[petsc-users] Crash caused by strange error in KSPSetUp
    Junchao Zhang
    jczhang at mcs.anl.gov
    Mon Feb 17 10:19:15 CST 2020
Hi, Richard,
 I tested the case you sent over and found it did fail due to the 32-bit
overflow on number of non-zeros, and with a 64-bit built petsc it passed.
You had a typo when you reported that --with-64-bit-indicies=yes failed. It
should be --with-64-bit-indices=yes.
 You can go with a 64-bit built petsc, or you can go with parallel
computing and run with multiple MPI ranks so that each rank has less
non-zeros and it is faster (but you need to make sure that code is
correctly parallelized).
 Barry's recent fix ierr = PetscIntCast(nz64,&nz);CHKERRQ(ierr); would
print more useful error messages in this case.  Barry, should we patch it
back to 3.6.3?
--Junchao Zhang
On Sun, Feb 16, 2020 at 11:37 PM Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> Richard,
>   I managed to get the code Simlul at trophy built. Could you tell me how to
> run your test? I want to see if I can reproduce the error. Thanks
> --Junchao Zhang
> On Fri, Feb 14, 2020 at 8:34 PM Richard Beare <richard.beare at monash.edu>
> wrote:
>> It doesn't compile out of the box with master.
>> singularity def file attached.
>> On Sat, 15 Feb 2020 at 08:03, Richard Beare <richard.beare at monash.edu>
>> wrote:
>>> I will see if I can build with master. The docs for simulatrophy say
>>> 3.6.3.1.
>>> On Sat, 15 Feb 2020 at 02:47, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
>>>> Which petsc version do you use? In aij.c of the master branch, I saw
>>>> Barry recently added a useful check to catch number of nonzero overflow,
>>>> ierr = PetscIntCast(nz64,&nz);CHKERRQ(ierr);  But you mentioned using
>>>> 64-bit indices did not solve the problem, it might not be the reason.  You
>>>> should try the master branch if feasible. Also, vary number of MPI ranks to
>>>> see if error stack changes.
>>>> --Junchao Zhang
>>>> On Fri, Feb 14, 2020 at 5:12 AM Richard Beare via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>>> No luck - exactly the same error after including the
>>>>> --with-64-bit-indicies=yes --download-mpich=yes options
>>>>> ==8674== Argument 'size' of function memalign has a fishy (possibly
>>>>> negative) value: -17152036540
>>>>> ==8674==    at 0x4C320A6: memalign (in
>>>>> /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
>>>>> ==8674==    by 0x4F0CFF2: PetscMallocAlign(unsigned long, int, char
>>>>> const*, char const*, void**) (mal.c:28)
>>>>> ==8674==    by 0x4F0F716: PetscTrMallocDefault(unsigned long, int,
>>>>> char const*, char const*, void**) (mtr.c:188)
>>>>> ==8674==    by 0x569AF3E: MatSeqAIJSetPreallocation_SeqAIJ (aij.c:3595)
>>>>> ==8674==    by 0x569A531: MatSeqAIJSetPreallocation (aij.c:3539)
>>>>> ==8674==    by 0x599080A: DMCreateMatrix_DA_3d_MPIAIJ(_p_DM*, _p_Mat*)
>>>>> (fdda.c:1085)
>>>>> ==8674==    by 0x598B937: DMCreateMatrix_DA(_p_DM*, _p_Mat**)
>>>>> (fdda.c:759)
>>>>> ==8674==    by 0x58A2BF2: DMCreateMatrix (dm.c:956)
>>>>> ==8674==    by 0x5E377B3: KSPSetUp (itfunc.c:262)
>>>>> ==8674==    by 0x409FFC: PetscAdLemTaras3D::solveModel(bool)
>>>>> (PetscAdLemTaras3D.hxx:255)
>>>>> ==8674==    by 0x4239FB: AdLem3D<3u>::solveModel(bool, bool, bool)
>>>>> (AdLem3D.hxx:551)
>>>>> ==8674==    by 0x41BD17: main (PetscAdLemMain.cxx:344)
>>>>> ==8674==
>>>>> On Fri, 14 Feb 2020 at 17:07, Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>> wrote:
>>>>>>    Richard,
>>>>>>      It is likely that for these problems some of the integers become
>>>>>> too large for the int variable to hold them, thus they overflow and become
>>>>>> negative.
>>>>>>      You should make a new PETSC_ARCH configuration of PETSc that
>>>>>> uses the configure option --with-64-bit-indices, this will change PETSc to
>>>>>> use 64 bit integers which will not overflow.
>>>>>>      Good luck and let us know how it works out
>>>>>>     Barry
>>>>>>      Probably the code is built with an older version of PETSc; the
>>>>>> later versions should produce a more useful error message.
>>>>>> > On Feb 13, 2020, at 11:43 PM, Richard Beare via petsc-users <
>>>>>> > Hi Everyone,
>>>>>> > I am experimenting with the Simlul at trophy tool (
>>>>>> https://github.com/Inria-Asclepios/simul-atrophy) that uses petsc to
>>>>>> simulate brain atrophy based on segmented MRI data. I am not the author. I
>>>>>> have this running on most of a dataset of about 50 scans, but experience
>>>>>> crashes with several that I am trying to track down. However I am out of
>>>>>> ideas. The problem images are slightly bigger than some of the successful
>>>>>> ones, but not substantially so, and I have experimented on machines with
>>>>>> sufficient RAM. The error happens very quickly, as part of setup - see the
>>>>>> valgrind report below. I haven't managed to get the sgcheck tool to work
>>>>>> yet. I can only guess that the ksp object is somehow becoming corrupted
>>>>>> during the setup process, but the array sizes that I can track (which
>>>>>> derive from image sizes), appear correct at every point I can check. Any
>>>>>> suggestions as to how I can check what might go wrong in the setup of the
>>>>>> ksp object?
>>>>>> > Thankyou.
>>>>>> > valgrind tells me:
>>>>>> > ==18175== Argument 'size' of function memalign has a fishy
>>>>>> (possibly negative) value: -17152038144
>>>>>> > ==18175==    at 0x4C320A6: memalign (in
>>>>>> > ==18175==    by 0x4F0F1F2: PetscMallocAlign(unsigned long, int,
>>>>>> char const*, char const*, void**) (mal.c:28)
>>>>>> > ==18175==    by 0x56B43CA: MatSeqAIJSetPreallocation_SeqAIJ
>>>>>> (aij.c:3595)
>>>>>> > ==18175==    by 0x56B39BD: MatSeqAIJSetPreallocation (aij.c:3539)
>>>>>> > ==18175==    by 0x59A9B44: DMCreateMatrix_DA_3d_MPIAIJ(_p_DM*,
>>>>>> _p_Mat*) (fdda.c:1085)
>>>>>> > ==18175==    by 0x59A4C71: DMCreateMatrix_DA(_p_DM*, _p_Mat**)
>>>>>> (fdda.c:759)
>>>>>> > ==18175==    by 0x58BBD29: DMCreateMatrix (dm.c:956)
>>>>>> > ==18175==    by 0x5E509D5: KSPSetUp (itfunc.c:262)
>>>>>> > ==18175==    by 0x40A3DE: PetscAdLemTaras3D::solveModel(bool)
>>>>>> (PetscAdLemTaras3D.hxx:269)
>>>>>> > ==18175==    by 0x42413F: AdLem3D<3u>::solveModel(bool, bool, bool)
>>>>>> (AdLem3D.hxx:552)
>>>>>> > ==18175==    by 0x41C25C: main (PetscAdLemMain.cxx:349)
>>>>>> > ==18175==
>>>>>> > A/Prof Richard Beare
>>>>>> > Imaging and Bioinformatics, Peninsula Clinical School
>>>>>> > orcid.org/0000-0002-7530-5664
>>>>>> > Richard.Beare at monash.edu
>>>>>> > +61 3 9788 1724
>>>>>> > Geospatial Research:
>>>>>> https://www.monash.edu/medicine/scs/medicine/research/geospatial-analysis
>>>>> +61 3 9788 1724
>>> +61 3 9788 1724
>> +61 3 9788 1724
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200217/571034de/attachment-0001.html>
