[petsc-users] DMDA with dimension of size 1
Patrick Sanan patrick.sanan at gmail.com
Mon Oct 1 09:57:16 CDT 2018
Whoops, sent that patch too fast (forgot to update SETERRQ3 to SETERRQ4).
Updated patch for maint attached.
Am Mo., 1. Okt. 2018 um 16:55 Uhr schrieb Patrick Sanan <
patrick.sanan at gmail.com>:
> Meshes of size 1 should work.
> Looks like there is a bug in the code to produce this error message (patch
> for maint attached). It's not outputting the "P" (size in the 3rd
> dimension) component.
> This is just speculation without a full error message or code to
> reproduce, but perhaps the size in the third dimension is an uninitialized
> value which is triggering this warning with a 10 x 10 x (huge garbage) x 1
> (dof) mesh.
> Am Mo., 1. Okt. 2018 um 15:59 Uhr schrieb Phil Tooley <
> phil.tooley at sheffield.ac.uk>:
>> Hi all,
>> Is it valid to have a DMDA with one of the dimensions of size 1.  I was
>> hoping to avoid having to write explicit logic to handle the case that I
>> am working on a 2D rather than a 3D image for my current application.
>> Unfortunately when I try to construct such a DMDA I get an error:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Overflow in integer operation:
>> [0]PETSC ERROR: Mesh of 10 by 10 by 1 (dof) is too large for 32 bit
>> indices
>> Is there a workaround other than "write everything twice"?
>> Thanks
>> Phil
>> Phil Tooley
>> Research Software Engineering
>> University of Sheffield
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181001/7d04df3e/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181001/7d04df3e/attachment.obj>
