[petsc-users] Help with DMDASetBlockFillsSparse
Alex Koshkarov okoshkarov at tae.com
Thu Aug 13 21:16:39 CDT 2020
Hello All,
I have a problem with DMDA matrix, I hope you can help. I am solving big PDE with TS object and my main data structure is 3D DMDA which has large number of degrees of freedom. I solve this system implicitly with JFNK. Essentially, I do something like this (J is jacobian, P is preconditioner):
MatCreateSNESMF(snes,&J);
DMCreateMatrix(da,&P);
SNESSetJacobian(snes,J,P,form_P,env);
In form_P I form P, but not J, and all works. I also sometimes use 3D DMDA for 2D and 1D problems, just setting Ny=Nz=1 and periodic boundary conditions. I have many degrees of freedom in my DMDA, so I need blocks to be sparse. So I tried to use DMDASetBlockFillsSparse, before DMCreateMatrix. However, it gives me an error connected that size of each dimension should be divisible by (2*stencil_size +1) to make efficient coloring, which makes using 3D DMDA for 2D problems not optimal. Moreover, it becomes super slow… I am not sure why it needs coloring. Essentially, everything works fine without DMDASetBlockFillsSparse, but once I use it, it complains and becomes slow. Do I do something wrong here? Do I need this coloring? All I need is more sparse DMDA matrix… I am somewhat lost.
Thank you very much and best regards,
Alex Koshkarov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200814/da46e447/attachment.html>
