[petsc-users] [EXT]Re: Is using PETSc appropriate for this problem
Thu Sep 17 08:04:41 CDT 2020
On Thu, Sep 17, 2020 at 12:23 AM Jed Brown <jed at jedbrown.org> wrote:
> Alexander B Prescott <alexprescott at email.arizona.edu> writes:
> >>      Are the problems of varying nonlinearity, that is will some
> converge
> >> with say a couple of Newton iterations while others require more, say 8
> or
> >> more Newton steps?
> > The nonlinearity should be pretty similar, the problem setup is the same
> at
> > every node but the global domain needs to be traversed in a specific
> order.
> It sounds like you may have a Newton solver now for each individual
> problem?  If so, could you make a histogram of number of iterations
> necessary to solve?  Does it have a long tail or does every problem take 3
> and 4 iterations (for example).
> If there is no long tail, then you can batch.  If there is a long tail,
> you really want a solver that does one problem at a time, or a more dynamic
> system that checks which have completed and shrinks the active problem
> down.  (That complexity has a development and execution time cost.)
He cannot batch if the solves are sequential, as he says above.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200917/60ac1bd4/attachment.html>
