[petsc-users] win32fe icl won't work
Balay, Satish
balay at mcs.anl.gov
Mon Dec 16 19:30:27 CST 2019
Try:
mv /usr/bin/link.exe /usr/bin/link-cygwin.exe
And rerun configure
Satish
On Mon, 16 Dec 2019, Sam Guo wrote:
> Thanks for the quick response. I attach the configure.log again.
> icl is found
> $ icl
> Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64,
> Version 18.0.3.210 Build 20180410
> Copyright (C) 1985-2018 Intel Corporation. All rights reserved.
> icl: command line error: no files specified; for help type "icl /help"
> On Mon, Dec 16, 2019 at 7:03 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > The attached configure.log is a link file. Can you resend the log from
> > PETSC_ARCH/lib/petsc/conf
> > Also can you verify that you followed instructions from
> > https://www.mcs.anl.gov/petsc/documentation/installation.html#windows
> > [its not explicitly specified - but you need to run the correct cmd that
> > sets up Intel compiler - instead of the MS compiler]
> > i.e verify 'icl' works from cygwin/bash - before attempting configure.
> > Satish
> > > Dear PETSc dev team,
> > > I tried to compile petsc using intel compiler win32fe icl on cygwin
> > but
> > > encountered error. By the way, I am able to compile using visual studio
> > > compiler win32fe cl.
> > > Configuring PETSc to compile on your system
> > > Warning: "with-clean" is specified. Removing all build files from
> > arch-starccmplus_s===============================================================================
> > > TESTING: checkCCompiler from
> > config.setCompilers(config/BuildSystem/config/setCompilers.py*******************************************************************************
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > > details):
> > > C compiler you provided with -with-cc=win32fe icl does not work.
> > > Cannot compile/link C with
> > > /home/xianzhongg/dev/star/petsc/lib/petsc/bin/win32fe/win32fe icl.
> > > BR,
> > > Sam
