 1.0 7.3272e+0214.1 0.00e+00 0.0 6.7e+06 8.0e+00
0.0e+00  5  0  0  0  0   5  0  2  0  0     0
BuildTwoSidedF        59 1.0 3.1132e+01 7.4 0.00e+00 0.0 4.8e+06 2.5e+05
0.0e+00  0  0  0  6  0   0  0  1 19  0     0
SNESSolve              1 1.0 1.7468e+02 1.0 7.83e+09 1.3 3.4e+08 1.3e+04
8.8e+02  5 13 12 23 48   5 85 96 70 89 1205779
SNESSetUp              1 1.0 2.4195e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05
1.3e+01  1  0  0  7  1   1  0  1 22  1     0
SNESFunctionEval       3 1.0 1.1359e+01 1.2 1.17e+09 1.0 1.6e+06 1.4e+04
2.0e+00  0  2  0  0  0   0 15  0  0  0 3344744
SNESJacobianEval       2 1.0 1.6829e+02 1.0 1.52e+09 1.0 1.1e+06 8.3e+05
0.0e+00  5  3  0  5  0   5 20  0 14  0 293588
DMCreateMat            1 1.0 2.4107e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05
Mesh Partition         1 1.0 5.0133e+02 1.0 0.00e+00 0.0 1.3e+05 2.7e+02
6.0e+00 15  0  0  0  0  15  0  0  0  1     0
Mesh Migration         1 1.0 1.5494e+03 1.0 0.00e+00 0.0 7.3e+05 1.9e+02
2.4e+01 45  0  0  0  1  46  0  0  0  2     0
DMPlexPartSelf         1 1.0 1.1498e+002367.3 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexPartLblInv       1 1.0 3.6698e+00 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
3.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMPlexPartLblSF        1 1.0 2.8522e-01 1.7 0.00e+00 0.0 4.9e+04 1.5e+02
DMPlexPartStrtSF       1 1.0 4.9474e+023520.8 0.00e+00 0.0 3.3e+04 4.3e+02
0.0e+00 14  0  0  0  0  15  0  0  0  0     0
DMPlexPointSF          1 1.0 9.8750e+021264.8 0.00e+00 0.0 6.6e+04 5.4e+02
0.0e+00 28  0  0  0  0  29  0  0  0  0     0
DMPlexInterp          84 1.0 4.3219e-0158.6 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00  0  0  0  0  0   0  0  0  0  1     0
DMPlexDistribute       1 1.0 3.0000e+03 1.5 0.00e+00 0.0 9.3e+05 2.3e+02
3.0e+01 88  0  0  0  2  90  0  0  0  3     0
DMPlexDistCones        1 1.0 1.0688e+03 2.6 0.00e+00 0.0 1.8e+05 3.1e+02
1.0e+00 31  0  0  0  0  31  0  0  0  0     0
DMPlexDistLabels       1 1.0 2.9172e+02 1.0 0.00e+00 0.0 3.1e+05 1.9e+02
2.1e+01  9  0  0  0  1   9  0  0  0  2     0
DMPlexDistField        1 1.0 1.8688e+02 1.2 0.00e+00 0.0 2.1e+05 9.3e+01
1.0e+00  5  0  0  0  0   5  0  0  0  0     0
DMPlexStratify       118 1.0 6.2852e+023280.9 0.00e+00 0.0 0.0e+00 0.0e+00
1.6e+01  1  0  0  0  1   1  0  0  0  2     0
DMPlexSymmetrize     118 1.0 6.7634e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00
DMPlexPrealloc         1 1.0 2.3741e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05
1.1e+01  1  0  0  7  1   1  0  1 22  1     0
DMPlexResidualFE       3 1.0 1.0634e+01 1.2 1.16e+09 1.0 0.0e+00 0.0e+00
0.0e+00  0  2  0  0  0   0 15  0  0  0 3569848
DMPlexJacobianFE       2 1.0 1.6809e+02 1.0 1.51e+09 1.0 6.5e+05 1.4e+06
0.0e+00  5  3  0  5  0   5 20  0 14  0 293801
SFSetGraph            87 1.0 2.7673e-03 3.2 0.00e+00 0.0 0.0e+00 0.0e+00
SFSetUp               62 1.0 7.3283e+0213.6 0.00e+00 0.0 2.0e+07 2.7e+04
0.0e+00  5  0  1  3  0   5  0  6  9  0     0
SFBcastOpBegin       107 1.0 1.5770e+00452.5 0.00e+00 0.0 2.1e+07 1.8e+04
0.0e+00  0  0  1  2  0   0  0  6  6  0     0
SFBcastOpEnd         107 1.0 2.9430e+03 4.8 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 80  0  0  0  0  82  0  0  0  0     0
SFReduceBegin         12 1.0 2.4825e-01172.8 0.00e+00 0.0 2.4e+06 2.0e+05
0.0e+00  0  0  0  2  0   0  0  1  8  0     0
SFReduceEnd           12 1.0 3.8286e+014865.8 3.74e+04 0.0 0.0e+00 0.0e+00
0.0e+00  1  0  0  0  0   1  0  0  0  0    31
SFFetchOpBegin         2 1.0 2.4497e-0390.2 0.00e+00 0.0 4.3e+05 3.5e+05
0.0e+00  0  0  0  1  0   0  0  0  2  0     0
SFFetchOpEnd           2 1.0 6.1349e-0210.9 0.00e+00 0.0 4.3e+05 3.5e+05
SFCreateEmbed          3 1.0 3.6800e+013261.5 0.00e+00 0.0 4.7e+05 1.7e+03
SFDistSection          9 1.0 4.4325e+02 1.5 0.00e+00 0.0 2.8e+06 1.1e+04
9.0e+00 11  0  0  0  0  11  0  1  1  1     0
SFSectionSF           11 1.0 2.3898e+02 4.7 0.00e+00 0.0 9.2e+05 1.7e+05
0.0e+00  5  0  0  1  0   5  0  0  2  0     0
SFRemoteOff            2 1.0 3.2868e-0143.1 0.00e+00 0.0 8.7e+05 8.2e+03
SFPack              1023 1.0 2.5215e-0176.6 0.00e+00 0.0 0.0e+00 0.0e+00
SFUnpack            1025 1.0 5.1600e-0216.8 5.62e+0521.3 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 54693
MatMult            1549525.4 3.4810e+00 1.3 4.35e+09 1.1 2.2e+08 6.1e+03
0.0e+00  0  8  8  7  0   0 54 62 21  0 38319208
MatMultAdd           132 1.0 6.9168e-01 3.0 7.97e+07 1.2 2.8e+07 4.6e+02
0.0e+00  0  0  1  0  0   0  1  8  0  0 3478717
MatMultTranspose     132 1.0 5.9967e-01 1.6 8.00e+07 1.2 3.0e+07 4.5e+02
0.0e+00  0  0  1  0  0   0  1  9  0  0 4015214
MatSolve              22 0.0 6.8431e-04 0.0 7.41e+05 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1082
MatLUFactorSym         1 1.0 5.9569e-0433.3 0.00e+00 0.0 0.0e+00 0.0e+00
MatLUFactorNum         1 1.0 1.6236e-03773.2 1.46e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   897
MatConvert             6 1.0 1.4290e-01 1.2 0.00e+00 0.0 3.0e+06 3.7e+03
0.0e+00  0  0  0  0  0   0  0  1  0  0     0
MatScale              18 1.0 3.7962e-01 1.3 4.11e+07 1.2 2.0e+06 5.5e+03
0.0e+00  0  0  0  0  0   0  0  1  0  0 3253392
MatResidual          132 1.0 6.8256e-01 1.4 8.27e+08 1.2 4.4e+07 5.5e+03
0.0e+00  0  2  2  1  0   0 10 13  4  0 36282014
MatAssemblyBegin     244 1.0 3.1181e+01 6.6 0.00e+00 0.0 4.8e+06 2.5e+05
MatAssemblyEnd       244 1.0 6.3232e+00 1.9 3.17e+06 6.9 0.0e+00 0.0e+00
1.4e+02  0  0  0  0  8   0  0  0  0 15  7655
MatGetRowIJ            1 0.0 2.5780e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatCreateSubMat       10 1.0 1.5162e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05
1.3e+02  0  0  0  0  7   0  0  0  1 13     0
MatGetOrdering         1 0.0 1.0899e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatCoarsen             6 1.0 3.5837e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04
3.9e+01  0  0  1  1  2   0  0  5  3  4     0
MatZeroEntries         8 1.0 5.3730e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatAXPY                6 1.0 2.6245e-01 1.1 2.66e+05 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 33035
MatTranspose          12 1.0 3.0731e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
MatMatMultSym         18 1.0 2.1398e+00 1.4 0.00e+00 0.0 6.1e+06 5.5e+03
4.8e+01  0  0  0  0  3   0  0  2  1  5     0
MatMatMultNum          6 1.0 1.1243e+00 1.0 3.76e+07 1.2 2.0e+06 5.5e+03
0.0e+00  0  0  0  0  0   0  0  1  0  0 1001203
MatPtAPSymbolic        6 1.0 1.7280e+01 1.0 0.00e+00 0.0 1.2e+07 3.2e+04
4.2e+01  1  0  0  2  2   1  0  3  6  4     0
MatPtAPNumeric         6 1.0 1.8047e+01 1.0 1.49e+09 5.1 2.8e+06 1.1e+05
2.4e+01  1  1  0  2  1   1  5  1  5  2 663675
MatTrnMatMultSym       1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05
MatGetLocalMat        19 1.0 1.3904e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetBrAoCol         18 1.0 1.9926e-01 5.0 0.00e+00 0.0 1.4e+07 2.3e+04
0.0e+00  0  0  0  2  0   0  0  4  5  0     0
MatGetSymTrans         2 1.0 1.8996e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecTDot              176 1.0 7.0632e-01 4.5 3.48e+07 1.0 0.0e+00 0.0e+00
1.8e+02  0  0  0  0 10   0  0  0  0 18 1608728
VecNorm               60 1.0 1.4074e+0012.2 1.58e+07 1.0 0.0e+00 0.0e+00
6.0e+01  0  0  0  0  3   0  0  0  0  6 366467
VecCopy              422 1.0 5.1259e-02 3.8 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet               653 1.0 2.3974e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY              165 1.0 6.5622e-03 1.3 3.42e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 170485467
VecAYPX              861 1.0 7.8529e-02 1.2 6.21e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  1  0  0  0 25785252
VecAXPBYCZ           264 1.0 4.1343e-02 1.5 5.85e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  1  0  0  0 46135592
VecAssemblyBegin      21 1.0 2.3463e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
VecAssemblyEnd        21 1.0 1.4457e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
VecPointwiseMult     600 1.0 5.7510e-02 1.2 2.66e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 15075754
VecScatterBegin      902 1.0 5.1188e-01 1.2 0.00e+00 0.0 2.9e+08 5.3e+03
0.0e+00  0  0 10  8  0   0  0 82 25  0     0
VecScatterEnd        902 1.0 1.2143e+00 3.2 5.50e+0537.9 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1347
VecSetRandom           6 1.0 2.6354e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
DualSpaceSetUp         7 1.0 5.3467e-0112.0 4.26e+03 1.0 0.0e+00 0.0e+00
1.3e+01  0  0  0  0  1   0  0  0  0  1   261
FESetUp                7 1.0 1.7541e-01128.5 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSetUp              15 1.0 2.7470e-01 1.1 2.04e+08 1.2 1.0e+07 5.5e+03
1.3e+02  0  0  0  0  7   0  2  3  1 13 22477233
KSPSolve               1 1.0 4.3257e+00 1.0 4.33e+09 1.1 2.5e+08 4.8e+03
6.6e+01  0  8  9  6  4   0 54 72 20  7 30855976
PCGAMGGraph_AGG        6 1.0 5.0969e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03
4.8e+01  0  0  0  0  3   0  0  1  0  5 220852
PCGAMGCoarse_AGG       6 1.0 3.1121e+01 1.0 0.00e+00 0.0 2.5e+07 6.9e+04
5.5e+01  1  0  1  9  3   1  0  7 27  6     0
PCGAMGProl_AGG         6 1.0 5.8196e-01 1.0 0.00e+00 0.0 6.6e+06 9.3e+03
7.2e+01  0  0  0  0  4   0  0  2  1  7     0
PCGAMGPOpt_AGG         6 1.0 3.2414e+00 1.0 2.42e+08 1.2 2.1e+07 5.3e+03
1.6e+02  0  0  1  1  9   0  3  6  2 17 2256493
GAMG: createProl       6 1.0 4.0042e+01 1.0 2.80e+08 1.2 5.8e+07 3.3e+04
3.4e+02  1  1  2 10 19   1  3 16 31 34 210778
  Graph               12 1.0 5.0926e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03
4.8e+01  0  0  0  0  3   0  0  1  0  5 221038
  MIS/Agg              6 1.0 3.5850e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04
  SA: col data         6 1.0 3.0509e-01 1.0 0.00e+00 0.0 5.4e+06 9.2e+03
2.4e+01  0  0  0  0  1   0  0  2  1  2     0
  SA: frmProl0         6 1.0 2.3467e-01 1.1 0.00e+00 0.0 1.3e+06 9.5e+03
2.4e+01  0  0  0  0  1   0  0  0  0  2     0
  SA: smooth           6 1.0 2.7855e+00 1.0 4.14e+07 1.2 8.1e+06 5.5e+03
6.3e+01  0  0  0  0  3   0  1  2  1  6 446491
GAMG: partLevel        6 1.0 3.7266e+01 1.0 1.49e+09 5.1 1.5e+07 4.9e+04
3.2e+02  1  1  1  4 17   1  5  4 12 32 321395
  repartition          5 1.0 2.0343e+00 1.1 0.00e+00 0.0 4.0e+05 1.4e+05
2.5e+02  0  0  0  0 14   0  0  0  1 25     0
  Invert-Sort          5 1.0 1.5021e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
3.0e+01  0  0  0  0  2   0  0  0  0  3     0
  Move A               5 1.0 1.1548e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05
7.0e+01  0  0  0  0  4   0  0  0  1  7     0
  Move P               5 1.0 4.2799e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
7.5e+01  0  0  0  0  4   0  0  0  0  8     0
PCGAMG Squ l00         1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05
PCGAMG Gal l00         1 1.0 8.7411e+00 1.0 2.93e+08 1.1 5.4e+06 4.5e+04
1.2e+01  0  1  0  1  1   0  4  2  4  1 1092355
PCGAMG Opt l00         1 1.0 1.9734e+00 1.0 3.36e+07 1.1 3.2e+06 1.2e+04
9.0e+00  0  0  0  0  0   0  0  1  1  1 555327
PCGAMG Gal l01         1 1.0 1.0153e+00 1.0 3.50e+07 1.4 5.9e+06 3.9e+04
1.2e+01  0  0  0  1  1   0  0  2  4  1 1079887
PCGAMG Opt l01         1 1.0 7.4812e-02 1.0 5.35e+05 1.2 3.2e+06 1.1e+03
9.0e+00  0  0  0  0  0   0  0  1  0  1 232542
PCGAMG Gal l02         1 1.0 1.8063e+00 1.0 7.43e+07 0.0 3.0e+06 5.9e+04
1.2e+01  0  0  0  1  1   0  0  1  3  1 593392
PCGAMG Opt l02         1 1.0 1.1580e-01 1.1 6.93e+05 0.0 1.6e+06 1.3e+03
9.0e+00  0  0  0  0  0   0  0  0  0  1 93213
PCGAMG Gal l03         1 1.0 6.1075e+00 1.0 2.72e+08 0.0 2.6e+05 9.2e+04
1.1e+01  0  0  0  0  1   0  0  0  0  1 36155
PCGAMG Opt l03         1 1.0 8.0836e-02 1.0 1.55e+06 0.0 1.4e+05 1.4e+03
8.0e+00  0  0  0  0  0   0  0  0  0  1 18229
PCGAMG Gal l04         1 1.0 1.6203e+01 1.0 9.44e+08 0.0 1.4e+04 3.0e+05
1.1e+01  0  0  0  0  1   0  0  0  0  1  2366
PCGAMG Opt l04         1 1.0 1.2663e-01 1.0 2.01e+06 0.0 6.9e+03 2.2e+03
8.0e+00  0  0  0  0  0   0  0  0  0  1   817
PCGAMG Gal l05         1 1.0 1.4800e+00 1.0 3.16e+08 0.0 9.0e+01 1.6e+05
1.1e+01  0  0  0  0  1   0  0  0  0  1   796
PCGAMG Opt l05         1 1.0 8.1763e-02 1.1 2.50e+06 0.0 4.8e+01 4.6e+03
8.0e+00  0  0  0  0  0   0  0  0  0  1   114
PCSetUp                2 1.0 7.7969e+01 1.0 1.97e+09 2.8 8.3e+07 3.3e+04
8.1e+02  2  2  3 14 44   2 11 23 43 82 341051
PCSetUpOnBlocks       22 1.0 2.4609e-0317.2 1.46e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   592
PCApply               22 1.0 3.6455e+00 1.1 3.57e+09 1.2 2.4e+08 4.3e+03
0.0e+00  0  7  8  5  0   0 43 67 16  0 29434967
--- Event Stage 1: PCSetUp
BuildTwoSided          4 1.0 1.5980e-01 2.7 0.00e+00 0.0 2.1e+05 8.0e+00
BuildTwoSidedF         6 1.0 1.3169e+01 5.5 0.00e+00 0.0 1.9e+06 1.9e+05
0.0e+00  0  0  0  2  0  28  0 10 51  0     0
SFSetGraph             5 1.0 4.9640e-0519.0 0.00e+00 0.0 0.0e+00 0.0e+00
SFSetUp                4 1.0 1.6038e-01 2.3 0.00e+00 0.0 6.4e+05 9.1e+02
0.0e+00  0  0  0  0  0   0  0  3  0  0     0
SFPack                30 1.0 3.3376e-04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
SFUnpack              30 1.0 1.2101e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
MatMult               30 1.0 1.5544e-01 1.5 1.87e+08 1.2 1.0e+07 5.5e+03
0.0e+00  0  0  0  0  0   0 31 53  8  0 35930640
MatAssemblyBegin      43 1.0 1.3201e+01 4.7 0.00e+00 0.0 1.9e+06 1.9e+05
MatAssemblyEnd        43 1.0 1.1159e+01 1.0 2.77e+07705.7 0.0e+00 0.0e+00
2.0e+01  0  0  0  0  1  26  0  0  0 13  1036
MatZeroEntries         6 1.0 4.7315e-0410.7 0.00e+00 0.0 0.0e+00 0.0e+00
MatTranspose          12 1.0 2.5142e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
MatMatMultSym         10 1.0 5.8783e-0117.4 0.00e+00 0.0 0.0e+00 0.0e+00
MatPtAPSymbolic        5 1.0 1.4489e+01 1.0 0.00e+00 0.0 6.2e+06 3.6e+04
3.5e+01  0  0  0  1  2  34  0 32 31 22     0
MatPtAPNumeric         6 1.0 2.8457e+01 1.0 1.50e+09 5.1 2.7e+06 1.6e+05
2.0e+01  1  1  0  2  1  66 66 14 61 13 421190
MatGetLocalMat         6 1.0 9.8574e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetBrAoCol          6 1.0 3.7669e-01 2.3 0.00e+00 0.0 5.1e+06 3.8e+04
0.0e+00  0  0  0  1  0   0  0 27 28  0     0
VecTDot               66 1.0 6.5271e-02 4.1 5.85e+06 1.0 0.0e+00 0.0e+00
6.6e+01  0  0  0  0  4   0  1  0  0 42 2922260
VecNorm               36 1.0 1.1226e-02 3.2 3.19e+06 1.0 0.0e+00 0.0e+00
3.6e+01  0  0  0  0  2   0  1  0  0 23 9268067
VecCopy               12 1.0 1.2805e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet                11 1.0 6.6620e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY               60 1.0 1.0763e-03 1.5 5.32e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  1  0  0  0 161104914
VecAYPX               24 1.0 2.0581e-03 1.3 2.13e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 33701038
VecPointwiseMult      36 1.0 3.5709e-03 1.3 1.60e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 14567861
VecScatterBegin       30 1.0 2.9079e-03 7.8 0.00e+00 0.0 1.0e+07 5.5e+03
0.0e+00  0  0  0  0  0   0  0 53  8  0     0
VecScatterEnd         30 1.0 3.7015e-0263.0 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSetUp               7 1.0 2.3165e-01 1.0 2.04e+08 1.2 1.0e+07 5.5e+03
1.0e+02  0  0  0  0  6   1 34 53  8 64 26654598
PCGAMG Gal l00         1 1.0 4.7415e+00 1.0 2.94e+08 1.1 1.8e+06 7.8e+04
0.0e+00  0  1  0  1  0  11 53  9 20  0 2015623
PCGAMG Gal l01         1 1.0 1.2103e+00 1.0 3.50e+07 1.4 4.8e+06 6.2e+04
1.2e+01  0  0  0  2  1   3  6 25 41  8 905938
PCGAMG Gal l02         1 1.0 3.4334e+00 1.0 7.41e+07 0.0 2.2e+06 8.7e+04
1.2e+01  0  0  0  1  1   8  6 11 27  8 312184
PCGAMG Gal l03         1 1.0 9.6062e+00 1.0 2.71e+08 0.0 1.9e+05 1.3e+05
1.1e+01  0  0  0  0  1  22  1  1  4  7 22987
PCGAMG Gal l04         1 1.0 2.2482e+01 1.0 9.43e+08 0.0 8.7e+03 4.8e+05
1.1e+01  1  0  0  0  1  52  0  0  1  7  1705
PCGAMG Gal l05         1 1.0 1.5961e+00 1.1 3.16e+08 0.0 6.8e+01 2.2e+05
1.1e+01  0  0  0  0  1   4  0  0  0  7   738
PCSetUp                1 1.0 4.3191e+01 1.0 1.70e+09 3.6 1.9e+07 3.7e+04
1.6e+02  1  1  1  4  9 100100100100100 420463
--- Event Stage 2: KSP Solve only
SFPack              8140 1.0 7.4247e-02 4.8 0.00e+00 0.0 0.0e+00 0.0e+00
SFUnpack            8140 1.0 1.2905e-02 5.2 5.50e+0637.9 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0 1267207
MatMult             5500 1.0 2.9994e+01 1.2 3.98e+10 1.1 2.0e+09 6.1e+03
0.0e+00  1 76 68 62  0  70 92 78 98  0 40747181
MatMultAdd          1320 1.0 6.2192e+00 2.7 7.97e+08 1.2 2.8e+08 4.6e+02
0.0e+00  0  2 10  1  0  14  2 11  1  0 3868976
MatMultTranspose    1320 1.0 4.0304e+00 1.7 8.00e+08 1.2 2.8e+08 4.6e+02
0.0e+00  0  2 10  1  0   7  2 11  1  0 5974153
MatSolve             220 0.0 6.7366e-03 0.0 7.41e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  1100
MatLUFactorSym         1 1.0 5.8691e-0435.5 0.00e+00 0.0 0.0e+00 0.0e+00
MatLUFactorNum         1 1.0 1.5955e-03756.2 1.46e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   913
MatResidual         1320 1.0 6.4920e+00 1.3 8.27e+09 1.2 4.4e+08 5.5e+03
0.0e+00  0 15 15 13  0  14 19 18 20  0 38146350
MatGetRowIJ            1 0.0 2.7820e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         1 0.0 9.6940e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00
VecTDot              440 1.0 4.6162e+00 6.9 2.31e+08 1.0 0.0e+00 0.0e+00
4.4e+02  0  0  0  0 24   5  1  0  0 66 1635124
VecNorm              230 1.0 3.9605e-02 1.6 1.21e+08 1.0 0.0e+00 0.0e+00
2.3e+02  0  0  0  0 13   0  0  0  0 34 99622387
VecCopy             3980 1.0 5.4166e-01 4.3 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet              4640 1.0 1.4216e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY              440 1.0 4.2829e-02 1.3 2.31e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  1  0  0  0 176236363
VecAYPX             8130 1.0 7.3998e-01 1.2 5.78e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   2  1  0  0  0 25489392
VecAXPBYCZ          2640 1.0 3.9974e-01 1.5 5.85e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   1  1  0  0  0 47716315
VecPointwiseMult    5280 1.0 5.9845e-01 1.5 2.34e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   1  1  0  0  0 12748927
VecScatterBegin     8140 1.0 4.9231e-01 5.9 0.00e+00 0.0 2.5e+09 4.9e+03
0.0e+00  0  0 87 64  0   1  0100100  0     0
VecScatterEnd       8140 1.0 1.0172e+01 3.6 5.50e+0637.9 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0  13  0  0  0  0  1608
KSPSetUp               1 1.0 9.5996e-07 3.1 0.00e+00 0.0 0.0e+00 0.0e+00
KSPSolve              10 1.0 3.9685e+01 1.0 4.33e+10 1.1 2.5e+09 4.9e+03
6.7e+02  1 83 87 64 37 100100100100100 33637495
PCSetUp                1 1.0 2.4149e-0318.1 1.46e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   603
PCSetUpOnBlocks      220 1.0 2.6945e-03 8.9 1.46e+06 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0   540
PCApply              220 1.0 3.2921e+01 1.1 3.57e+10 1.2 2.3e+09 4.3e+03
0.0e+00  1 67 81 53  0  81 80 93 82  0 32595360
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container   112            112        69888     0.
                SNES     1              1         1532     0.
              DMSNES     1              1          720     0.
    Distributed Mesh   449            449     30060888     0.
            DM Label   790            790       549840     0.
          Quadrature   579            579       379824     0.
           Index Set 100215          100210    361926232     0.
   IS L to G Mapping     8             13      4356552     0.
             Section   771            771       598296     0.
   Star Forest Graph   897            897      1053640     0.
     Discrete System   521            521       533512     0.
    GraphPartitioner   118            118        91568     0.
              Matrix   432            462   2441805304     0.
      Matrix Coarsen     6              6         4032     0.
              Vector   354            354     65492968     0.
        Linear Space     7              7         5208     0.
          Dual Space   111            111       113664     0.
            FE Space     7              7         5992     0.
       Field over DM     6              6         4560     0.
       Krylov Solver    21             21        37560     0.
     DMKSP interface     1              1          704     0.
      Preconditioner    21             21        21632     0.
              Viewer     2              1          896     0.
         PetscRandom    12             12         8520     0.
           Index Set    10             15     85367336     0.
   IS L to G Mapping     5              0            0     0.
   Star Forest Graph     5              5         6600     0.
              Matrix    50             20     73134024     0.
              Vector    28             28      6235096     0.
           Index Set     5              5         8296     0.
              Matrix     1              1       273856     0.
Average time to get PetscTime(): 6.40051e-08
Average time for MPI_Barrier(): 8.506e-06
Average time for zero size MPI_Send(): 6.6027e-06
#PETSc Option Table entries:
-benchmark_it 10
-dm_distribute
-dm_plex_box_dim 3
-dm_plex_box_faces 32,32,32
-dm_plex_box_lower 0,0,0
-dm_plex_box_simplex 0
-dm_plex_box_upper 1,1,1
-dm_refine 5
-ksp_converged_reason
-ksp_max_it 150
-ksp_norm_type unpreconditioned
-ksp_rtol 1.e-12
-ksp_type cg
-log_view
-matptap_via scalable
-mg_levels_esteig_ksp_max_it 5
-mg_levels_esteig_ksp_type cg
-mg_levels_ksp_max_it 2
-mg_levels_ksp_type chebyshev
-mg_levels_pc_type jacobi
-pc_gamg_agg_nsmooths 1
-pc_gamg_coarse_eq_limit 2000
-pc_gamg_coarse_grid_layout_type spread
-pc_gamg_esteig_ksp_max_it 5
-pc_gamg_esteig_ksp_type cg
-pc_gamg_process_eq_limit 500
-pc_gamg_repartition false
-pc_gamg_reuse_interpolation true
-pc_gamg_square_graph 1
-pc_gamg_threshold 0.01
-pc_gamg_threshold_scale .5
-pc_gamg_type agg
-pc_type gamg
-petscpartitioner_simple_node_grid 8,8,8
-petscpartitioner_simple_process_grid 4,4,4
-petscpartitioner_type simple
-potential_petscspace_degree 2
-snes_converged_reason
-snes_max_it 1
-snes_monitor
-snes_rtol 1.e-8
-snes_type ksponly
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure options: CC=mpifccpx CXX=mpiFCCpx CFLAGS="-L
/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" CXXFLAGS="-L
/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" COPTFLAGS=-Kfast
CXXOPTFLAGS=-Kfast --with-fc=0
--package-prefix-hash=/home/ra010009/a04199/petsc-hash-pkgs --with-batch=1
--with-shared-libraries=yes --with-debugging=no --with-64-bit-indices=1
PETSC_ARCH=arch-fugaku-fujitsu
Libraries compiled on 2021-02-12 02:27:41 on fn01sv08
Machine characteristics:
Linux-3.10.0-957.27.2.el7.x86_64-x86_64-with-redhat-7.6-Maipo
Using PETSc directory: /home/ra010009/a04199/petsc
Using PETSc arch:
Using C compiler: mpifccpx -L /opt/FJSVxtclanga/tcsds-1.2.29/lib64
-lfjlapack -fPIC -Kfast
Using include paths: -I/home/ra010009/a04199/petsc/include
-I/home/ra010009/a04199/petsc/arch-fugaku-fujitsu/include
Using C linker: mpifccpx
Using libraries: -Wl,-rpath,/home/ra010009/a04199/petsc/lib
-L/home/ra010009/a04199/petsc/lib -lpetsc
-Wl,-rpath,/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8
-L/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8
-Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64
-L/opt/FJSVxtclanga/tcsds-1.2.29/lib64
-Wl,-rpath,/opt/FJSVxtclanga/.common/MELI022/lib64
-L/opt/FJSVxtclanga/.common/MELI022/lib64
-Wl,-rpath,/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64
-L/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64
-Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64
-L/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64
-Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64
-L/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64
-Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj
-L/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj -lX11 -lfjprofmpi -lfjlapack
-ldl -lmpi_cxx -lmpi -lfjstring_internal -lfj90i -lfj90fmt_sve -lfj90f
-lfjsrcinfo -lfjcrt -lfjprofcore -lfjprofomp -lfjc++ -lfjc++abi -lfjdemgl
-lmpg -lm -lrt -lpthread -lelf -lz -lgcc_s -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210307/a5c22850/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210307/a5c22850/attachment-0001.png>
