[petsc-users] residual norm with TSPSEUDO
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Wed Jun 13 11:18:43 CDT 2018
-ts_monitor_pseudo  ?
> On Jun 13, 2018, at 10:54 AM, Praveen C <cpraveen at gmail.com> wrote:
> Hello Barry
> I am working in Fortran :-(
> I can see the residual if I use -info but it prints too much information. Is it possible to reduce the amount of log messages printed to screen, some sort of log-level ???
   | grep -i "String you want"   ?
> Thanks
> praveen
>> On 13-Jun-2018, at 8:29 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>   Take a look at TSPseudoMonitorDefault() in src/ts/impls/pseudo/posindep.c
>>    The problem is that you need to expose
>> typedef struct {
>>  Vec update;       /* work vector where new solution is formed */
>>  Vec func;         /* work vector where F(t[i],u[i]) is stored */
>>  Vec xdot;         /* work vector for time derivative of state */
>>  /* information used for Pseudo-timestepping */
>>  PetscErrorCode (*dt)(TS,PetscReal*,void*);              /* compute next timestep, and related context */
>>  void *dtctx;
>>  PetscErrorCode (*verify)(TS,Vec,void*,PetscReal*,PetscBool*);  /* verify previous timestep and related context */
>>  void *verifyctx;
>>  PetscReal fnorm_initial,fnorm;                   /* original and current norm of F(u) */
>>  PetscReal fnorm_previous;
>>  PetscReal dt_initial;                     /* initial time-step */
>>  PetscReal dt_increment;                   /* scaling that dt is incremented each time-step */
>>  PetscReal dt_max;                         /* maximum time step */
>>  PetscBool increment_dt_from_initial_dt;
>>  PetscReal fatol,frtol;
>> } TS_Pseudo;
>> inside your application code (that is make a copy of this struct definition and put it in your code so you can access the fields).
>>   Barry
