[petsc-users] Example 23 of ksp problems
Fazlul Huq huq2090 at gmail.com
Thu Nov 29 13:37:41 CST 2018
Thanks!
Sincerely,
Huq
On Tue, Nov 27, 2018 at 10:57 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>     This is an ad hoc way of checking that the error from the linear solve
> is "reasonable".  Note that PETSC_MACHINE_EPSILON
> depends on the precision of the floating point used so for more precise
> floating point (in going from half precision to quad precision) we expect
> the error
> to be smaller (depending on the machine epsilon). The 1000 is an arbitrary
> number, it could be 100 or 10,000 or anything in between could be
> reasonable. Note that using a 1.0 is probably not reasonable because it is
> not reasonable to expect the error to be only a machine epsilon away from
> the "exact" answer.
>     Barry
> If you are not familiar with the term machine epsilon you can google it.
> > On Nov 26, 2018, at 9:30 PM, Fazlul Huq via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hello PETSc developers,
> > I went through the ex23.c of ksp section attached herewith but I don't
> understand the following part:
> > tol=1000.*PETSC_MACHINE_EPSILON
> > and,
> > ierr = VecAXPY(x,-1.0,u);CHKERRQ(ierr);
> >  ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
> >  ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);
> >  if (norm > tol) {
> >  ierr = PetscPrintf(PETSC_COMM_WORLD,"Norm of error %g, Iterations
> %D\n",  (double)norm,its);CHKERRQ(ierr);
> > I don't understand what is "tol" here and "*PETSC_MACHINE_EPSILON"?
> > The if condition is also not clear to me.
> > Thanks.
> > Sincerely,
> > Huq
> > Fazlul Huq
> > Graduate Research Assistant
> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> > University of Illinois at Urbana-Champaign (UIUC)
> > E-mail: huq2090 at gmail.com
> > <ex23.c>
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/ae2517bf/attachment.html>
