[petsc-users] ARKIMEX produces incorrect values
Ed Bueler elbueler at alaska.edu
Mon Aug 31 12:17:46 CDT 2020
Emil --
Thanks for looking at this.
> Hi Ed, can you please add the following
> TSSetEquationType(ts,TS_EQ_IMPLICIT);
> before calling TSSolve and try again? This is described in Table 12 in
the pdf doc.
Yep, that fixes it.  After setting the TS_EQ_IMPLICIT flag programmatically
I get:
$ ./ex54 -ts_type arkimex -ts_arkimex_fully_implicit
error norm at tf = 1.000000 from 12 steps:  |u-u_exact| =  1.34500e-02
Without -ts_arkimex_fully_implicit we still get the wrong answer, but, as I
understand it, we expect the wrong answer because dF/d(dudt) != I, correct?
So -ts_arkimex_fully_implicit does not set this flag?
> So that we improve our user experience, can you tell us what are your
usual sources/starting points
> when implementing a new problem:
> 1- PDF doc
Yes.  Looked briefly at the PDF manual.  E.g. I saw the tables for IMEX
methods but my eyes glazed over.
> 2- tutorials (if you find a good match)
Yes.  Looked at various html pages including the one for TSARKIMEX.  But I
missed the sentence "Methods with an explicit stage can only be used with
ODE in which the stiff part G(t,X,Xdot) has the form Xdot + Ghat(t,X)."  I
did not expect that ARKIMEX had this restriction, and did not pick it up.
> 3- own PETSc implementations
Yes.  I have my own diffusion-reaction system (
https://github.com/bueler/p4pdes/blob/master/c/ch5/pattern.c) in which
ARKIMEX works well.  (Or at least as far as I can tell.  I don't have a
manufactured solution for it, for example.)  I am in the midst of tracking
down a different kind of error, probably from DMDA callbacks, when I got
distracted by the current issue.
> 4- online function doc
Yes.  See above comment on TSARKIMEX page.   By my memory I also looked at
the TSSet{I,RHS}Jacobian() pages, for example, and probably others.
> 5- other
Not sure.
Ed
On Mon, Aug 31, 2020 at 6:09 AM Constantinescu, Emil M. <emconsta at anl.gov>
wrote:
> On 8/30/20 6:04 PM, Ed Bueler wrote:
> Actually, ARKIMEX is not off the hook.  It still gets the wrong answer if
> told the whole thing is implicit:
> $ ./ex54 -ts_type arkimex -ts_arkimex_fully_implicit    # WRONG  (AND
> REALLY SLOW)
> error norm at tf = 1.000000 from 224 steps:  |u-u_exact| =  2.76636e+00
>  TSSetEquationType <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetEquationType.html#TSSetEquationType>(ts,TS_EQ_IMPLICIT <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSEquationType.html#TSEquationType>);
> before calling TSSolve and try again? This is described in Table 12 in the
> pdf doc.
> usual sources/starting points when implementing a new problem:
> 1- PDF doc
> 5- other
> Thanks,
> Emil
> versus
> $ ./ex54 -ts_type arkimex      # WRONG BUT IFunction IS OF FLAGGED FORM
> error norm at tf = 1.000000 from 16 steps:  |u-u_exact| =  1.93229e+01
> $ ./ex54 -ts_type bdf   # RIGHT
> error norm at tf = 1.000000 from 33 steps:  |u-u_exact| =  9.29170e-02
> So I am not sure what "Methods with an explicit stage can only be used
> with ODE in which the stiff part G(t,X,Xdot) has the form Xdot +
> Ghat(t,X)." means.
> Ed
> On Sun, Aug 30, 2020 at 2:57 PM Ed Bueler <elbueler at alaska.edu> wrote:
>> Darn, sorry.
>> I realize the ARKIMEX page does say "Methods with an explicit stage can
>> only be used with ODE in which the stiff part G(t,X,Xdot) has the form Xdot
>> + Ghat(t,X)."  So my example does not do that.  Is there a way for
>> ARKIMEX to detect that dG/d(Xdot) = I?
>> Ed
>> On Sun, Aug 30, 2020 at 2:44 PM Ed Bueler <elbueler at alaska.edu> wrote:
>>> Dear PETSc --
>>> I tried twice to make this an issue at the gitlab.com host site, but
>>> both times got "something went wrong (500)".  So this is a bug report by
>>> old-fashioned means.
>>> I created a TS example,
>>> https://github.com/bueler/p4pdes-next/blob/master/c/fix-arkimex/ex54.c
>>> at my github, also attached.  It solves a 2D linear ODE
>>>    x' + y' = 6 y
>>>         y' = x
>>> Pretty basic; the known exact solution is just exponentials.  The code
>>> writes it as F(t,u,u')=G(t,u) and supplies all the pieces, namely
>>> IFunction,IJacobian,RHSFunction,RHSJacobian.  Note both F and G must be
>>> seen by TS to get the correct solution.  In summary, a boring (and
>>> valgrind-clean ;-)) example.
>>> For current master branch it runs fine for the fully-implicit methods
>>> (e.g. BDF, CN, ROSW) which can use the IFunction F, including with
>>> finite-differenced Jacobians.  With BDF2, BDF2+-snes_fd, BDF6+tight tol.,
>>> CN, BEULER, ROSW:
>>> $ ./ex54
>>> $ ./ex54 -snes_fd
>>> $ ./ex54 -ts_rtol 1.0e-14 -ts_atol 1.0e-14 -ts_bdf_order 6
>>> error norm at tf = 1.000000 from 388 steps:  |u-u_exact| =  4.23624e-11
>>> $ ./ex54 -ts_type beuler
>>> error norm at tf = 1.000000 from 100 steps:  |u-u_exact| =  6.71676e-01
>>> $ ./ex54 -ts_type cn
>>> error norm at tf = 1.000000 from 100 steps:  |u-u_exact| =  2.22839e-03
>>> $ ./ex54 -ts_type rosw
>>> error norm at tf = 1.000000 from 21 steps:  |u-u_exact| =  5.64012e-03
>>> But it produces wrong values with ARKIMEX:
>>> Neither tightening tolerance nor changing type (`-ts_arkimex_type`)
>>> helps ARKIMEX.
>>> Thanks!
>>> Ed
>>> PS  My book is at a late proofs stage, and out of my hands.  It should
>>> appear SIAM Press in a couple of months.  In all the examples in my book,
>>> only my diffusion-reaction system example using F(t,u,u') = G(t,u) is
>>> broken.  Thus the motivation for a trivial ODE example as above.
>>> Ed Bueler
>>> Dept of Mathematics and Statistics
>>> University of Alaska Fairbanks
>>> Fairbanks, AK 99775-6660
>>> 306C Chapman
>> Ed Bueler
>> 306C Chapman
> Ed Bueler
> 306C Chapman
> Emil M. Constantinescu, Ph.D.
> Computational Mathematician
> Argonne National Laboratory
> Mathematics and Computer Science Division
> Ph: 630-252-0926http://www.mcs.anl.gov/~emconsta
Ed Bueler
306C Chapman
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200831/a2077ad4/attachment.html>
