[petsc-users] I have a question for PETSc example
Tue Jan 16 05:48:16 CST 2018
On Mon, Jan 15, 2018 at 8:28 PM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
wrote:
> sorry, I mean that
> *My geometry is a rectangle*.
> That means, geometry is just rectangle box shape with four boundary.
> My question is that, how can I set the four boundary condition
> individually in example 12 of SNES?
You put a different marker on each side. The easiest way to do it is to
give the
  -dm_plex_separate_marker
option. This is done in SNES ex69.
     Matt
> (I think that the boundary condition should be added in right side of the
> weak form, where load vector f and test function term is included. However,
> in example of petsc, boundary condition is applied as general form.)
> Seungjin Seo
> *보낸 사람:* Smith, Barry F. <bsmith at mcs.anl.gov>
> *보낸 날짜:* 2018년 1월 15일 월요일 오후 11:06:18
> *받는 사람:* 서승진 (기계항공및원자력공학부)
> *참조:* Smith, Barry F.; petsc-users at mcs.anl.gov
> *제목:* Re: [petsc-users] I have a question for PETSc example
>    The term "rectangular mesh" usually refers to a "structured grid mesh"
> so it is not clear if you truly need an unstructured grid. Take a look at
> src/snes/examples/tutorials/ex19.c
>   Barry
> > On Jan 15, 2018, at 1:03 AM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
> wrote:
> > Dear PETSc-user
> > I am Seungjin Seo, researcher of Korean Advanced Institute of Science
> and Technology, South Korea.
> > I am tring to understand the ex12.c in SNES examples, and I have a
> problem...
> > Could you give me some advise? Is there any good description or
> materials for PetscFE and DMPlex?
> > I will make a code with unstructured grid with PetscFE and SNES. My
> geometry is a rectangle mesh (the size is not fixed so I think this is
> unstructured grid).
> > The equation is
> > I will set boundry conditions as follow;
> >   1. (Top-side boundary) Neumann boundary
> >   2. (Bottom-side boundary) Neumann boundary
> >   3. (Left-side boundary) Dirichlet boundary
> >   4. (Right-side boundary) Dirichlet boundary
> > In example ex12.c in SNES, load vector f is defiend as f_0, and neumann
> boundary condition is defined as f_bd_0. f_1 means the test function
> gradient term. The example set general type of neumann boundary condition
> on f_bd_0, but I want to set each boundary condition individually. Could
> > Thansk for reading my email.
> > Best regard,
> > Seungjin Seo
> > 보낸 사람: Smith, Barry F. <bsmith at mcs.anl.gov>
> > 보낸 날짜: 2017년 12월 21일 목요일 오후 3:46:42
> > 받는 사람: 서승진 (기계항공및원자력공학부)
> > 참조: petsc-users at mcs.anl.gov
> > 제목: Re: [petsc-users] I have a question for PETSc example
> >   In deed you can, yes many PETSc examples only feature a single field
> for simplicity, but multiple fields are fine. You simple provide your
> FormFunction and FormJacobian to handle both degrees of freedom per
> cell/node at the same time. You use SNES or TS depending on if your problem
> is time dependent and then use -pc_type lu to start. Once you have the
> physics correct come back and ask us about optimizing the linear solver
> with preconditioners; but until you have the physics correct it is absurd
> to waste time worrying about making the linear solver efficient. What you
> want to do, many people do and is not a big deal.
> >    Barry
> > > On Dec 21, 2017, at 12:27 AM, 서승진 (기계항공및원자력공학부) <mistloin at unist.ac.kr>
> wrote:
> > > Dear PETSc-user
> > > I am trying to solve thermal and fluid equations within a porous
> structure.
> > > The thermal equation includes a non-linear term of pressure and the
> fluid equation has a boundary condition using temperature gradient.
> > > Is there any way I can solve these two equations at the same time,
> instead of solving temperature first with previous pressure distribution
> and then pressure and update temperature?
> > > Many examples solve only one PDF instead of coupling several physics.
> > > Please recommend me which solver is appropriate for my case?
> > > Best regards,
> > > Seungjin Seo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180116/103897b6/attachment-0001.html>
