[petsc-users] TSAdjoint not working correctly when using TSThetaSetEndpoint(true)
Zhang, Hong hongzhang at anl.gov
Tue Jun 2 17:31:42 CDT 2020
Miguel,
After I uncommented ts.setThetaEndpoint(True) and removed ts.setProblemType(False.ProblemType.LINEAR) in your code, I got the following result:
hongzhang at Hongs-MacBook-Pro$ python3 petsc_question_2.py
Cost function
Vec Object: 1 MPI processes
  type: seq
127.781
Exact value: 127.78112
Numerical sensitivity w.r.t. a
12.778122049945212
Real sensitivity w.r.t a
12.7781121978613
Numerical sensitivity w.r.t. b
83.8907580310942
Real sensitivity w.r.t b
211.67168296791954
-ts_type cn gives the same result. What was the problem you encountered?
Hong (Mr.)
On Jun 2, 2020, at 2:36 PM, Salazar De Troya, Miguel via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
I am attaching a simple example that uses TSAdjoint to calculate the sensitivity of a 1 degree of freedom ODE. When using theta methods, it returns the right sensitivity as given by the analytical solution. When I set `ts.setThetaEndpoint(True)`, it does not work. Is there a theoretical reason why? I was using this option because using the options
ts.setType(ts.Type.THETA)
ts.setTheta(0.5)
is equivalent to using ts.Type.CN
Thanks
Miguel
Miguel A. Salazar de Troya
Postdoctoral Researcher, Lawrence Livermore National Laboratory
B141
Rm: 1085-5
Ph: 1(925) 422-6411
<petsc_question_2.py>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200602/2f5e023d/attachment-0001.html>
