[petsc-users] Error during PETSc build on Edison
Amneet Bhalla mail2amneet at gmail.com
Mon Jan 29 22:19:41 CST 2018
Hi Satish --- I am trying GNU. I am configuring with these additional
flags, and it seems to be past that point. I will let you know if it works
fine all the way.
The reason I am not using prebuilt PETSc on NERSC is that I want to be
consistent with C++, C, and fortran
compilers with all the 3rd party libraries I am building for a code (that
requires them).
On Mon, Jan 29, 2018 at 8:14 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 30 Jan 2018, Satish Balay wrote:
> > 1. cray provides prebuilt petsc libraries. Does that work for you?
> > 2. verylikely  you need:
> > --with-clib-autodetect=0
> > --with-cxxlib-autodetect=0
> Also
> --with-fortranlib-autodetect=0
> > LIBS=-lstdc++
> > If it doesn't work - send configure.log
> BTW: What compilers do you require? Intel or GNU?
> Satish
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180129/deff8d66/attachment.html>
