[petsc-users] Fortran: undefined reference to petscsfdistributesection
Danyang Su danyang.su at gmail.com
Mon Dec 3 15:12:03 CST 2018
On 2018-12-03 12:56 p.m., Matthew Knepley wrote:
> On Mon, Dec 3, 2018 at 3:40 PM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     On 2018-12-03 12:03 p.m., Matthew Knepley wrote:
>>     On Mon, Dec 3, 2018 at 2:27 PM Danyang Su <danyang.su at gmail.com
>>         Hi Matt,
>>         Thanks.
>>         BTW: DmPlexGetVertexNumbering now can work using the latest
>>         develop version. But the index is not in natural ordering
>>         when DMSetUseNatural is called. That's why I want to use
>>         PetscSFDistributeSection to check if I miss anything in the code.
>>     Can you explain that a little more? Maybe you can just push
>>     forward what you want using the migrationSF.
>     Hi Matt,
>     Since I cannot figure what is wrong or missing in my code, I
>     followed an old ex26.c example in src/dm/impls/plex/examples/tests
>     to create similar code as shown below to test global to natural
>     ordering. The code may be ugly with unnecessary functions in it.
>     Using DmPlexGetVertexNumbering, I can get the value but it is not
>     in natural order, instead, it is still in default PETSc order
>     without calling DMSetUseNatural(dm,PETSC_TRUE,ierr).
> I do not understand what you are doing below. You just need to call
>     ierr = DMSetUseNatural(dm,PETSC_TRUE);CHKERRQ(ierr);
>     ierr = DMPlexDistribute(dm,0,&migrationSF,&pdm);CHKERRQ(ierr);
>     if (pdm) {
>       ierr = DMPlexSetMigrationSF(pdm,migrationSF);CHKERRQ(ierr);
> and the DMGlobalToNaturalBegin/End() should work.
You mean to use DMPlexGlobalToNaturalBegin/End(), right? That's what I
tried at first, but without success.
I will create a test example to make further check if I can reproduce
the problem.
Danyang
>   Thanks,
>      Matt
>               if (rank == 0) then
>                 call
>     DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells,
>     num_nodes,num_nodes_per_cell,    &
>     Petsc_False,dmplex_cells,ndim, dmplex_verts,dm,ierr)
>                 CHKERRQ(ierr)
>               else
>                 call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,
>     0,num_nodes_per_cell,    &
>     Petsc_False,dmplex_cells,ndim,dmplex_verts,dm,ierr)
>                 CHKERRQ(ierr)
>               end if
>               if (nprocs > 1) then
>                 call DMSetUseNatural(dm,PETSC_TRUE,ierr)
>                 CHKERRQ(ierr)
>               end if
>               call DMPlexDistribute(dm,stencil_width,                &
>     migrationsf,distributedMesh,ierr)
>               CHKERRQ(ierr)
>               if (distributedMesh /= PETSC_NULL_DM) then
>                 call
>     PetscSFCreateInverseSF(migrationsf,migrationsf_inv,ierr)
>                 CHKERRQ(ierr)
>                 call
>     DMCreateGlobalToNatural(distributedMesh,migrationsf,migrationsf_inv,ierr)
>                 CHKERRQ(ierr)
>                 call DMGetSection(distributedMesh,section,ierr)
>                 CHKERRQ(ierr)
>                 call PetscSectionCreate(Petsc_Comm_World,section_seq,ierr)
>                 CHKERRQ(ierr)
>                 call PetscSFDistributeSection(migrationsf_inv,section, &
>     PETSC_NULL_INTEGER,section_seq,ierr)
>                 CHKERRQ(ierr)
>                 call DMPlexCreateGlobalToNaturalSF(distributedMesh, &
>     section_seq,migrationsf,sf_natural,ierr)
>                 CHKERRQ(ierr)
>                 call DMSetUseNatural(distributedMesh,PETSC_TRUE,ierr)
>                 CHKERRQ(ierr)
>                 call PetscSFDestroy(migrationsf,ierr)
>                 CHKERRQ(ierr)
>                 call PetscSFDestroy(migrationsf_inv,ierr)
>                 CHKERRQ(ierr)
>               end if
>     Thanks,
>     Danyang
>>       Thanks,
>>          Matt
>>         Regards,
>>         Danyang
>>         On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
>>>         I need to write a custom Fortran stub for this one. I will
>>>         get it done as soon as possible.
>>>           Thanks,
>>>             Matt
>>>         On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via petsc-users
>>>         <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>         wrote:
>>>             Hi All,
>>>             I got a simple compilation error when use
>>>             PetscSFDistributeSection in
>>>             Fortran. It looks like the required head files are
>>>             included and the
>>>             parameters are correctly defined. However, when compile
>>>             the code, I got
>>>             error undefined reference to
>>>             `petscsfdistributesection_'. The code is
>>>             shown below. Did I miss anything here?
>>>             #include <petsc/finclude/petscsys.h>
>>>             #include <petsc/finclude/petscvec.h>
>>>             #include <petsc/finclude/petscdm.h>
>>>             #include <petsc/finclude/petscdmplex.h>
>>>                    use petscsys
>>>                    use petscvec
>>>                    use petscdm
>>>                    use petscdmplex
>>>                    implicit none
>>>                    PetscSection ::  section, section_seq
>>>                    PetscSF :: migrationsf_inv, sf_natural
>>>                    Vec :: vec_global, vec_natural
>>>                    PetscErrorCode :: ierr
>>>                    call
>>>                    CHKERRQ(ierr)
>>>                        call
>>>                        CHKERRQ(ierr)
>>>             Thanks,
>>>             Danyang
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>>         https://www.cse.buffalo.edu/~knepley/
>>>         <http://www.cse.buffalo.edu/~knepley/>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/5175c89b/attachment.html>
